FGSD 002 Fibaro Smoke sending false fire alert in Beta
gizmocuz
Re: FGSD 002 Fibaro Smoke sending false fire alert in Beta
Post by gizmocuz »
can you see in the svn log whats changed?
dressie
Domoticz version: V2020.2
Post by dressie »
gizmocuz wrote:hmmm nothing changed related to this... so i cant see what the stable version fixes
That's a shame! It happens when I upgrade to beta coming from stable. Don't know how many steps or versions I skipped, but going back to stable fixed it. I'm afraid to upgrade again...
dressie
Post by dressie »
I moved from a pi2 to Windows, installed a fresh version and removed all zwave nodes. Started all over again and this afternoon it started again....false alerts...what could this be??
Jantje1972
Domoticz version: 2.2336
Post by Jantje1972 »
It looks like the false alarms are reported by domoticz every time the wakeup interval is up, so in my case every 21600 seconds or every 6 hours i get a false alarm......
dressie
Post by dressie »
Yes! Same here, I double checked but all sensors from the smoke sensor wake up and go to the "on" position. Must be something with the xml file I assume? Is there a work around for now? Really love Domoticz, this issue makes it just near perfect :)
xs4me
Post by xs4me »
My guess is that the smoke sensor send a periodic test alarm, which is not interpreted correctly by Domoticz.
In your OZW_Log.txt you will see a Alarm report with a event code 3, meaning "Smoke Alarm Test"
Event codes have different meaning depending on the type of alarm.
dressie
Post by dressie »
xs4me wrote:My guess is that the smoke sensor send a periodic test alarm, which is not interpreted correctly by Domoticz.
Knowing this, can it be changed in the next update? Because of this I have all actions/notifications turned off (don't like to be up at 3am with all the lights on and the phones making alarm sounds :o ).
I'll see if there's a way to turn off the test alarm for now...
dressie
Post by dressie »
Little update:
I'm on V2.2673 right now (Windows), put the notification on with the interval "ignore" box checked and set the interval to 6 hours. So far, knock on wood, no false alarm YET. I hope this is the solution!
xs4me
Post by xs4me »
After Domoticz starts up it will retrieve the current settings on the device . This will trigger an alarm. Most times it takes two wakup intervals to retrieve all settings. So If your wakup interval is 6 hours, expect an fire alarm anywhere between 0-12 hours after a domoticz restart.
But to be sure, I need to see the OZW_Log.txt. So if you have an false fire alert, please show the relevant parts in OZW_Log.txt.
dressie
Post by dressie »
xs4me wrote:But to be sure, I need to see the OZW_Log.txt. So if you have an false fire alert, please show the relevant parts in OZW_Log.txt.
As soon as I will have a fase alert I'll post it here. The OZW_Log.txt is only 2kb and has like 6 lines in it. Looks like it empties every time?
xs4me
Post by xs4me »
Be sure to enable the debug flag on the controller (setup->hardware->Setup on OpenZWave USB) -> select your controller -> 2. Enable Debug -> set to 1 & apply)
Changing this will restart OZW.
dressie
Post by dressie »
Well...here you go! Just got a false alert...
