FGSD 002 Fibaro Smoke sending false fire alert in Beta
- gizmocuz
Re: FGSD 002 Fibaro Smoke sending false fire alert in Beta
can you see in the svn log whats changed?
- Domoticz version: V2020.2
That's a shame! It happens when I upgrade to beta coming from stable. Don't know how many steps or versions I skipped, but going back to stable fixed it. I'm afraid to upgrade again...gizmocuz wrote:hmmm nothing changed related to this... so i cant see what the stable version fixes
I moved from a pi2 to Windows, installed a fresh version and removed all zwave nodes. Started all over again and this afternoon it started again....false alerts...what could this be??
- Domoticz version: 2.2336
It looks like the false alarms are reported by domoticz every time the wakeup interval is up, so in my case every 21600 seconds or every 6 hours i get a false alarm......
Yes! Same here, I double checked but all sensors from the smoke sensor wake up and go to the "on" position. Must be something with the xml file I assume? Is there a work around for now? Really love Domoticz, this issue makes it just near perfect
My guess is that the smoke sensor send a periodic test alarm, which is not interpreted correctly by Domoticz.
In your OZW_Log.txt you will see a Alarm report with a event code 3, meaning "Smoke Alarm Test"
Event codes have different meaning depending on the type of alarm.
Knowing this, can it be changed in the next update? Because of this I have all actions/notifications turned off (don't like to be up at 3am with all the lights on and the phones making alarm soundsxs4me wrote:My guess is that the smoke sensor send a periodic test alarm, which is not interpreted correctly by Domoticz.
I'll see if there's a way to turn off the test alarm for now...
Little update:
I'm on V2.2673 right now (Windows), put the notification on with the interval "ignore" box checked and set the interval to 6 hours. So far, knock on wood, no false alarm YET. I hope this is the solution!
After Domoticz starts up it will retrieve the current settings on the device . This will trigger an alarm. Most times it takes two wakup intervals to retrieve all settings. So If your wakup interval is 6 hours, expect an fire alarm anywhere between 0-12 hours after a domoticz restart.
But to be sure, I need to see the OZW_Log.txt. So if you have an false fire alert, please show the relevant parts in OZW_Log.txt.
As soon as I will have a fase alert I'll post it here. The OZW_Log.txt is only 2kb and has like 6 lines in it. Looks like it empties every time?xs4me wrote:But to be sure, I need to see the OZW_Log.txt. So if you have an false fire alert, please show the relevant parts in OZW_Log.txt.
Be sure to enable the debug flag on the controller (setup->hardware->Setup on OpenZWave USB) -> select your controller -> 2. Enable Debug -> set to 1 & apply)
Changing this will restart OZW.
Well...here you go! Just got a false alert...xs4me wrote:But to be sure, I need to see the OZW_Log.txt. So if you have an false fire alert, please show the relevant parts in OZW_Log.txt.
