DTGMenu4Docker (updated version of DTGBOT)
- jvdz
- Domoticz version: 4.107
I have been working on a Docker version for DTGBOT, which will make the whole installation very simple and avoid all these LUA & SSL incompatibilities we have seen over the last couple of years.
It also has a web front end to make log checking and basic configuration easier.
This will be the only DTGBOT version I am supporting going forward, and I would like to thank @simonrg for all his work on the original DTGBOT project.
All info can be found here: https://github.com/jvanderzande/dtgbotmenu4docker
Some Screenscapture:
mojso
Re: DTGMenu4Docker (updated version of DTGBOT)
Very good and useful, especially when you don't have a public IP address.
You can control Domoticz from wherever you want.
- andreo
- Domoticz version: 2024.3
Successfully implemented and this is so useful, very satisfied with it.
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
RNEE
- Domoticz version: 2026.4
Hi Jos,
I have troubles implementing DTG bot.
Log :
2026-11-17 11:17:25 : >> Start Initial connectivity check for Domoticz and Telegram ==
2026-11-17 11:17:25 : Domoticz getversion failed
2026-11-17 11:17:25 : !> Initial test connection to Domoticz failed!
2026-11-17 11:17:25 : +> Initial test connection to Telegram successfull.
2026-11-17 11:17:25 : > ------------------------------------------------------------------
2026-11-17 11:17:25 : !> problem connecting to DomoticzURL=http://192.168.2.48:8080. Is it correct in the compose definitions ?
2026-11-17 11:17:25 : !> Fix your docker-compose.yml environment variable(s) and try to restart.
2026-11-17 11:17:25 : !> environment:
2026-11-17 11:17:25 : !> - TZ=Europe/Amsterdam # Timezone setting
2026-11-17 11:17:25 : !> - DomoticzURL=http://192.168.2.48:8080 # your domoticz url
Problem here is : DomoticzURL=http://dtgbot:domoticz@domoticz-host:8080 # your domoticz url
My IP for Domotics is 192.168.2.48
The Docker IP for the Domoticz container is 172.18.0.2
What should the DomoticzURL in the compose.yaml be exactly ? I tried several but no succes.
Thank you, Rene
Log :
Thank you, Rene
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|DTGbot|
- jvdz
I am running them both on the same HOST(ip = 192.168.0.12) in seperate docker stacks and in DTGBOTMENU use:
Which is working fine for me.
Obviously the userid "dtgbot" needs to be defined in domoticz with password "domoticz".
environment:
- DomoticzURL=http://dtgbot:[email protected]:8080 # your domoticz url
RNEE
Ah Oke, i used an existing Telegram account and its password for "dtgbot".
That does not match, my bad..
Now i made a user account for dtgbot with password, and it works now so far.
May you can add the "user : password" requirements / setup on the readme page on Github, something like :
DomoticzURL=http://dtgbot:domoticz@domoticz-host:8080 # ie your dtgbot-user:dtgbot-password@domoticz:8080 url
where dtgbot-user and dtgbot-password should be created in Domoticz->setup->users
Thank you , looks very nice , great enhancement for holiday use !
RNEE
I noticed after plain setup(changed nothing) in "rooms selection" the "use default" gives an error in telegram:
when "use default" is deselected it works as expected.
- jvdz
I think I found that issue (bug), which only happens when the config is still empty.
Could you try the latest v1.3.11 available now in hub.docker.com?
Please email me to my github email account with the logs attached in case you still have issues.
Thanks for reporting.
PS: DTGMENU works with the Rooms defined in Domoticz as its basic menu structure. It is not required and can be defined manually, but defining Rooms is the easiest.
RNEE
On 1.3.11 It is working now.
When "default" is selected i get "Misc" and "Exit"
when "default" is unselected i get my rooms.
Thankx for the quick response.
- jvdz
You can define in the config menu the default rooms used. So this allows you to make a standard set of rooms to use for the users.
When you deselect Default, you can manually set the displayed rooms for that particular user.
