Blocky to lua
- Varazir
Blocky to lua
Hello
I have 2 blocky event that works as I like them to do but I like to execute a shell script when this event is triggered and what I can understand can't be done with blocky
I have never worked with LUA, done some bash scripting that is all.
I guess I can learn LUA but what I have read feels nothing that I'm looking for.
- blocky_event_computer.PNG (11.74 KiB) Viewed 3890 times
- blocky_event_tv.PNG (21.25 KiB) Viewed 3890 times
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
compuman
- Domoticz version: V4.9700
Re: Blocky to lua
Hallo Varazir
i would it write it in LUA :
ComputerConsumption = tonumber(otherdevices_svalues['ComputerConsumption'])
if ComputerConsumption < '13' and ComputerConsumption > '1' then
wait 60000
commandArray['Variable:Computer'] = 'Off'
OnkyoConsumtion = tonumber(otherdevices_svalues['Onkyo Consumtion'])
OpenelecConsumption = tonumber(otherdevices_svalues['Openelec Consumption'])
If OnkyoConsumtion < '5' and OnkyoConsumtion > '0' and OpenelecConsumption < '1' and OpenelecConsumption > '0' then
commandArray['TV'] = 'Off'
the command "Wait 60000" are not avaibele in Lua. I would it do with a "delay Funktion " in the Switch Propperties.
I think, the TV is never go Off because, there is no value between >0 and <1.
wait 60000
- Varazir
Re: Blocky to lua
Thankscompuman wrote:Hallo Varazir
wait 60000
Found thiscompuman wrote: the command "Wait 60000" are not avaibele in Lua. I would it do with a "delay Funktion " in the Switch Propperties.
http://stackoverflow.com/a/13263109
local clock = os.clock
function sleep(n) -- seconds
local t0 = clock()
while clock() - t0 <= n do
endHmm, It's due to the raspberry PI consumes 2.2W when running and about 0.4 W when it's turned offcompuman wrote: I think, the TV is never go Off because, there is no value between >0 and <1.
I'm using non standard notification system, going to call a bash script that pushes out a msg to my phone.
If ComputerConsumption < 15 and ComputerConsumption > 0; then
execute scrip/notification.sh "Computer" "#Domoticz" "Computer is shutdown, powering down in 20 seconds" &
sleep 20
sleep 5
set computer = off
execute scrip/notification.sh "Computer" "#Domoticz" "Computer is online again"
exit
fi
fi
jackfagner
Re: Blocky to lua
You could actually execute scripts from blocky using this hack:
Add an OpenURL action with URL:
The script ~/domoticz/scripts/myscript.sh will then be executed with parameters 123
Happy coding!
127.0.0.1:8080/json.htm?type=command¶m=execute_script&direct=true&scriptname=myscript.sh&scriptparams=123Happy coding!
- Varazir
Re: Blocky to lua
How can I add space to the parameters?jackfagner wrote:You could actually execute scripts from blocky using this hack:
Add an OpenURL action with URL:The script ~/domoticz/scripts/myscript.sh will then be executed with parameters 123Code: Select all
Happy coding!
2016-03-04 21:40:00.466 Error: Error opening url: 127.0.0.1:8080/json.htm?type=command¶m=execute_script&direct=true&scriptname=irssinotifier.sh&scriptparams=""Computer" "#Domoticz_inet" "Turning off the Computer""Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
niceandeasy
- Domoticz version: 3.8153
Re: Blocky to lua
If you would introduce a delay in a LUA script, Domoticz will freeze untili that delay has past. So don't do it. Don't use that os.clock delay trick.compuman wrote:...
wait 60000
The switch delay function might be an option.
You may also issue command['Computer']='Off AFTER 60'
Take a look at the domoticz wiki page 'Events'.
- Varazir
Re: Blocky to lua
Hmm, honestly I can't remember why I needed this.
I guess I can do a workaround with OpenURL. creating a "script" that calls my other script so I don't need any parameters.
or simpler with just one parameter "computer" "tv" etc and then the full command line in the file.
jackfagner
Re: Blocky to lua
Varazir wrote:How can I add space to the parameters?jackfagner wrote:You could actually execute scripts from blocky using this hack:
Happy coding!
127.0.0.1:8080/json.htm?type=command¶m=execute_script&direct=true&scriptname=irssinotifier.sh&scriptparams=Computer%20%23Domoticz_inet%20%22Turning%20off%20the%20Computer%22