2015-08-07 15:55:46.083 Info, Node010, Received Wakeup Notification from node 10
2015-08-07 15:55:46.083 Info, Node010, Node 10 has been marked as awake
2015-08-07 15:55:46.083 Detail, Node010, Queuing (Controller) Delete All Return Routes
2015-08-07 15:55:46.083 Detail, Node010, Queuing (Controller) Assign Return Route
2015-08-07 15:55:46.083 Detail, Node010, Queuing (Query) Query Stage Complete (Probe1)
2015-08-07 15:55:46.083 Detail, Node010, Notification: Notification - Node Awake
2015-08-07 15:55:46.083 Info, Deleting all return routes from node 10
2015-08-07 15:55:46.083 Detail, Node010, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=10): 0x01, 0x05, 0x00, 0x47, 0x0a, 0x8f, 0x38
2015-08-07 15:55:46.083 Detail, Notification: ControllerComand - Starting
2015-08-07 15:55:46.083 Info, Node010, Sending (Command) message (Callback ID=0x8f, Expected Reply=0x47) - ControllerCommand_DeleteAllReturnRoutess (Node=10):0x01, 0x05, 0x00, 0x47, 0x0a, 0x8f, 0x38
2015-08-07 15:55:46.091 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x47, 0x01, 0xbc
2015-08-07 15:55:46.093 Detail,
2015-08-07 15:55:46.093 Info, Node010, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE - command in progress
2015-08-07 15:55:46.093 Detail, Notification: ControllerCommand - InProgress
2015-08-07 15:55:46.246 Detail, Node010, Received: 0x01, 0x05, 0x00, 0x47, 0x8f, 0x00, 0x32
2015-08-07 15:55:46.248 Detail,
2015-08-07 15:55:46.248 Info, Node010, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE for node 10 - SUCCESS
2015-08-07 15:55:46.248 Detail, Expected callbackId was received
2015-08-07 15:55:46.248 Detail, Expected reply was received
2015-08-07 15:55:46.248 Detail, Message transaction complete
2015-08-07 15:55:46.248 Detail, Node010, Removing current message
2015-08-07 15:55:46.248 Detail, Notification: ControllerCommand - Completed
2015-08-07 15:55:46.248 Info, Assigning return route from node 10 to node 1
2015-08-07 15:55:46.248 Detail, Node010, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=10): 0x01, 0x06, 0x00, 0x46, 0x0a, 0x01, 0x90, 0x24
2015-08-07 15:55:46.248 Detail, Notification: ControllerComand - Starting
2015-08-07 15:55:46.248 Info, Node010, Sending (Command) message (Callback ID=0x90, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=10): 0x01, 0x06, 0x00, 0x46, 0x0a, 0x01, 0x90, 0x24
2015-08-07 15:55:46.263 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
2015-08-07 15:55:46.263 Info, Node010, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
2015-08-07 15:55:46.263 Detail, Notification: ControllerCommand - InProgress
2015-08-07 15:55:47.993 Detail, Node010, Received: 0x01, 0x05, 0x00, 0x46, 0x90, 0x00, 0x2c
2015-08-07 15:55:47.996 Detail,
2015-08-07 15:55:47.996 Info, Node010, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 10 - SUCCESS
2015-08-07 15:55:47.996 Detail, Expected callbackId was received
2015-08-07 15:55:47.996 Detail, Expected reply was received
2015-08-07 15:55:47.996 Detail, Message transaction complete
2015-08-07 15:55:47.996 Detail, Node010, Removing current message
2015-08-07 15:55:47.996 Detail, Notification: ControllerCommand - Completed
2015-08-07 15:55:47.996 Detail, Node010, Query Stage Complete (Probe1)
2015-08-07 15:55:47.996 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2015-08-07 15:55:47.996 Detail, Node010, QueryStage_Associations
2015-08-07 15:55:47.996 Info, Node010, Number of association groups reported for node 10 is 5.
