FlatZ Frontpage
MAidEN
Re: FlatZ Frontpage
Post by MAidEN »
Can you help me to custom cells?
I want modify temp cells like that (Temp & Humidy on same cell) :
I think the chart isn't necessary for temp cells (for exemple we can automaticly change color of temp, blue = cold, red =hot).
How we can modify icons? exemple for electricity :
How we can add multiple status lines like here ?
Other question : is possible to add a group/scene to left switch panel ?
Thanks for your help ! :)
jjnj
Re: FlatZ Frontpage
Post by jjnj »
For some reason my colours are white and pink
ThinkPad
Re: FlatZ Frontpage
Post by ThinkPad »
jjnj wrote:For some reason my colours are white and pink
Same here. But i don't have it in the Domoticz folder, but in the 'Web Station' (Synology) folder:
/volume1/web/
So maybe it has something to do with the paths or so? I would like to have it outside of Domoticz, so files are kept when upgrading Domoticz and it is easier to make backups.
Patrick
Domoticz version: 3.5877
Re: FlatZ Frontpage
Post by Patrick »
/volume1/web/
In settings.js (/settings) you see $.theme = "mainLight.css"; //possible values: 'main.css', 'mainPurple.css', 'mainLight.css'
If you change mainLight.css to main.css the theme is dark again.
ThinkPad
Re: FlatZ Frontpage
Post by ThinkPad »
Thanks, that worked :)
Another question: is it by purpose that the log search function (great feature!) is case sensitive? Being not case sensitive would be a bit easier.
Will have a look at the page later, maybe i'll find some other improvement points. But for now it looks promising!
Patrick
Re: FlatZ Frontpage
Post by Patrick »
ThinkPad wrote:Thanks, that worked :)
I don't think Galadril did it on purpose, but if you modify the following the search will be case-insensitive:
In methods.js add on row 558: var tempText = totalText.toLowerCase();
and change row 559 to : if (filter.length <= 0 || tempText.indexOf(filter) >= 0) {
I'm really excited about this frontpage!
{edit}
Wrong code inserted :oops:
G3rard
Domoticz version: No
Re: FlatZ Frontpage
Post by G3rard »
{edit}
Nice, thanks!
Not using Domoticz anymore
galadril
Domoticz version: latest
Re: FlatZ Frontpage
Post by galadril »
Patrick wrote:In settings.js (/settings) you see $.theme = "mainLight.css"; //possible values: 'main.css', 'mainPurple.css', 'mainLight.css'
galadril
Re: FlatZ Frontpage
Post by galadril »
Patrick wrote:In methods.js add on row 558: var tempText = totalText.toLowerCase();
Thanks for the help, if you like you can also contribute on the github page :)
Patrick
Re: FlatZ Frontpage
Post by Patrick »
@galadril,
I have a problem with dimming my KaKu dimmers.
The MaxDimLevel of these devices is 15, but FlatZ sends 0 - 100.
Can you insert a extra variable for setting the max dim level?
So if max is 15 the level send with the dim command is not eg 40 but 40*(MaxDimLevel / 100).
Patrick
Re: FlatZ Frontpage
Post by Patrick »
If you would like to explain how contributing on GitHub works :oops: , sure!
galadril
Re: FlatZ Frontpage
Post by galadril »
Patrick wrote:If you would like to explain how contributing on GitHub works :oops: , sure!
You can change the code via Github Desktop (for example)
https://desktop.github.com/
How-to:
https://guides.github.com/activities/co ... en-source/
Patrick
Re: FlatZ Frontpage
Post by Patrick »
How-to:
Got Github installed and started learning the Git :D
I will add the case-insensitive code as a trial.
galadril
Re: FlatZ Frontpage
Post by galadril »
Patrick wrote:I will add the case-insensitive code as a trial.
Cool!
Patrick
Re: FlatZ Frontpage
Post by Patrick »
Cool!
I guess I've done thing the right way? :lol:
How can I see what you're working on? So we don't do things twice ;)
galadril
Re: FlatZ Frontpage
Post by galadril »
Patrick wrote:How can I see what you're working on? So we don't do things twice
At this moment there is one 'master' branche of FlatZ frontpage and I've nothing open.
When I'm working on it, I'm first making a new branche of it, then do my code changes.. and then if it;s finished merge the code back to the master.
When I've a second development branche open, you can see that in Git Desktop (not at the moment..)
Patrick
Re: FlatZ Frontpage
Post by Patrick »
Ok.
Tonight I will try to fix the Kaku dimmer problem (If the wife doesn't mind me testing it all the time 8-) )
thorbj
Re: FlatZ Frontpage
Post by thorbj »
Great forntpage, I'm trying it out now.
But I can't the lights page do display correctly, It seems like it gets broken. I only see the menu at top, and a white page under with six lightbulbs and a switch icon.
Also I can't display the weather, but the page loads correctly it seems.
All other pages seems to be correct.
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
galadril
Re: FlatZ Frontpage
Post by galadril »
Do you see errors in the console of your browser (f12, then choose console.. and reload the page)
thorbj
Re: FlatZ Frontpage
Post by thorbj »
galadril wrote:Do you see errors in the console of your browser (f12, then choose console.. and reload the page)
Yes
ReferenceError: $ is not defined settings.js:2:0
ReferenceError: $ is not defined noty.js:1:0
ReferenceError: jQuery is not defined jquery-ui.min.js:6:51
ReferenceError: $ is not defined lights.html:215:9
Users browsing this forum: BarryT, madpatrick and 1 guest
