DTGMenu4Docker (updated version of DTGBOT)
jvdz
Domoticz version: 4.107
Post by jvdz »
I have been working on a Docker version for DTGBOT, which will make the whole installation very simple and avoid all these LUA & SSL incompatibilities we have seen over the last couple of years.
It also has a web front end to make log checking and basic configuration easier.
This will be the only DTGBOT version I am supporting going forward, and I would like to thank @simonrg for all his work on the original DTGBOT project.
All info can be found here: https://github.com/jvanderzande/dtgbotmenu4docker
Some Screenscapture:
DTGBOTMENU_keyboard_menu1 (Klein).png (287.77 KiB) Viewed 2299 times
DTGBOTMENU_inline_menu1 (Klein).png (336.63 KiB) Viewed 2299 times
mojso
Re: DTGMenu4Docker (updated version of DTGBOT)
Post by mojso »
Very good and useful, especially when you don't have a public IP address.
You can control Domoticz from wherever you want.
andreo
Domoticz version: 2024.3
Post by andreo »
Successfully implemented and this is so useful, very satisfied with it.
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
RNEE
Domoticz version: 2026.4
Post by RNEE »
Hi Jos,
I have troubles implementing DTG bot.
Log :
2026-11-17 11:17:25 : >> Start Initial connectivity check for Domoticz and Telegram ==
2026-11-17 11:17:25 : Domoticz getversion failed
2026-11-17 11:17:25 : !> Initial test connection to Domoticz failed!
2026-11-17 11:17:25 : +> Initial test connection to Telegram successfull.
2026-11-17 11:17:25 : > ------------------------------------------------------------------
2026-11-17 11:17:25 : !> problem connecting to DomoticzURL=http://192.168.2.48:8080. Is it correct in the compose definitions ?
2026-11-17 11:17:25 : !> Fix your docker-compose.yml environment variable(s) and try to restart.
2026-11-17 11:17:25 : !> environment:
2026-11-17 11:17:25 : !> - TZ=Europe/Amsterdam # Timezone setting
2026-11-17 11:17:25 : !> - DomoticzURL=http://192.168.2.48:8080 # your domoticz url
Problem here is : DomoticzURL=http://dtgbot:domoticz@domoticz-host:8080 # your domoticz url
My IP for Domotics is 192.168.2.48
The Docker IP for the Domoticz container is 172.18.0.2
What should the DomoticzURL in the compose.yaml be exactly ? I tried several but no succes.
Thank you, Rene
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|DTGbot|
jvdz
Post by jvdz »
I am running them both on the same HOST(ip = 192.168.0.12) in seperate docker stacks and in DTGBOTMENU use:
    environment:
      - DomoticzURL=http://dtgbot:[email protected]:8080            # your domoticz url
Which is working fine for me.
Obviously the userid "dtgbot" needs to be defined in domoticz with password "domoticz".
RNEE
Post by RNEE »
Ah Oke, i used an existing Telegram account and its password for "dtgbot".
That does not match, my bad..
Now i made a user account for dtgbot with password, and it works now so far.
May you can add the "user : password" requirements / setup on the readme page on Github, something like :
DomoticzURL=http://dtgbot:domoticz@domoticz-host:8080 # ie your dtgbot-user:dtgbot-password@domoticz:8080 url
where dtgbot-user and dtgbot-password should be created in Domoticz->setup->users
Thank you , looks very nice , great enhancement for holiday use !
RNEE
Post by RNEE »
I noticed after plain setup(changed nothing) in "rooms selection" the "use default" gives an error in telegram:
when "use default" is deselected it works as expected.
jvdz
Post by jvdz »
I think I found that issue (bug), which only happens when the config is still empty.
Could you try the latest v1.3.11 available now in hub.docker.com?
Please email me to my github email account with the logs attached in case you still have issues.
Thanks for reporting.
PS: DTGMENU works with the Rooms defined in Domoticz as its basic menu structure. It is not required and can be defined manually, but defining Rooms is the easiest.
RNEE
Post by RNEE »
On 1.3.11 It is working now.
When "default" is selected i get "Misc" and "Exit"
when "default" is unselected i get my rooms.
Thankx for the quick response.
jvdz
Post by jvdz »
You can define in the config menu the default rooms used. So this allows you to make a standard set of rooms to use for the users.
When you deselect Default, you can manually set the displayed rooms for that particular user.