2015-08-07 15:55:46.083 Info, Node010, Received Wakeup Notification from node 10
2015-08-07 15:55:46.083 Info, Node010, Node 10 has been marked as awake
2015-08-07 15:55:46.083 Detail, Node010, Queuing (Controller) Delete All Return Routes
2015-08-07 15:55:46.083 Detail, Node010, Queuing (Controller) Assign Return Route
2015-08-07 15:55:46.083 Detail, Node010, Queuing (Query) Query Stage Complete (Probe1)
2015-08-07 15:55:46.083 Detail, Node010, Notification: Notification - Node Awake
2015-08-07 15:55:46.083 Info, Deleting all return routes from node 10
2015-08-07 15:55:46.083 Detail, Node010, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=10): 0x01, 0x05, 0x00, 0x47, 0x0a, 0x8f, 0x38
2015-08-07 15:55:46.083 Detail, Notification: ControllerComand - Starting
2015-08-07 15:55:46.083 Info, Node010, Sending (Command) message (Callback ID=0x8f, Expected Reply=0x47) - ControllerCommand_DeleteAllReturnRoutess (Node=10):0x01, 0x05, 0x00, 0x47, 0x0a, 0x8f, 0x38
2015-08-07 15:55:46.091 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x47, 0x01, 0xbc
2015-08-07 15:55:46.093 Detail,
2015-08-07 15:55:46.093 Info, Node010, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE - command in progress
2015-08-07 15:55:46.093 Detail, Notification: ControllerCommand - InProgress
2015-08-07 15:55:46.246 Detail, Node010, Received: 0x01, 0x05, 0x00, 0x47, 0x8f, 0x00, 0x32
2015-08-07 15:55:46.248 Detail,
2015-08-07 15:55:46.248 Info, Node010, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE for node 10 - SUCCESS
2015-08-07 15:55:46.248 Detail, Expected callbackId was received
2015-08-07 15:55:46.248 Detail, Expected reply was received
2015-08-07 15:55:46.248 Detail, Message transaction complete
2015-08-07 15:55:46.248 Detail, Node010, Removing current message
2015-08-07 15:55:46.248 Detail, Notification: ControllerCommand - Completed
2015-08-07 15:55:46.248 Info, Assigning return route from node 10 to node 1
2015-08-07 15:55:46.248 Detail, Node010, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=10): 0x01, 0x06, 0x00, 0x46, 0x0a, 0x01, 0x90, 0x24
2015-08-07 15:55:46.248 Detail, Notification: ControllerComand - Starting
2015-08-07 15:55:46.248 Info, Node010, Sending (Command) message (Callback ID=0x90, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=10): 0x01, 0x06, 0x00, 0x46, 0x0a, 0x01, 0x90, 0x24
2015-08-07 15:55:46.263 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
2015-08-07 15:55:46.263 Info, Node010, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
2015-08-07 15:55:46.263 Detail, Notification: ControllerCommand - InProgress
2015-08-07 15:55:47.993 Detail, Node010, Received: 0x01, 0x05, 0x00, 0x46, 0x90, 0x00, 0x2c
2015-08-07 15:55:47.996 Detail,
2015-08-07 15:55:47.996 Info, Node010, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 10 - SUCCESS
2015-08-07 15:55:47.996 Detail, Expected callbackId was received
2015-08-07 15:55:47.996 Detail, Expected reply was received
2015-08-07 15:55:47.996 Detail, Message transaction complete
2015-08-07 15:55:47.996 Detail, Node010, Removing current message
2015-08-07 15:55:47.996 Detail, Notification: ControllerCommand - Completed
2015-08-07 15:55:47.996 Detail, Node010, Query Stage Complete (Probe1)
2015-08-07 15:55:47.996 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2015-08-07 15:55:47.996 Detail, Node010, QueryStage_Associations
2015-08-07 15:55:47.996 Info, Node010, Number of association groups reported for node 10 is 5.
