#2215 Custom Icons uploader Implemented
Bikey
- Domoticz version: 2020.x
Re: #2215 Custom Icons uploader Implemented
I've just uploaded some icons to Domoticz and followed the instrutions in the Wiki.
Works great except if you follow the Wiki you end up with double listing of the new icons.
You must not do the "Editing icon description file" part.
I already thought that to be redundant because it says to add this line in the file:
<filename without extention>;<iconname in interface>;<icon description>
while that was already also in the icons.txt file that you have to upload together in the ZIP-file with the icons.
Also restarting Domoticz is not necessary.
This all for V2.2326 and higher.
Kroontje
I've opened this topic today; http://www.domoticz.com/forum/viewtopic.php?f=31&t=5904 but is locked because of this topic.
I've running the latest beta version of Domoticz and I'm curious if it's possible, through the web interface, to change the icons off the switch types; dimmers, motion sensors, blinds, etc.. Gizmocuz mentioned in the topic start that it will maybe be possible in the feature, already a date?
Morcegolas
Hi everybody, this is interesting for me, I'm using some text virtual sensors to know the state of my denon receiver, volume and source, and I want to change the icons of them, is it possible to do this or just to ON/OFF switches?
- Text virtual sensors
- denon.jpg (43.14 KiB) Viewed 14672 times
Morcegolas
I think I got the answer :/gizmocuz wrote: ...
Currently only supported for On/Off switches (as it is now), and probably later for other types as well
Wirehead
I've created this for the LG Hombot V3
Please add to the google drive.
- Archive.zip
- (10.44 KiB) Downloaded 577 times
EscApe
- Domoticz version: 2026.3
I have created a few custom icons. Could you please add these to google drive?
- Switch without signaling colors (like red/green) for switches that do not necessarily say anything about the current state of devices/lights. I use this for wall switches that can trigger a scene or dimmer level.
- WAN status icon for anyone who uses their domoticz setup to monitor the WAN connection on the router
- SMS icon. In my case used for a dummy device that triggers a shell script that sends alerts thru sms (using a 3G dongle en gammu-smsd).
- sms.zip
- (9.27 KiB) Downloaded 659 times
- wan.zip
- (11.88 KiB) Downloaded 705 times
- wallswitch.zip
- (5.66 KiB) Downloaded 849 times
Derik
- Domoticz version: BETA
EscApe wrote:Hi,
Please send them to
[email protected] [ then i have them in the archive ]
- jcjames13009
- Domoticz version: 2023.2
Here are 2 icons I created for my project: Pump & Robot for the pool.
Just sent by mail to [email protected] as well to be added to the archive
JC
JC
Mati24
This is an icon for Philips Hue :
- Hue.zip
- Philips Hue icons
- (11.83 KiB) Downloaded 824 times
Bikey
Thanks for the Hue icons.
However, when I uploaded this I only got a question mark instead of the Icon. I had to rename the filenames to lower case and change the icons.txt contents accordingly to make this work. Is that a bug?
Furthermore: I can't change the icon for an actual Philips Hue lamp, as this is a "dimmer". It is only possible to assign an icon to a "switch" via the web interface . How did you change the icon for the Hue lamp?
P.s. according to the Wiki you have to change the icon description file in /home/pi/domoticz/www/ however it also works without doing that. Is that old info?
Bikey
I have created these icons for a scene:
- scene.zip
- (8.57 KiB) Downloaded 508 times
- 1bigwink
This is rally useful thank you. I see that people have created custom icons for various devices (cameras, motion sensors, door contacts etc) - is it possible to use this. Currently I only get the option for a custom icon for On/Off Switches... is it possible to use these on other items that appear on the switches tab as well?
Thanks,
dk
Thanks,
dk
1x RasPi, RFXtrx433e, v5 Aeon ZWave, MD210R Door Contacts, MC335R PIRs, MD326 Siren, 25 x MiLight RGBW Bulb (4 x WiFi Contoller), 12 IP Cam, Fibaro FGS221, 5x433mhz venetian blind, 433mhz TV ceiling lift.
Next: Touchscreen + frontpage.html
cjnicholl
- Domoticz version: 2564
I have made custom icons for Roku & Tivo devices.
Sent by mail to [email protected] as well to be added to the archive
cjnicholl
Examples here:
- 1bigwink
How are you adding these please? As far as I can see custom icons are only supported on switches, or have I maybe missed somethingcjnicholl wrote:I have made custom icons for Roku & Tivo devices.
cjnicholl
I'm adding them as a device via the System Alive Checker
sylvainsjc
I don't understand what's wrong with my custom icons file ?
impossible to upload it ?? I get message "Icon definition file not found"
domoticz V2.2765
domoticz V2.2765
- SZIcons.zip
- (12.16 KiB) Downloaded 541 times
Raspberry + Raspian + Domoticz Beta + Rfxcom433e + heater control with Chacon 54755 + sensors TS34C + OWL160 + Z-Wave Everspring/Fibaro
Complete Backup script using "dd" to remote hard disk
They seem to be alright, i only made two separate files and tested your icons in v2.2787. and it worked...sylvainsjc wrote:Hi,
domoticz V2.2765
- Chauffage.zip
- (8.54 KiB) Downloaded 501 times
- Zone.zip
- (6.04 KiB) Downloaded 416 times
sylvainsjc
yes it works with your 2 zip files but I really don't understand why ???
Does my "SZicons.zip" worked for you ???
No, got the same error. I use it only with one iconsset per zipfile...sylvainsjc wrote:yes it works with your 2 zip files but I really don't understand why ???
