Buienradar settings
Derik
- Domoticz version: BETA
Buienradar settings
Holiday so time for the hobby.
I saw a buienradar_rain script when I was logged in with FTP.
I have adjusted the data.
I have a dummy rain sensor.
But now?
I need a crontab?
What does this sensor?
What else can I set?
But now?
I need a crontab?
- gizmocuz
Re: Buienradar settings
It will tell you the change (in percentage) of rain in the next 5 minutes
you could use a script/blockly to close your windscreens/doors/....
Derik
I do something wrong..:
Only what..
- gizmocuz
i added a crontab job with the command
that looks like
(you have to change <USER> with your domoticz user, for instance pi or linaro)
and i think you can leave the IP to 127.0.0.1 (and add this IP in your local networks in the domoticz settings page)
crontab -eCode: Select all
*/5 * * * * perl /home/<USER>/domoticz/buienradar_rain.pland i think you can leave the IP to 127.0.0.1 (and add this IP in your local networks in the domoticz settings page)
Derik
Where do i go wrong..
Crontab installed..[ with linaro user ]
Only i see a red device...
And i do not undertand:
the 127.0.0.1 ?
I run on a CB2?
the 127.0.0.1 ?
I run on a CB2?
- gizmocuz
this script runs locally on your cubietruck, so you can use the local ip address 127.0.0.1
in domoticz, enter this 127.0.0.1 in your local network settings, so it will not need a password
if you type
crontab -e
(was already installed)
then enter the following line
*/5 * * * * perl /home/linaro/domoticz/buienradar_rain.pl
that is, if you installed domoticz in the folder /home/linaro/domoticz
if you type
crontab -e
Derik
Looks good...
Only it is killing my dummy rain sensor:
linaro@cubie:~$ sudo perl /home/linaro/domoticz/scripts/buienradar_rain.pl
OK, precip=0.00Code: Select all
#!/usr/bin/perl -w
use strict;
use LWP::UserAgent;
use HTTP::Cookies;
my $lat=50.22041;
my $long=5.89744;
my $domoticz_ip="192.168.5.70";
my $domoticz_port="8080";
my $domoticz_sensor_idx="3904";
my $duration=15;
my @user_agents = (
'Mozilla/4.0 (compatible; MSIE 4.01; Windows 98)'
Derik
Okay ...[ Thanks! ]
And the higher the percentage, the more chance of rain?
Too bad he is not active weather sensors.
- gizmocuz
correct, 20-30 is a good change, best to look outside when it is raining, and check the percentage
Derik
Thanks,,,
The time Domoticz can forecast with this option is about 2 hours...?
- gizmocuz
upcoming 15 minutes (it is a parameter in the sketch)
(will it rain in the next 15 minutes...)
Derik
mmmm
Thanks.
I now how this option is working now..
Great!
Thanks.
Great!
Derik
Update problem...
After the last update a red device....
I try:
So it is not working any more..
I make no changes....
Are there more problems?
I try:
Error sending data to domoticz!
- gizmocuz
What version? Did you try to update again?
What other problems?
Derik
Did 20 minutes ago the update...
After that the % device is red..
Perhaps there are more people with a problem was what i mean..
Derik
Found it...!!!
The update make the settings in the document back to standard....
my idx was changed and the domoticz ip was chagend to..
Changed them back: So it is working again....
- gizmocuz
yes, you need to copy this template to another location, edit it, and then use it in the crontabDerik wrote:Found it...!!!
Derik
pppffffff, makes sence indeed
I going to do this...
Perhaps in the document a short how to..