2015-08-07 15:55:47.996 Info, Node010, Get MultiInstanceAssociation for group 1 of node 10
2015-08-07 15:55:47.996 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x01, 0x25, 0x91, 0xd6
2015-08-07 15:55:47.996 Detail, Node010, Queuing (Query) Query Stage Complete (Associations)
2015-08-07 15:55:47.996 Info, Node010, Sending (Send) message (Callback ID=0x91, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x01, 0x25, 0x91, 0xd6
2015-08-07 15:55:48.006 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.006 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.021 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x91, 0x00, 0x00, 0x02, 0x78
2015-08-07 15:55:48.023 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x91 received (expected 0x91)
2015-08-07 15:55:48.023 Info, Node010, Request RTT 27 Average Request RTT 27
2015-08-07 15:55:48.023 Detail, Expected callbackId was received
2015-08-07 15:55:48.033 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x8e, 0x03, 0x01, 0x01, 0x00, 0x01, 0x77
2015-08-07 15:55:48.033 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.036 Info, Node010, Received Multi Instance Association report from node 10, group 1
2015-08-07 15:55:48.036 Info, Node010, The group contains:
2015-08-07 15:55:48.036 Info, Node010, Node 1
2015-08-07 15:55:48.036 Info, Node010, Get MultiInstanceAssociation for group 2 of node 10
2015-08-07 15:55:48.036 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x02, 0x25, 0x92, 0xd6
2015-08-07 15:55:48.036 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.036 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.036 Detail, Node010, Removing current message
2015-08-07 15:55:48.036 Info, Node010, Sending (Send) message (Callback ID=0x92, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x02, 0x25, 0x92, 0xd6
2015-08-07 15:55:48.046 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.046 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.061 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x92, 0x00, 0x00, 0x02, 0x7b
2015-08-07 15:55:48.061 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x92 received (expected 0x92)
2015-08-07 15:55:48.061 Info, Node010, Request RTT 25 Average Request RTT 26
2015-08-07 15:55:48.061 Detail, Expected callbackId was received
2015-08-07 15:55:48.071 Detail, Node010, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0a, 0x05, 0x8e, 0x03, 0x02, 0x0a, 0x00, 0x7a
2015-08-07 15:55:48.073 Detail,
2015-08-07 15:55:48.073 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.073 Info, Node010, Received Multi Instance Association report from node 10, group 2
2015-08-07 15:55:48.073 Info, Node010, The group contains:
2015-08-07 15:55:48.073 Info, Node010, Get MultiInstanceAssociation for group 3 of node 10
2015-08-07 15:55:48.073 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x03, 0x25, 0x93, 0xd6
2015-08-07 15:55:48.073 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.073 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.073 Detail, Node010, Removing current message
2015-08-07 15:55:48.073 Detail, Node010, Notification: Group
2015-08-07 15:55:48.073 Info, Node010, Sending (Send) message (Callback ID=0x93, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x03, 0x25, 0x93, 0xd6
2015-08-07 15:55:48.083 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.083 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.098 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x93, 0x00, 0x00, 0x02, 0x7a
2015-08-07 15:55:48.101 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x93 received (expected 0x93)
2015-08-07 15:55:48.101 Info, Node010, Request RTT 27 Average Request RTT 26
2015-08-07 15:55:48.101 Detail, Expected callbackId was received
2015-08-07 15:55:48.111 Detail, Node010, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0a, 0x05, 0x8e, 0x03, 0x03, 0x0a, 0x00, 0x7b
2015-08-07 15:55:48.111 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.111 Info, Node010, Received Multi Instance Association report from node 10, group 3
2015-08-07 15:55:48.111 Info, Node010, The group contains:
2015-08-07 15:55:48.111 Info, Node010, Get MultiInstanceAssociation for group 4 of node 10
2015-08-07 15:55:48.113 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x04, 0x25, 0x94, 0xd6
2015-08-07 15:55:48.113 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.113 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.113 Detail, Node010, Removing current message
2015-08-07 15:55:48.113 Detail, Node010, Notification: Group
2015-08-07 15:55:48.113 Info, Node010, Sending (Send) message (Callback ID=0x94, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x04, 0x25, 0x94, 0xd6
2015-08-07 15:55:48.121 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.123 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.138 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x94, 0x00, 0x00, 0x02, 0x7d
2015-08-07 15:55:48.138 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x94 received (expected 0x94)
2015-08-07 15:55:48.138 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:48.138 Detail, Expected callbackId was received
2015-08-07 15:55:48.151 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x8e, 0x03, 0x04, 0x0a, 0x00, 0x01, 0x79
2015-08-07 15:55:48.151 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.151 Info, Node010, Received Multi Instance Association report from node 10, group 4
2015-08-07 15:55:48.151 Info, Node010, The group contains:
2015-08-07 15:55:48.151 Info, Node010, Node 1
2015-08-07 15:55:48.151 Info, Node010, Get MultiInstanceAssociation for group 5 of node 10
2015-08-07 15:55:48.151 Detail, Node010, Queuing (Send) MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x05, 0x25, 0x95, 0xd6
2015-08-07 15:55:48.151 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.151 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.151 Detail, Node010, Removing current message
2015-08-07 15:55:48.151 Info, Node010, Sending (Send) message (Callback ID=0x95, Expected Reply=0x04) - MultiInstanceAssociationCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x8e, 0x02, 0x05, 0x25, 0x95, 0xd6
2015-08-07 15:55:48.161 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.161 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.176 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x95, 0x00, 0x00, 0x02, 0x7c
2015-08-07 15:55:48.178 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x95 received (expected 0x95)
2015-08-07 15:55:48.178 Info, Node010, Request RTT 27 Average Request RTT 26
2015-08-07 15:55:48.178 Detail, Expected callbackId was received
2015-08-07 15:55:48.188 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x8e, 0x03, 0x05, 0x0a, 0x00, 0x01, 0x78
2015-08-07 15:55:48.188 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.191 Info, Node010, Received Multi Instance Association report from node 10, group 5
2015-08-07 15:55:48.191 Info, Node010, The group contains:
2015-08-07 15:55:48.191 Info, Node010, Node 1
2015-08-07 15:55:48.191 Info, Node010, Querying associations for node 10 is complete.