2015-08-07 15:55:47.996 Info, Node010, Get MultiInstanceAssociation for group 1 of node 10
2015-08-07 15:55:47.996 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x01, 0x25, 0x91, 0xd6
2015-08-07 15:55:47.996 Detail, Node010, Queuing (Query) Query Stage Complete (Associations)
2015-08-07 15:55:47.996 Info, Node010, Sending (Send) message (Callback ID=0x91, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x01, 0x25, 0x91, 0xd6
2015-08-07 15:55:48.006 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.006 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.021 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x91, 0x00, 0x00, 0x02, 0x78
2015-08-07 15:55:48.023 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x91 received (expected 0x91)
2015-08-07 15:55:48.023 Info, Node010, Request RTT 27 Average Request RTT 27
2015-08-07 15:55:48.023 Detail, Expected callbackId was received
2015-08-07 15:55:48.033 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x8e, 0x03, 0x01, 0x01, 0x00, 0x01, 0x77
2015-08-07 15:55:48.033 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.036 Info, Node010, Received Multi Instance Association report from node 10, group 1
2015-08-07 15:55:48.036 Info, Node010, The group contains:
2015-08-07 15:55:48.036 Info, Node010, Node 1
2015-08-07 15:55:48.036 Info, Node010, Get MultiInstanceAssociation for group 2 of node 10
2015-08-07 15:55:48.036 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x02, 0x25, 0x92, 0xd6
2015-08-07 15:55:48.036 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.036 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.036 Detail, Node010, Removing current message
2015-08-07 15:55:48.036 Info, Node010, Sending (Send) message (Callback ID=0x92, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x02, 0x25, 0x92, 0xd6
2015-08-07 15:55:48.046 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.046 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.061 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x92, 0x00, 0x00, 0x02, 0x7b
2015-08-07 15:55:48.061 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x92 received (expected 0x92)
2015-08-07 15:55:48.061 Info, Node010, Request RTT 25 Average Request RTT 26
2015-08-07 15:55:48.061 Detail, Expected callbackId was received
2015-08-07 15:55:48.071 Detail, Node010, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0a, 0x05, 0x8e, 0x03, 0x02, 0x0a, 0x00, 0x7a
2015-08-07 15:55:48.073 Detail,
2015-08-07 15:55:48.073 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.073 Info, Node010, Received Multi Instance Association report from node 10, group 2
2015-08-07 15:55:48.073 Info, Node010, The group contains:
2015-08-07 15:55:48.073 Info, Node010, Get MultiInstanceAssociation for group 3 of node 10
2015-08-07 15:55:48.073 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x03, 0x25, 0x93, 0xd6
2015-08-07 15:55:48.073 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.073 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.073 Detail, Node010, Removing current message
2015-08-07 15:55:48.073 Detail, Node010, Notification: Group
2015-08-07 15:55:48.073 Info, Node010, Sending (Send) message (Callback ID=0x93, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x03, 0x25, 0x93, 0xd6
2015-08-07 15:55:48.083 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.083 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.098 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x93, 0x00, 0x00, 0x02, 0x7a
2015-08-07 15:55:48.101 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x93 received (expected 0x93)
2015-08-07 15:55:48.101 Info, Node010, Request RTT 27 Average Request RTT 26
2015-08-07 15:55:48.101 Detail, Expected callbackId was received
2015-08-07 15:55:48.111 Detail, Node010, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0a, 0x05, 0x8e, 0x03, 0x03, 0x0a, 0x00, 0x7b
2015-08-07 15:55:48.111 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.111 Info, Node010, Received Multi Instance Association report from node 10, group 3
2015-08-07 15:55:48.111 Info, Node010, The group contains:
2015-08-07 15:55:48.111 Info, Node010, Get MultiInstanceAssociation for group 4 of node 10
2015-08-07 15:55:48.113 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x04, 0x25, 0x94, 0xd6
2015-08-07 15:55:48.113 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.113 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.113 Detail, Node010, Removing current message
2015-08-07 15:55:48.113 Detail, Node010, Notification: Group
