FlatZ Frontpage
Re: FlatZ Frontpage
Can you help me to custom cells?
I want modify temp cells like that (Temp & Humidy on same cell) :
I think the chart isn't necessary for temp cells (for exemple we can automaticly change color of temp, blue = cold, red =hot).
How we can modify icons? exemple for electricity :
How we can add multiple status lines like here ?
Other question : is possible to add a group/scene to left switch panel ?
Thanks for your help !
Re: FlatZ Frontpage
Same here. But i don't have it in the Domoticz folder, but in the 'Web Station' (Synology) folder:jjnj wrote:For some reason my colours are white and pink
/volume1/web/
So maybe it has something to do with the paths or so? I would like to have it outside of Domoticz, so files are kept when upgrading Domoticz and it is easier to make backups.
- Domoticz version: 3.5877
Re: FlatZ Frontpage
In settings.js (/settings) you see $.theme = "mainLight.css"; //possible values: 'main.css', 'mainPurple.css', 'mainLight.css'ThinkPad wrote:Same here. But i don't have it in the Domoticz folder, but in the 'Web Station' (Synology) folder:jjnj wrote:For some reason my colours are white and pink
/volume1/web/
If you change mainLight.css to main.css the theme is dark again.
Re: FlatZ Frontpage
Thanks, that worked
Another question: is it by purpose that the log search function (great feature!) is case sensitive? Being not case sensitive would be a bit easier.
Will have a look at the page later, maybe i'll find some other improvement points. But for now it looks promising!
Re: FlatZ Frontpage
I don't think Galadril did it on purpose, but if you modify the following the search will be case-insensitive:ThinkPad wrote:Thanks, that worked
In methods.js add on row 558: var tempText = totalText.toLowerCase();
and change row 559 to : if (filter.length <= 0 || tempText.indexOf(filter) >= 0) {
I'm really excited about this frontpage!
{edit}
Wrong code inserted
- G3rard
- Target OS: -
- Domoticz version: No
Re: FlatZ Frontpage
Nice, thanks!Patrick wrote:I don't think Galadril did it on purpose, but if you modify the following the search will be case-insensitive:ThinkPad wrote:Thanks, that worked
{edit}
Wrong code inserted
Not using Domoticz anymore
- galadril
- Domoticz version: latest
Re: FlatZ Frontpage
Patrick wrote:In settings.js (/settings) you see $.theme = "mainLight.css"; //possible values: 'main.css', 'mainPurple.css', 'mainLight.css'
- galadril
Re: FlatZ Frontpage
Thanks for the help, if you like you can also contribute on the github pagePatrick wrote:In methods.js add on row 558: var tempText = totalText.toLowerCase();
Re: FlatZ Frontpage
@galadril,
I have a problem with dimming my KaKu dimmers.
The MaxDimLevel of these devices is 15, but FlatZ sends 0 - 100.
Can you insert a extra variable for setting the max dim level?
So if max is 15 the level send with the dim command is not eg 40 but 40*(MaxDimLevel / 100).
Re: FlatZ Frontpage
If you would like to explain how contributing on GitHub works , sure!galadril wrote:Thanks for the help, if you like you can also contribute on the github pagePatrick wrote:In methods.js add on row 558: var tempText = totalText.toLowerCase();
- galadril
Re: FlatZ Frontpage
You can change the code via Github Desktop (for example)Patrick wrote:If you would like to explain how contributing on GitHub works , sure!
https://desktop.github.com/
How-to:
https://guides.github.com/activities/co ... en-source/
Re: FlatZ Frontpage
Got Github installed and started learning the Gitgaladril wrote:You can change the code via Github Desktop (for example)Patrick wrote:If you would like to explain how contributing on GitHub works , sure!
How-to:
I will add the case-insensitive code as a trial.
- galadril
Re: FlatZ Frontpage
Cool!Patrick wrote:I will add the case-insensitive code as a trial.
Re: FlatZ Frontpage
I guess I've done thing the right way?galadril wrote:Cool!Patrick wrote:I will add the case-insensitive code as a trial.
How can I see what you're working on? So we don't do things twice
- galadril
Re: FlatZ Frontpage
At this moment there is one 'master' branche of FlatZ frontpage and I've nothing open.Patrick wrote:How can I see what you're working on? So we don't do things twice
When I'm working on it, I'm first making a new branche of it, then do my code changes.. and then if it;s finished merge the code back to the master.
When I've a second development branche open, you can see that in Git Desktop (not at the moment..)
Re: FlatZ Frontpage
Ok.galadril wrote:At this moment there is one 'master' branche of FlatZ frontpage and I've nothing open.Patrick wrote:How can I see what you're working on? So we don't do things twice
Tonight I will try to fix the Kaku dimmer problem (If the wife doesn't mind me testing it all the time )
Re: FlatZ Frontpage
Great forntpage, I'm trying it out now.
But I can't the lights page do display correctly, It seems like it gets broken. I only see the menu at top, and a white page under with six lightbulbs and a switch icon.
Also I can't display the weather, but the page loads correctly it seems.
All other pages seems to be correct.
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
- galadril
Re: FlatZ Frontpage
Do you see errors in the console of your browser (f12, then choose console.. and reload the page)
Re: FlatZ Frontpage
Yesgaladril wrote:Do you see errors in the console of your browser (f12, then choose console.. and reload the page)
ReferenceError: $ is not defined settings.js:2:0
ReferenceError: $ is not defined noty.js:1:0
ReferenceError: jQuery is not defined jquery-ui.min.js:6:51
ReferenceError: $ is not defined lights.html:215:9