2015-08-07 15:55:48.191 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.191 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.191 Detail, Node010, Removing current message
2015-08-07 15:55:48.191 Detail, Node010, Query Stage Complete (Associations)
2015-08-07 15:55:48.191 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
2015-08-07 15:55:48.191 Detail, Node010, QueryStage_Neighbors
2015-08-07 15:55:48.191 Detail, Requesting routing info (neighbor list) for Node 10
2015-08-07 15:55:48.191 Detail, Node010, Queuing (Command) Get Routing Info (Node=10): 0x01, 0x07, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x03, 0x71
2015-08-07 15:55:48.191 Detail, Node010, Queuing (Query) Query Stage Complete (Neighbors)
2015-08-07 15:55:48.191 Info, Node010, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=10): 0x01, 0x07, 0x00, 0x80, 0x0a, 0x00, 0x00, 0x03, 0x71
2015-08-07 15:55:48.196 Detail, Node010, Received: 0x01, 0x20, 0x01, 0x80, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x59
2015-08-07 15:55:48.198 Detail,
2015-08-07 15:55:48.198 Info, Node010, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2015-08-07 15:55:48.198 Info, Node010, Neighbors of this node are:
2015-08-07 15:55:48.198 Info, Node010, Node 1
2015-08-07 15:55:48.198 Info, Node010, Node 2
2015-08-07 15:55:48.198 Info, Node010, Node 3
2015-08-07 15:55:48.198 Detail, Expected reply was received
2015-08-07 15:55:48.198 Detail, Message transaction complete
2015-08-07 15:55:48.198 Detail, Node010, Removing current message
2015-08-07 15:55:48.198 Detail, Node010, Query Stage Complete (Neighbors)
2015-08-07 15:55:48.198 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2015-08-07 15:55:48.198 Detail, Node010, QueryStage_Session
2015-08-07 15:55:48.198 Detail, Node010, Queuing (Query) PowerlevelCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x73, 0x02, 0x25, 0x96, 0x2f
2015-08-07 15:55:48.198 Detail, Node010, Queuing (Query) WakeUpCmd_IntervalGet (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x84, 0x05, 0x25, 0x97, 0xde
2015-08-07 15:55:48.198 Detail, Node010, Queuing (Query) Query Stage Complete (Session)
2015-08-07 15:55:48.198 Info, Node010, Sending (Query) message (Callback ID=0x96, Expected Reply=0x04) - PowerlevelCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x73, 0x02, 0x25, 0x96, 0x2f
2015-08-07 15:55:48.208 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.208 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.223 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x96, 0x00, 0x00, 0x02, 0x7f
2015-08-07 15:55:48.226 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x96 received (expected 0x96)
2015-08-07 15:55:48.226 Info, Node010, Request RTT 27 Average Request RTT 26
2015-08-07 15:55:48.226 Detail, Expected callbackId was received
2015-08-07 15:55:48.236 Detail, Node010, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x0a, 0x04, 0x73, 0x03, 0x00, 0x00, 0x8f
2015-08-07 15:55:48.236 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.236 Info, Node010, Received a PowerLevel report: PowerLevel=Normal, Timeout=0
2015-08-07 15:55:48.236 Detail, Node010, Initial read of value
2015-08-07 15:55:48.236 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.236 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.236 Detail, Node010, Removing current message
2015-08-07 15:55:48.236 Detail, Node010, Notification: ValueChanged
2015-08-07 15:55:48.238 Detail, Node010, Notification: ValueChanged
2015-08-07 15:55:48.238 Info, Node010, Sending (Query) message (Callback ID=0x97, Expected Reply=0x04) - WakeUpCmd_IntervalGet (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x84, 0x05, 0x25, 0x97, 0xde
2015-08-07 15:55:48.246 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.248 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.263 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x97, 0x00, 0x00, 0x02, 0x7e
2015-08-07 15:55:48.263 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x97 received (expected 0x97)