2015-08-07 15:55:48.113 Info, Node010, Sending (Send) message (Callback ID=0x94, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x04, 0x25, 0x94, 0xd6
2015-08-07 15:55:48.121 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.123 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.138 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x94, 0x00, 0x00, 0x02, 0x7d
2015-08-07 15:55:48.138 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x94 received (expected 0x94)
2015-08-07 15:55:48.138 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:48.138 Detail, Expected callbackId was received
2015-08-07 15:55:48.151 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x8e, 0x03, 0x04, 0x0a, 0x00, 0x01, 0x79
2015-08-07 15:55:48.151 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.151 Info, Node010, Received Multi Instance Association report from node 10, group 4
2015-08-07 15:55:48.151 Info, Node010, The group contains:
2015-08-07 15:55:48.151 Info, Node010, Node 1
2015-08-07 15:55:48.151 Info, Node010, Get MultiInstanceAssociation for group 5 of node 10
2015-08-07 15:55:48.151 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x05, 0x25, 0x95, 0xd6
2015-08-07 15:55:48.151 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.151 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.151 Detail, Node010, Removing current message
2015-08-07 15:55:48.151 Info, Node010, Sending (Send) message (Callback ID=0x95, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x05, 0x25, 0x95, 0xd6
2015-08-07 15:55:48.161 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.161 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.176 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x95, 0x00, 0x00, 0x02, 0x7c
2015-08-07 15:55:48.178 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x95 received (expected 0x95)
2015-08-07 15:55:48.178 Info, Node010, Request RTT 27 Average Request RTT 26
2015-08-07 15:55:48.178 Detail, Expected callbackId was received
2015-08-07 15:55:48.188 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x8e, 0x03, 0x05, 0x0a, 0x00, 0x01, 0x78
2015-08-07 15:55:48.188 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.191 Info, Node010, Received Multi Instance Association report from node 10, group 5
2015-08-07 15:55:48.191 Info, Node010, The group contains:
2015-08-07 15:55:48.191 Info, Node010, Node 1
2015-08-07 15:55:48.191 Info, Node010, Querying associations for node 10 is complete.
2015-08-07 15:55:48.191 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.191 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.191 Detail, Node010, Removing current message
2015-08-07 15:55:48.191 Detail, Node010, Query Stage Complete (Associations)
2015-08-07 15:55:48.191 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
2015-08-07 15:55:48.191 Detail, Node010, QueryStage_Neighbors
2015-08-07 15:55:48.191 Detail, Requesting routing info (neighbor list) for Node 10
2015-08-07 15:55:48.191 Detail, Node010, Queuing (Command) Get Routing Info (Node=10): 0x01, 0x07, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x03, 0x71
2015-08-07 15:55:48.191 Detail, Node010, Queuing (Query) Query Stage Complete (Neighbors)
2015-08-07 15:55:48.191 Info, Node010, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=10): 0x01, 0x07, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x03, 0x71
2015-08-07 15:55:48.196 Detail, Node010, Received: 0x01, 0x20, 0x01, 0x80, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x59
2015-08-07 15:55:48.198 Detail,
2015-08-07 15:55:48.198 Info, Node010, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2015-08-07 15:55:48.198 Info, Node010, Neighbors of this node are:
2015-08-07 15:55:48.198 Info, Node010, Node 1
2015-08-07 15:55:48.198 Info, Node010, Node 2
2015-08-07 15:55:48.198 Info, Node010, Node 3
2015-08-07 15:55:48.198 Detail, Expected reply was received
2015-08-07 15:55:48.198 Detail, Message transaction complete
2015-08-07 15:55:48.198 Detail, Node010, Removing current message
2015-08-07 15:55:48.198 Detail, Node010, Query Stage Complete (Neighbors)
2015-08-07 15:55:48.198 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2015-08-07 15:55:48.198 Detail, Node010, QueryStage_Session
2015-08-07 15:55:48.198 Detail, Node010, Queuing (Query) PowerlevelCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x73, 0x02, 0x25, 0x96, 0x2f
2015-08-07 15:55:48.198 Detail, Node010, Queuing (Query) WakeUpCmd_IntervalGet (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x84, 0x05, 0x25, 0x97, 0xde
2015-08-07 15:55:48.198 Detail, Node010, Queuing (Query) Query Stage Complete (Session)
