Blocky to lua
Varazir
Blocky to lua
Post by Varazir »
Hello
I have 2 blocky event that works as I like them to do but I like to execute a shell script when this event is triggered and what I can understand can't be done with blocky
I have never worked with LUA, done some bash scripting that is all.
I guess I can learn LUA but what I have read feels nothing that I'm looking for.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
compuman
Domoticz version: V4.9700
Re: Blocky to lua
Post by compuman »
Hallo Varazir
i would it write it in LUA :
ComputerConsumption = tonumber(otherdevices_svalues['ComputerConsumption'])
if ComputerConsumption < '13' and ComputerConsumption > '1' then
wait 60000
commandArray['Variable:Computer'] = 'Off'
OnkyoConsumtion = tonumber(otherdevices_svalues['Onkyo Consumtion'])
OpenelecConsumption = tonumber(otherdevices_svalues['Openelec Consumption'])
If OnkyoConsumtion < '5' and OnkyoConsumtion > '0' and OpenelecConsumption < '1' and OpenelecConsumption > '0' then
commandArray['TV'] = 'Off'
the command "Wait 60000" are not avaibele in Lua. I would it do with a "delay Funktion " in the Switch Propperties.
I think, the TV is never go Off because, there is no value between >0 and <1.
Varazir
Re: Blocky to lua
Post by Varazir »
compuman wrote:Hallo Varazir
wait 60000
compuman wrote: the command "Wait 60000" are not avaibele in Lua. I would it do with a "delay Funktion " in the Switch Propperties.
Found this
http://stackoverflow.com/a/13263109
local clock = os.clock
function sleep(n)  -- seconds
   local t0 = clock()
   while clock() - t0 <= n do
compuman wrote: I think, the TV is never go Off because, there is no value between >0 and <1.
Hmm, It's due to the raspberry PI consumes 2.2W when running and about 0.4 W when it's turned off
I'm using non standard notification system, going to call a bash script that pushes out a msg to my phone.
If ComputerConsumption < 15 and ComputerConsumption > 0; then
         execute  scrip/notification.sh "Computer" "#Domoticz" "Computer is shutdown, powering down in 20 seconds" &
         sleep 20
                  sleep 5
                  set computer = off
                  execute  scrip/notification.sh "Computer" "#Domoticz" "Computer is online again"
                  exit
         fi
fi
jackfagner
Re: Blocky to lua
Post by jackfagner »
You could actually execute scripts from blocky using this hack:
Add an OpenURL action with URL:
127.0.0.1:8080/json.htm?type=command&param=execute_script&direct=true&scriptname=myscript.sh&scriptparams=123
The script ~/domoticz/scripts/myscript.sh will then be executed with parameters 123
Happy coding!
Varazir
Re: Blocky to lua
Post by Varazir »
jackfagner wrote:You could actually execute scripts from blocky using this hack:
Happy coding!
How can I add space to the parameters?
2016-03-04 21:40:00.466 Error: Error opening url: 127.0.0.1:8080/json.htm?type=command¶m=execute_script&direct=true&scriptname=irssinotifier.sh&scriptparams=""Computer" "#Domoticz_inet" "Turning off the Computer""
niceandeasy
Domoticz version: 3.8153
Re: Blocky to lua
Post by niceandeasy »
compuman wrote:...
wait 60000
If you would introduce a delay in a LUA script, Domoticz will freeze untili that delay has past. So don't do it. Don't use that os.clock delay trick.
The switch delay function might be an option.
You may also issue command['Computer']='Off AFTER 60'
Take a look at the domoticz wiki page 'Events'.
Varazir
Re: Blocky to lua
Post by Varazir »
Hmm, honestly I can't remember why I needed this.
I guess I can do a workaround with OpenURL. creating a "script" that calls my other script so I don't need any parameters.
or simpler with just one parameter "computer" "tv" etc and then the full command line in the file.
jackfagner
Re: Blocky to lua
Happy coding!
127.0.0.1:8080/json.htm?type=command&param=execute_script&direct=true&scriptname=irssinotifier.sh&scriptparams=Computer%20%23Domoticz_inet%20%22Turning%20off%20the%20Computer%22