2015-08-07 15:55:48.263 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:48.263 Detail, Expected callbackId was received
2015-08-07 15:55:48.273 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x84, 0x06, 0x00, 0x54, 0x60, 0x01, 0x4c
2015-08-07 15:55:48.276 Detail,
2015-08-07 15:55:48.276 Info, Node010, Response RTT 37 Average Response RTT 37
2015-08-07 15:55:48.276 Info, Node010, Received Wakeup Interval report from node 10: Interval=21600, Target Node=1
2015-08-07 15:55:48.276 Detail, Node010, Initial read of value
2015-08-07 15:55:48.276 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.276 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.276 Detail, Node010, Removing current message
2015-08-07 15:55:48.276 Detail, Node010, Notification: ValueChanged
2015-08-07 15:55:48.276 Detail, Node010, Query Stage Complete (Session)
2015-08-07 15:55:48.276 Detail, Node010, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2015-08-07 15:55:48.276 Detail, Node010, QueryStage_Dynamic
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) BasicCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x20, 0x02, 0x25, 0x98, 0x72
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x30, 0x02, 0x25, 0x99, 0x63
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorMultilevelCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x31, 0x04, 0x01, 0x25, 0x9a, 0x64
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x01, 0x01, 0x25, 0x9b, 0x24
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x04, 0x01, 0x25, 0x9c, 0x26
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x07, 0x01, 0x25, 0x9d, 0x24
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x08, 0x01, 0x25, 0x9e, 0x28
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x09, 0x01, 0x25, 0x9f, 0x28
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) BatteryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x80, 0x02, 0x25, 0xa0, 0xea
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorAlarmCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x9c, 0x01, 0x00, 0x25, 0xa1, 0xf6
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorAlarmCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x9c, 0x01, 0x01, 0x25, 0xa2, 0xf4
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Send) SensorAlarmCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x9c, 0x01, 0x04, 0x25, 0xa3, 0xf0
2015-08-07 15:55:48.276 Detail, Node010, Queuing (Query) Query Stage Complete (Dynamic)
2015-08-07 15:55:48.278 Detail,
2015-08-07 15:55:48.278 Info, Node010, Sending (Send) message (Callback ID=0x98, Expected Reply=0x04) - BasicCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x20, 0x02, 0x25, 0x98, 0x72
2015-08-07 15:55:48.286 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.288 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.303 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x98, 0x00, 0x00, 0x02, 0x71
2015-08-07 15:55:48.303 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x98 received (expected 0x98)
2015-08-07 15:55:48.303 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:48.303 Detail, Expected callbackId was received
2015-08-07 15:55:48.313 Detail, Node010, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0a, 0x03, 0x20, 0x03, 0x00, 0xd8
2015-08-07 15:55:48.313 Info, Node010, Response RTT 35 Average Response RTT 36
2015-08-07 15:55:48.313 Info, Node010, Received Basic report from node 10: level=0
2015-08-07 15:55:48.316 Detail, Node010, Initial read of value
2015-08-07 15:55:48.316 Detail, Node010, Expected reply and command class was received
2015-08-07 15:55:48.316 Detail, Node010, Message transaction complete
2015-08-07 15:55:48.316 Detail, Node010, Removing current message
2015-08-07 15:55:48.316 Detail, Node010, Notification: ValueChanged
2015-08-07 15:55:48.316 Info, Node010, Sending (Send) message (Callback ID=0x99, Expected Reply=0x04) - SensorBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x30, 0x02, 0x25, 0x99, 0x63
2015-08-07 15:55:48.323 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:48.326 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:48.341 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x99, 0x00, 0x00, 0x02, 0x70