2015-08-07 15:55:48.198 Info, Node010, Sending (Query) message (Callback ID=0x96, Expected Reply=0x04) - PowerlevelCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x73, 0x02, 0x25, 0x96, 0x2f
2015-08-07 15:55:48.208 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.208 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.223 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x96, 0x00, 0x00, 0x02, 0x7f
2015-08-07 15:55:48.226 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x96 received (expected 0x96)
2015-08-07 15:55:48.226 Info, Node010, Request RTT 27 Average Request RTT 26
2015-08-07 15:55:48.226 Detail, Expected callbackId was received
2015-08-07 15:55:48.236 Detail, Node010, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x0a, 0x04, 0x73, 0x03, 0x00, 0x00, 0x8f
2015-08-07 15:55:48.236 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.236 Info, Node010, Received a PowerLevel report: PowerLevel=Normal, Timeout=0
2015-08-07 15:55:48.236 Detail, Node010, Initial read of value
2015-08-07 15:55:48.236 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.236 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.236 Detail, Node010, Removing current message
2015-08-07 15:55:48.236 Detail, Node010, Notification: ValueChanged
2015-08-07 15:55:48.238 Detail, Node010, Notification: ValueChanged
2015-08-07 15:55:48.238 Info, Node010, Sending (Query) message (Callback ID=0x97, Expected Reply=0x04) - WakeUpCmd_IntervalGet (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x84, 0x05, 0x25, 0x97, 0xde
2015-08-07 15:55:48.246 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.248 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.263 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x97, 0x00, 0x00, 0x02, 0x7e
2015-08-07 15:55:48.263 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x97 received (expected 0x97)
2015-08-07 15:55:48.263 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:48.263 Detail, Expected callbackId was received
2015-08-07 15:55:48.273 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x84, 0x06, 0x00, 0x54, 0x60, 0x01, 0x4c
2015-08-07 15:55:48.276 Detail,
2015-08-07 15:55:48.276 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.276 Info, Node010, Received Wakeup Interval report from node 10: Interval=21600, Target Node=1
2015-08-07 15:55:48.276 Detail, Node010, Initial read of value
2015-08-07 15:55:48.276 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.276 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.276 Detail, Node010, Removing current message
2015-08-07 15:55:48.276 Detail, Node010, Notification: ValueChanged
2015-08-07 15:55:48.276 Detail, Node010, Query Stage Complete (Session)
2015-08-07 15:55:48.276 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2015-08-07 15:55:48.276 Detail, Node010, QueryStage_Dynamic
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) BasicCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x20, 0x02, 0x25, 0x98, 0x72
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x30, 0x02, 0x25, 0x99, 0x63
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorMultilevelCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x31, 0x04, 0x01, 0x25, 0x9a, 0x64
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x01, 0x01, 0x25, 0x9b, 0x24
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x04, 0x01, 0x25, 0x9c, 0x26
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x07, 0x01, 0x25, 0x9d, 0x24
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x08, 0x01, 0x25, 0x9e, 0x28
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x09, 0x01, 0x25, 0x9f, 0x28
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) BatteryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x80, 0x02, 0x25, 0xa0, 0xea
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorAlarmCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x9c, 0x01, 0x00, 0x25, 0xa1, 0xf6
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorAlarmCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x9c, 0x01, 0x01, 0x25, 0xa2, 0xf4
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorAlarmCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x9c, 0x01, 0x04, 0x25, 0xa3, 0xf0
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Query) Query Stage Complete (Dynamic)
2015-08-07 15:55:48.278 Detail,
2015-08-07 15:55:48.278 Info, Node010, Sending (Send) message (Callback ID=0x98, Expected Reply=0x04) - BasicCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x20, 0x02, 0x25, 0x98, 0x72
2015-08-07 15:55:48.286 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.288 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.303 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x98, 0x00, 0x00, 0x02, 0x71
