Buienradar settings
Derik
Buienradar settings
Post by Derik »
Holiday so time for the hobby.
I saw a buienradar_rain script when I was logged in with FTP.
I have adjusted the data.
I have a dummy rain sensor.
But now?
I need a crontab?
What does this sensor?
What else can I set?
gizmocuz
Re: Buienradar settings
Post by gizmocuz »
It will tell you the change (in percentage) of rain in the next 5 minutes
you could use a script/blockly to close your windscreens/doors/....
Derik
Post by Derik »
I do something wrong..:
Only what.. :oops:
gizmocuz
Post by gizmocuz »
i added a crontab job with the command
crontab -e
that looks like
*/5 * * * * perl /home/<USER>/domoticz/buienradar_rain.pl
(you have to change <USER> with your domoticz user, for instance pi or linaro)
and i think you can leave the IP to 127.0.0.1 (and add this IP in your local networks in the domoticz settings page)
Derik
Post by Derik »
Where do i go wrong..
Crontab installed..[ with linaro user ]
Only i see a red device...
And i do not undertand:
the 127.0.0.1 ?
I run on a CB2?
gizmocuz
Post by gizmocuz »
this script runs locally on your cubietruck, so you can use the local ip address 127.0.0.1
in domoticz, enter this 127.0.0.1 in your local network settings, so it will not need a password
if you type
crontab -e
(was already installed)
then enter the following line
*/5 * * * * perl /home/linaro/domoticz/buienradar_rain.pl
that is, if you installed domoticz in the folder /home/linaro/domoticz
Derik
Post by Derik »
Looks good...
linaro@cubie:~$ sudo perl /home/linaro/domoticz/scripts/buienradar_rain.pl
OK, precip=0.00
#!/usr/bin/perl -w
use strict;
use LWP::UserAgent;
use HTTP::Cookies;
my $lat=50.22041;
my $long=5.89744;
my $domoticz_ip="192.168.5.70";
my $domoticz_port="8080";
my $domoticz_sensor_idx="3904";
my $duration=15;
my @user_agents = (
		'Mozilla/4.0 (compatible; MSIE 4.01; Windows 98)'
Only it is killing my dummy rain sensor:
gizmocuz
Post by gizmocuz »
You have to use a percentage sensor
Derik
Post by Derik »
Okay ...[ Thanks! ]
And the higher the percentage, the more chance of rain?
Too bad he is not active weather sensors. ;)
gizmocuz
Post by gizmocuz »
correct, 20-30 is a good change, best to look outside when it is raining, and check the percentage
Derik
Post by Derik »
Thanks,,,
The time Domoticz can forecast with this option is about 2 hours...?
gizmocuz
Post by gizmocuz »
upcoming 15 minutes (it is a parameter in the sketch)
(will it rain in the next 15 minutes...)
Derik
Post by Derik »
mmmm
Thanks.
I now how this option is working now..
Great!
Derik
Post by Derik »
Update problem...
After the last update a red device....
I try:
Error sending data to domoticz!
So it is not working any more..
I make no changes....
Are there more problems?
gizmocuz
Post by gizmocuz »
What version? Did you try to update again?
What other problems?
Derik
Post by Derik »
Did 20 minutes ago the update...
After that the % device is red..
Perhaps there are more people with a problem was what i mean..
Derik
Post by Derik »
Found it...!!!
The update make the settings in the document back to standard....
my idx was changed and the domoticz ip was chagend to..
Changed them back:
So it is working again....
gizmocuz
Post by gizmocuz »
Derik wrote:Found it...!!!
yes, you need to copy this template to another location, edit it, and then use it in the crontab
Derik
Post by Derik »
pppffffff, makes sence indeed
I going to do this...
Perhaps in the document a short how to.. :-)
gizmocuz
Post by gizmocuz »
Good idea ! I will do this