2015-08-07 15:55:48.341 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x99 received (expected 0x99)
2015-08-07 15:55:48.341 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:48.341 Detail, Expected callbackId was received
2015-08-07 15:55:57.601 Detail, Node004, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x04, 0x03, 0x30, 0x03, 0x00, 0xc6
2015-08-07 15:55:57.601 Info, Node004, Received SensorBinary report: Sensor:198 State=Off
2015-08-07 15:55:57.601 Detail, Node004, Refreshed Value: old value=true, new value=false, type=bool
2015-08-07 15:55:57.601 Detail, Node004, Changes to this value are not verified
2015-08-07 15:55:57.601 Detail, Node004, Notification: ValueChanged
2015-08-07 15:55:57.663 Detail, Node004, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x04, 0x03, 0x20, 0x01, 0x00, 0xd4
2015-08-07 15:55:57.663 Info, Node004, Received Basic set from node 4: level=0. Treating it as a Basic report.
2015-08-07 15:55:58.316 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2015-08-07 15:55:58.316 Detail, Node010, Removing current message
2015-08-07 15:55:58.316 Detail, Node010, Notification: Notification - TimeOut
2015-08-07 15:55:58.316 Info, Node010, Sending (Send) message (Callback ID=0x9a, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x31, 0x04, 0x01, 0x25, 0x9a, 0x64
2015-08-07 15:55:58.323 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:55:58.326 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:55:58.341 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x9a, 0x00, 0x00, 0x02, 0x73
2015-08-07 15:55:58.341 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x9a received (expected 0x9a)
2015-08-07 15:55:58.341 Info, Node010, Request RTT 25 Average Request RTT 25
2015-08-07 15:55:58.341 Detail, Expected callbackId was received
2015-08-07 15:56:05.823 Detail, Node011, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0b, 0x06, 0x31, 0x05, 0x01, 0x22, 0x01, 0x0c, 0xe0
2015-08-07 15:56:05.826 Detail,
2015-08-07 15:56:05.826 Info, Node011, Received SensorMultiLevel report from node 11, instance 1, Temperature: value=26.8C
2015-08-07 15:56:05.826 Detail, Node011, Refreshed Value: old value=26.8, new value=26.8, type=string
2015-08-07 15:56:05.826 Detail, Node011, Changes to this value are not verified
2015-08-07 15:56:05.826 Detail, Node011, Notification: ValueChanged
2015-08-07 15:56:08.316 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2015-08-07 15:56:08.316 Detail, Node010, Removing current message
2015-08-07 15:56:08.316 Detail, Node010, Notification: Notification - TimeOut
2015-08-07 15:56:08.316 Info, Node010, Sending (Send) message (Callback ID=0x9b, Expected Reply=0x04) - AlarmCmd_Get (Node=10): 0x01, 0x0c, 0x00, 0x13, 0x0a, 0x05, 0x71, 0x04, 0x00, 0x01, 0x01, 0x25, 0x9b, 0x24
2015-08-07 15:56:08.326 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 15:56:08.326 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 15:56:08.341 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0x9b, 0x00, 0x00, 0x02, 0x72
2015-08-07 15:56:08.341 Detail, Node010, ZW_SEND_DATA Request with callback ID 0x9b received (expected 0x9b)
xs4me
Post by xs4me »
I was expecting something like this:
2015-08-07 17:55:25.874 Info, Node044, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Smoke event:254, status=255
2015-08-07 17:55:25.874 Detail, Node044, Initial read of value
2015-08-07 17:55:25.874 Detail, Node044,   Expected reply and command class was received
2015-08-07 17:55:25.874 Detail, Node044,   Message transaction complete
2015-08-07 17:55:25.874 Detail, Node044, Removing current message
2015-08-07 17:55:25.875 Detail, Node044, Notification: ValueChanged
2015-08-07 17:55:26.404 Detail, Node044, Notification: ValueChanged
2015-08-07 17:55:26.919 Detail, Node044, Notification: ValueChanged
Where your fire alert time corresponds with the time stamp on the ValueChanged log line. Is the " Received Alarm report" also present in your case?