2015-08-07 15:55:48.303 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x98 received (expected 0x98)
2015-08-07 15:55:48.303 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:48.303 Detail, Expected callbackId was received
2015-08-07 15:55:48.313 Detail, Node010, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0a, 0x03, 0x20, 0x03, 0x00, 0xd8
2015-08-07 15:55:48.313 Info, Node010, Response RTT 35 Average Response RTT 36
2015-08-07 15:55:48.313 Info, Node010, Received Basic report from node 10: level=0
2015-08-07 15:55:48.316 Detail, Node010, Initial read of value
2015-08-07 15:55:48.316 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.316 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.316 Detail, Node010, Removing current message
2015-08-07 15:55:48.316 Detail, Node010, Notification: ValueChanged
2015-08-07 15:55:48.316 Info, Node010, Sending (Send) message (Callback ID=0x99, Expected Reply=0x04) - SensorBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x30, 0x02, 0x25, 0x99, 0x63
2015-08-07 15:55:48.323 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.326 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.341 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x99, 0x00, 0x00, 0x02, 0x70
2015-08-07 15:55:48.341 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x99 received (expected 0x99)
2015-08-07 15:55:48.341 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:48.341 Detail, Expected callbackId was received
2015-08-07 15:55:57.601 Detail, Node004, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x04, 0x03, 0x30, 0x03, 0x00, 0xc6
2015-08-07 15:55:57.601 Info, Node004, Received SensorBinary report: Sensor:198 State=Off
2015-08-07 15:55:57.601 Detail, Node004, Refreshed Value: old value=true, new value=false, type=bool
2015-08-07 15:55:57.601 Detail, Node004, Changes to this value are not verified
2015-08-07 15:55:57.601 Detail, Node004, Notification: ValueChanged
2015-08-07 15:55:57.663 Detail, Node004, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x04, 0x03, 0x20, 0x01, 0x00, 0xd4
2015-08-07 15:55:57.663 Info, Node004, Received Basic set from node 4: level=0. Treating it as a Basic report.
2015-08-07 15:55:58.316 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2015-08-07 15:55:58.316 Detail, Node010, Removing current message
2015-08-07 15:55:58.316 Detail, Node010, Notification: Notification - TimeOut
2015-08-07 15:55:58.316 Info, Node010, Sending (Send) message (Callback ID=0x9a, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x31, 0x04, 0x01, 0x25, 0x9a, 0x64
2015-08-07 15:55:58.323 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:58.326 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:58.341 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x9a, 0x00, 0x00, 0x02, 0x73
2015-08-07 15:55:58.341 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x9a received (expected 0x9a)
2015-08-07 15:55:58.341 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:58.341 Detail, Expected callbackId was received
2015-08-07 15:56:05.823 Detail, Node011, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0b, 0x06, 0x31, 0x05, 0x01, 0x22, 0x01, 0x0c, 0xe0
2015-08-07 15:56:05.826 Detail,
2015-08-07 15:56:05.826 Info, Node011, Received SensorMultiLevel report from node 11, instance 1, Temperature: value=26.8C
2015-08-07 15:56:05.826 Detail, Node011, Refreshed Value: old value=26.8, new value=26.8, type=string
2015-08-07 15:56:05.826 Detail, Node011, Changes to this value are not verified
2015-08-07 15:56:05.826 Detail, Node011, Notification: ValueChanged
2015-08-07 15:56:08.316 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2015-08-07 15:56:08.316 Detail, Node010, Removing current message
2015-08-07 15:56:08.316 Detail, Node010, Notification: Notification - TimeOut
2015-08-07 15:56:08.316 Info, Node010, Sending (Send) message (Callback ID=0x9b, Expected Reply=0x04) - AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x01, 0x01, 0x25, 0x9b, 0x24
2015-08-07 15:56:08.326 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:56:08.326 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:56:08.341 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x9b, 0x00, 0x00, 0x02, 0x72
2015-08-07 15:56:08.341 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x9b received (expected 0x9b)
I was expecting something like this:
Where your fire alert time corresponds with the time stamp on the ValueChanged log line. Is the " Received Alarm report" also present in your case?
