#2215 Custom Icons uploader Implemented
gizmocuz
Post by gizmocuz »
Hi All,
I just uploaded #2215 that should add support for uploading custom icons. (Settings->More Options)
Its a first release, and needs some more fine tuning, but hope it works
(Gui is not translated yet also)
The icons are stored in the database, and are cached and also written to the www/images folder if they do not exists,
so when you make a backup of your database, this should let you keep your custom icons as well.
You need to supply a ZIP file, the contents is described in the updated manual.
It is possible to add multiple icons in the zip file.
Currently only supported for On/Off switches (as it is now), and probably later for other types as well
Also the dropdown to select the icon has to be rebuild as it is now a long list, when you have 50 icons its very long ;)
/Rob
Siewert308SW
Domoticz version: Stable
Re: #2215 Custom Icons uploader Implemented
Post by Siewert308SW »
Great thx and nice to beable to use your personal icons...
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
gizmocuz
Post by gizmocuz »
Here is my test zip file
2Icons.zip
(16.65 KiB) Downloaded 2486 times
Derik
Post by Derik »
Still a error:
Only my file is there:
gizmocuz
Post by gizmocuz »
Derik wrote:Still a error
New beta version available
You have a folder inside the zip file, this should NOT be there...
Derik
Post by Derik »
I did have the new version..
The folder was the problem..!!!
Thanks...
And it is working very nice !!!!!!!!
jin
Post by jin »
gizmocuz wrote:Hi All,
great great work gizmocuz!!! Thankyou!!!
DavidB
Post by DavidB »
Thanks for the icon uploader
But why don't my icons display correctly with transparency, I've set the layer in Gimp and they are transparent on my machine but not on the web interface?
Any advice gratefully received
Dave
Derik
Post by Derik »
@ Davidb..
Perhaps more info?
Like a print or textfile...
The feature is working great by me, so i think there is something wrong on your site. :cry:
DavidB
Post by DavidB »
The Icon shows a white background and not a transparent one see screenshot under device David
https://www.dropbox.com/s/ahivxsjd943ai ... 4.png?dl=0
D.
Derik
Post by Derik »
Anyone have an idea where we can share the icons in as online place?
Was thinking google drive or something. This has sufficient storage. Or maybe: https://code.google.com/
I like it to go to manage, only it must be a sustainable place.
So not a free place that tomorrow is gone.
any one an idea?
remb0
Post by remb0 »
you can use github,
of better google drive / dropbox ? free and thumbails in browsers and multiple restore view and sync options :)
I will join!
Derik wrote:Anyone have an idea where we can share the icons in as online place?
any one an idea?
Derik
Post by Derik »
Dear all:
I update the wiki....
http://www.domoticz.com/wiki/Custom_ico ... mplemented
Please read the WIKI..
Please send your icons to [email protected]
https://drive.google.com/folderview?id= ... sp=sharing
I post them when i have time
jackisidore
Post by jackisidore »
If you use a filebase name which is in use by domoticz, for instance "motion", uploading the zip file doesn't drop any errors. The icons are not visible only a broken filename browser icon.
pvm
Domoticz version: 4.10538
Post by pvm »
Good, job
Will there be an option to download all icons in a specific style?
Derik
Post by Derik »
pvm wrote:Good, job Image
In a map you can find the zip.
And there will be an on_icon, so you can see the icons before you download them...
There will be no different style...
Only the icons that other members share......
appelflap
Post by appelflap »
I really like the Nuvola icon set made by David Vignoni. ==> http://www.icon-king.com/projects/nuvola/ (GNU LGPL 2.1)
The icon set already has a folder with 48x48 icons. Within Gimp you can install a very nice 'Batch Image Manipulation' plugin with which resizing, renaming and greyscale manipulation on multiple images is very easy. Exactly what you need for nice On/Off pictures.
I attached an example of some possible icons.. Still searching for a nice door though..
nuvola-based-appelflap.zip
(68.27 KiB) Downloaded 1365 times
Derik
Post by Derik »
Dear appelflap
Will you please send your very nice icons to:
[email protected]
On the good format....
Derik
Post by Derik »
i update the wiki: http://www.domoticz.com/wiki/Custom_ico ... binterface
And the iconspage: https://drive.google.com/folderview?id= ... sp=sharing
So that everbody can find BIMP.. :D :D
Thanks.. ;)
appelflap
Post by appelflap »
@Derik: I've emailed the package and also every icon in the package as separate zip for the google drive folders.