dressie
Post by dressie »
@xs4me
I got this:
2015-08-07 17:37:27.922 Info, Node015, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Smoke event:254, status=255
2015-08-07 17:37:27.922 Detail, Node015, Initial read of value
2015-08-07 17:37:27.922 Detail, Node015, Expected reply and command class was received
2015-08-07 17:37:27.922 Detail, Node015, Message transaction complete
2015-08-07 17:37:27.922 Detail, Node015, Removing current message
2015-08-07 17:37:27.924 Detail, Node015, Notification: ValueChanged
2015-08-07 17:37:27.947 Detail, Node015, Notification: ValueChanged
2015-08-07 17:37:27.969 Detail, Node015, Notification: ValueChanged
2015-08-07 17:37:27.972 Detail, Node015, Notification: ValueChanged
2015-08-07 17:37:28.507 Detail,
2015-08-07 17:37:28.507 Info, Node015, Sending (Send) message (Callback ID=0xc9, Expected Reply=0x04) - AlarmCmd_Get (Node=15): 0x01, 0x0c, 0x00, 0x13, 0x0f, 0x05, 0x71, 0x04, 0x00, 0x04, 0x01, 0x25, 0xc9, 0x76
2015-08-07 17:37:28.517 Detail, Node015, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-08-07 17:37:28.517 Detail, Node015, ZW_SEND_DATA delivered to Z-Wave stack
2015-08-07 17:37:28.532 Detail, Node015, Received: 0x01, 0x07, 0x00, 0x13, 0xc9, 0x00, 0x00, 0x02, 0x20
2015-08-07 17:37:28.534 Detail, Node015, ZW_SEND_DATA Request with callback ID 0xc9 received (expected 0xc9)
2015-08-07 17:37:28.534 Info, Node015, Request RTT 27 Average Request RTT 26
2015-08-07 17:37:28.534 Detail, Expected callbackId was received
2015-08-07 17:37:28.612 Detail, Node015, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x0f, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x04, 0xfe, 0x00, 0x83
2015-08-07 17:37:28.612 Info, Node015, Response RTT 105 Average Response RTT 70
2015-08-07 17:37:28.612 Info, Node015, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Heat event:254, status=255
2015-08-07
Looks the same from another alert I got tonight.
xs4me
Post by xs4me »
Ok, so this one I can explain, as I did earlier:
xs4me wrote:After Domoticz starts up it will retrieve the current settings on the device . This will trigger an alarm. Most times it takes two wakup intervals to retrieve all settings. So If your wakup interval is 6 hours, expect an fire alarm anywhere between 0-12 hours after a domoticz restart.
I have submitted a patch for the case where the alarm responds with an alarm report with event:254, like this case. Can you relate all your false fire alerts to a Domoticz restart? ie within 12 hours of a domoticz restart? or have you other occurrences? If so do you have the log?
dressie
Post by dressie »
I haven't had any false alerts till you asked me to turn on the logging LOL. I'm waiting right now for my third smoke detector to check in and give a false alarm. After this it won't happen again, as it didn't for 2 days (the last update/restart). I'll keep on monitoring and keep checking the log files. Thanks so far and hopefully it will be fixed in the next update.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Can you post the patch here already?
Installed 2 of these yesterday and have the same issue. Luckely there's no sound configured yet for them.
Maybe a little off-topic, but why are their so many devices for just one smoke detector?
xs4me
Post by xs4me »
My patch has been merged. So false fire alerts after a Domoticz restart should be gone.
Egregius
Post by Egregius »
OK, updated to 2.2703. Now: wait, grab a Ricard and see...
dressie
Post by dressie »
Awesome guys!! I'll wait for 12 hours and re-activate de blockly scripts! @xs4me; thanks!!
