FlatZ Frontpage
- bizziebis
- Domoticz version: 3.8805
Re: FlatZ Frontpage
You can use the "Inspect element' feature of your browser (right mouseclick on screen). That way you can find out which Json command is being send when you use the slider, and what the result is. This will help solving your problem.
- mvveelen
Re: FlatZ Frontpage
This is the json:
So I guess it thinks I have colored LED lights...? But they are just regular lights with a dimmer.
http://192.168.0.124:8084/json.htm?type=command¶m=setcolbrightnessvalue&hue=undefined&idx=90&brightness=0&iswhite=false
- galadril
- Domoticz version: latest
Re: FlatZ Frontpage
If you call that json url in a browser, the lights also doesn;t dim?mvveelen wrote:So I guess it thinks I have colored LED lights...? But they are just regular lights with a dimmer.
Can je else remove the '&hue=undefined' part of the url, and try again.. does that work?
PS, my lights are all philips hue lichts, so i haven't test alot without hue..
Domoticz Android app:
https://play.google.com/store/apps/deta ... s.domoticz
- bizziebis
Re: FlatZ Frontpage
@mvveelen
You can also use the domoticz dash and use the slider of the specific light. Then post the json here to see what's possible.
- mvveelen
Re: FlatZ Frontpage
This is the json that works for the regular lights with dimmer:
http://192.168.0.124:8084/json.htm?type=command¶m=switchlight&idx=90&switchcmd=Set%20Level&level=8
pvm
- Domoticz version: 4.10538
Re: FlatZ Frontpage
Can you put some more help in the settings file?
Like how to set the cell values, what parameters to use for a dimmer, a switch, energy, etc. etc.?
(I am struggling to put a dimmer value on the frontpage)
- galadril
Re: FlatZ Frontpage
I've changed the method.js.mvveelen wrote:This is the json that works for the regular lights with dimmer:
You can now specify two types of lights in the settings.js ('Hue' (color lamp) or 'Dimmer'):
// Graph screen User settings >>> (max 3 on screen)
['11', 'Hue', 'cell7', 'Tafel 1'] >> works with colored JSON call
['11', 'Dimmer', 'cell7', 'Tafel 1'] >> works with the switch dimmer JSON call
I couldn't test it myself, can you try?
https://github.com/galadril/FlatZ-Frontpage
- galadril
Re: FlatZ Frontpage
I'm adding a weather tab
- weather.png (31.77 KiB) Viewed 4378 times
- Minglarn
- Domoticz version: v3.8153
Re: FlatZ Frontpage
Been watching this front page for a while now .. and I really like what I see. =)
How do I add this frontpage without deleting the original page?
As I understand, you have to overwrite the default files with this or am I wrong?
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
- galadril
Re: FlatZ Frontpage
You put all the files under 'www' directory.Minglarn wrote:How do I add this frontpage without deleting the original page?
It doesn't overwrite the default domoticz site, just the custom frontpage (if you have one..)
- bizziebis
Re: FlatZ Frontpage
Is it also possible to append the log? That would make the filter option really great.
- mvveelen
Re: FlatZ Frontpage
Krommenie? That's not too far from where I live
I've tried the new version (am I right that the settings file isn't changed?), and the slider doesn't work as expected. When I move it to the right, the light is brighter, but the % (top of the cell) doesn't change and also when I move the slider to the left, the light stays bright (100%).
I haven't looked at the code yet, because I'm facing some other challenges, but maybe I can try to find out where it goes wrong. What parts do I have to look at exactly?
Oh, and great work on the weather tab. Are you using the Skycons ? Or are those static images ?
- Minglarn
FlatZ Frontpage
Thanks. Will try to add this to mine and check how it works on my iPadgaladril wrote:You put all the files under 'www' directory.Minglarn wrote:How do I add this frontpage without deleting the original page?
Again, great job with this!
- galadril
Re: FlatZ Frontpage
Krommenie yesmvveelen wrote:I haven't looked at the code yet, because I'm facing some other challenges, but maybe I can try to find out where it goes wrong. What parts do I have to look at exactly?
But please check the methods.js, it happens in this function:
function setLightDimmer(idx, bright)
If you compare the json calls with the json calls of Domoticz itself, maybe you can find the problem..
- galadril
Re: FlatZ Frontpage
Thanks, hope you like it!Minglarn wrote:Again, great job with this!
Heisenberg
Re: FlatZ Frontpage
Nice improvements!
Is it possible to add a live feed of Buienradar like e.g. http://www.scheveningenlive.nl/buienradar/
And how can I implement live feed of my IP camera's? I think there are more members who have ip cameras for surveillance purposes too
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
- galadril
Re: FlatZ Frontpage
I'll put it on my listHeisenberg wrote:Is it possible to add a live feed of Buienradar like e.g. http://www.scheveningenlive.nl/buienradar/
- galadril
Re: FlatZ Frontpage
Adding some custom theme support
- theme_purple.png (54.53 KiB) Viewed 4278 times
misev
Re: FlatZ Frontpage
Really Nice! I will follow this topic
- G3rard
- Target OS: -
- Domoticz version: No
Re: FlatZ Frontpage
Great frontpage indeed!
Used your log and changed it a bit and am now using it as my Domoticz log (as a Custom page). The search function is also very handy and I like it that the newest item shows on top.
Last edited by G3rard on Wednesday 23 September 2015 20:41, edited 1 time in total.
Not using Domoticz anymore