2015-08-07 17:55:25.874 Info, Node044, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Smoke event:254, status=255
2015-08-07 17:55:25.874 Detail, Node044, Initial read of value
2015-08-07 17:55:25.874 Detail, Node044, Expected reply and command class was received
2015-08-07 17:55:25.874 Detail, Node044, Message transaction complete
2015-08-07 17:55:25.874 Detail, Node044, Removing current message
2015-08-07 17:55:25.875 Detail, Node044, Notification: ValueChanged
2015-08-07 17:55:26.404 Detail, Node044, Notification: ValueChanged
2015-08-07 17:55:26.919 Detail, Node044, Notification: ValueChanged
@xs4me
I got this:
2015-08-07 17:37:27.922 Info, Node015, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Smoke event:254, status=255
2015-08-07 17:37:27.922 Detail, Node015, Initial read of value
2015-08-07 17:37:27.922 Detail, Node015, Expected reply and command class was received
2015-08-07 17:37:27.922 Detail, Node015, Message transaction complete
2015-08-07 17:37:27.922 Detail, Node015, Removing current message
2015-08-07 17:37:27.924 Detail, Node015, Notification: ValueChanged
2015-08-07 17:37:27.947 Detail, Node015, Notification: ValueChanged
2015-08-07 17:37:27.969 Detail, Node015, Notification: ValueChanged
2015-08-07 17:37:27.972 Detail, Node015, Notification: ValueChanged
2015-08-07 17:37:28.507 Detail,
2015-08-07 17:37:28.507 Info, Node015, Sending (Send) message (Callback ID=0xc9, Expected Reply=0x04) - AlarmCmd_Get (Node=15): 0x01, 0x0c, 0x00, 0x13, 0x0f, 0x05, 0x71, 0x04, 0x00, 0x04, 0x01, 0x25, 0xc9, 0x76
2015-08-07 17:37:28.517 Detail, Node015, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 17:37:28.517 Detail, Node015, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 17:37:28.532 Detail, Node015, Received: 0x01, 0x07, 0x00, 0x13, 0xc9, 0x00, 0x00, 0x02, 0x20
2015-08-07 17:37:28.534 Detail, Node015, ZW_SEND_DATA Request with callback ID 0xc9 received (expected 0xc9)
2015-08-07 17:37:28.534 Info, Node015, Request RTT 27 Average Request RTT 26
2015-08-07 17:37:28.534 Detail, Expected callbackId was received
2015-08-07 17:37:28.612 Detail, Node015, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x0f, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x04, 0xfe, 0x00, 0x83
2015-08-07 17:37:28.612 Info, Node015, Response RTT 105 Average Response RTT 70
2015-08-07 17:37:28.612 Info, Node015, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Heat event:254, status=255
2015-08-07
Looks the same from another alert I got tonight.
I got this:
2015-08-07
Ok, so this one I can explain, as I did earlier:
I have submitted a patch for the case where the alarm responds with an alarm report with event:254, like this case. Can you relate all your false fire alerts to a Domoticz restart? ie within 12 hours of a domoticz restart? or have you other occurrences? If so do you have the log?xs4me wrote:After Domoticz starts up it will retrieve the current settings on the device . This will trigger an alarm. Most times it takes two wakup intervals to retrieve all settings. So If your wakup interval is 6 hours, expect an fire alarm anywhere between 0-12 hours after a domoticz restart.
I haven't had any false alerts till you asked me to turn on the logging LOL. I'm waiting right now for my third smoke detector to check in and give a false alarm. After this it won't happen again, as it didn't for 2 days (the last update/restart). I'll keep on monitoring and keep checking the log files. Thanks so far and hopefully it will be fixed in the next update.
- Egregius
- Domoticz version: v2024.7
My patch has been merged. So false fire alerts after a Domoticz restart should be gone.
- Egregius
OK, updated to 2.2703. Now: wait, grab a Ricard and see...
Awesome guys!! I'll wait for 12 hours and re-activate de blockly scripts! @xs4me; thanks!!
