domoticz in synology as package! Available now.
G3rard
Domoticz version: No
Post by G3rard »
jumbotroll wrote:
mvveelen wrote:That would be the best solution imho because you never know what changes will be added in the rest of the www folder. Thank you for doing this, and if you want me to test: let me know ;)
Maybe it is a bad idea to keep the old /styles folder in case of updates.
I think maybe I will work on a another solution..
If there is a "custom-temp" folder in the styles folder we can keep that but update as usual?
This way
www/styles/custom-temp
What do you think about that?
Jumbotroll
Do styles appear in Domoticz when they are in the custom-temp folder? Also if there are more than one styles in it? If so then that's a nice solution. (Can't test this right now as I am not at home).
Not using Domoticz anymore
G3rard
Post by G3rard »
@Jumbotroll, I noticed that the file History.txt (in the var folder) is missing in the package. Is it possible to add this file in the packages? When you click on the version number in Domoticz this file is being showed if present.
Thanks in advance!
mvveelen
Post by mvveelen »
Sounds like a great idea. You only have to change the name of that theme into "custom-temp" and you're done. That's a safe way of updating :) !
jumbotroll
Post by jumbotroll »
G3rard wrote: Do styles appear in Domoticz when they are in the custom-temp folder? Also if there are more than one styles in it? If so then that's a nice solution. (Can't test this right now as I am not at home).
How many custom styles do we need?
Maybe if we make a installer script that keep all folder named custom-*
Work still in progress, so I don't know if I can make this work.
I am not a programmer,but a noob learning 8-)
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
G3rard
Post by G3rard »
jumbotroll wrote: How many custom styles do we need?
Jumbotroll
That's true, I have more custom styles in the folder but I am only using one of them. So keeping one folder is fine. If I want to use another style I can just copy it at that moment.
Last edited by G3rard on Saturday 05 September 2015 14:42, edited 1 time in total.
jumbotroll
G3rard wrote:@Jumbotroll, I noticed that the file History.txt (in the var folder) is missing in the package. Is it possible to add this file in the packages? When you click on the version number in Domoticz this file is being showed if present.
Thanks in advance!
I will take a look at this later :)
Jumbotroll
Jumbotroll
ThinkPad
Post by ThinkPad »
Isn't it possible to keep all the folders in there that don't come with Domoticz by default?
You know that Domoticz writes 'folderA', 'folderB', 'folderC' to that folder, so everything that is not A, B, C should be kept
jumbotroll
@G3rard
History.txt is fixed in 2.0.2950-7.
http://jadahl.dscloud.me/sspks/packages ... 2954-7.spk
Jumbotroll
Last edited by jumbotroll on Sunday 06 September 2015 23:25, edited 1 time in total.
Jumbotroll
G3rard
Post by G3rard »
@jumbotroll Great. Thanks a lot!!!
apepannetje
Post by apepannetje »
i don't now what kind of pks i have to install on the syno
this is a system of my brother.
the syno nas is a DS212+ Marvell Kirkwood mv6282 2.0Ghz ARM (Marvell ARMADA 300)
i have trye to install domoticz_armada370-5.2_2.0.2841-7.spk
http://jadahl.dscloud.me/sspks/packages ... 2841-7.spk
syno do not accept this packages
Reguard apepannetje
jumbotroll
apepannetje wrote:Hello,
Reguard apepannetje
Try this :-)
http://jadahl.dscloud.me/sspks/?arch=88f6282
http://jadahl.dscloud.me/sspks/ DS212+ use arch=88f6282.
Old versions is deleted!
Jumbotroll
Last edited by jumbotroll on Saturday 05 September 2015 23:04, edited 3 times in total.
Jumbotroll
apepannetje
Thanks Jumbotroll for te fast reaction.
I will try it to morrow.
Regards apepannetje
jumbotroll
@G3rard
@mvveelen
Here you can test custom styles folder restore function.
Create folder /www/style/custom-1 to /www/style/custom-3
Max 3 folders, and the name "custom-1" are case sensitive!
The content of these folders will be restored when updating.
http://jadahl.dscloud.me/sspks/index.php?fulllist=true
Jumbotroll
Last edited by jumbotroll on Monday 07 September 2015 23:44, edited 1 time in total.
Jumbotroll
mvveelen
Post by mvveelen »
I renamed the custom-template to custom-1 and updated. The custom-1 folder still existed after updating, so this works :D ! Thanks Jumbotroll !
jumbotroll
mvveelen wrote:I renamed the custom-template to custom-1 and updated. The custom-1 folder still existed after updating, so this works :D ! Thanks Jumbotroll !
Nice 8-)
Jumbotroll
Jumbotroll
G3rard
Post by G3rard »
@jumbotroll, thanks for implementing it this way! Will update my version next weekend when I am back from my holiday .
ThinkPad
Post by ThinkPad »
Seems to work fine, solution works as you explained.
Bit more difficult to see what theme is installed by looking only at filename, but there is only one custom theme needed, so shouldn't be that hard. Just kidding ;)
jumbotroll
ThinkPad wrote:Seems to work fine, solution works as you explained.
Nice Theme ThinkPad :)
I have added the www/styles/ThinkTheme to backup restore in domoticz_armada370-5.2_2.0.2970-7.spk.
If www/styles/ThinkTheme are present it will backup and restore the theme.
Jumbotroll
Jumbotroll
ThinkPad
Post by ThinkPad »
Hahaha great! But i will stick to the general solution ('custom-1') you made, otherwise everyone will come ask you if you can create an exception for their theme.
And i now have included the name of my theme on the bottom of the webinterface of Domoticz, so not a problem anymore :)
amz4u2nv
Post by amz4u2nv »
Hi jumbotroll,
Just wanted to know how can I tell what version is the Synology package based on -
I am interested in implementing some smoke alarms to domoticz, and wanted to know if the newest synology package has the following in it -
- Implemented: MySensors added support for S_SMOKE/S_DIMMER
- Implemented: RFLink SmokeDetector support
Thanks for a great package by the way.. love it.
