Problem with the blockly script turning on the light
Dave21w
- Domoticz version: Stable
Re: Problem with the blockly script turning on the light
If turned on individually do you want to disable the auto on via pir of both or only the one you have manually turned on
Maciek90
Only the one I turned on manually.
The script from madpatrick works exactly as I want. However, there's a problem, and I don't know what's causing it. Every few days, one of the lights won't turn off after a set time (30 seconds) after the motion sensor signal is turned off. I had the same problem with my script in Blockly.
- madpatrick
- Domoticz version: 2026.1
Sounds it is not an script issue.
You can give extra/second switch off command but that makes no sense
Maciek90
I thought about that tooSounds it is not an script issue.
I tried something like this in blockly but it didn't helpYou can give extra/second switch off command but that makes no sense
However, I noticed that this problem was more common with blockly. With dzVents, it happens once every few days. Any ideas what might be causing this?
- madpatrick
Is the switched off command triggered when it happens
If the command is send to the switch then it is not a acriot issue but hardware
- madpatrick
Can you try this
it should switch off the lamp 30 after after the last movement. When there will be new movement within the 30 sec it will reset to 30 sec again
local SCRIPT_NAME = 'PIR'
local LOG_LEVEL = domoticz.LOG_FORCE
local OFF_DELAY = 30
devices = {68, 69, 1574, 1575},
logging = {
level = LOG_LEVEL,
marker = SCRIPT_NAME
execute = function(dz, device)
local pir1 = dz.devices(69)
local pir2 = dz.devices(1575)
local lamp1 = dz.devices(68)
local lamp2 = dz.devices(1574)
local lamp1PirVar = dz.variables('Lamp1_PIR')
local lamp2PirVar = dz.variables('Lamp2_PIR')
-- PIR 1 / Lamp 1
-- PIR detects motion → lamp ON or timer reset
if device.id == pir1.id and pir1.state == 'On' then
if lamp1.state == 'Off' then
lamp1.switchOn()
dz.log('PIR1 → Lamp1 ON', LOG_LEVEL)
-- mark lamp as PIR-controlled
lamp1PirVar.set(1)
-- cancel any pending OFF by reasserting ON
lamp1.switchOn().checkFirst()
dz.log('PIR1 → OFF timer reset', LOG_LEVEL)
-- PIR no motion → plan OFF
and pir1.state == 'Off'
and lamp1.state == 'On'
and lamp1PirVar.value == 1
then
lamp1.switchOff().afterSec(OFF_DELAY)
dz.log('PIR1 → Lamp1 OFF in ' .. OFF_DELAY .. ' sec', LOG_LEVEL)
-- Lamp actually turned off → reset PIR flag
if device.id == lamp1.id
and lamp1.state == 'Off'
then
lamp1PirVar.set(0)
dz.log('Lamp1 OFF → PIR mode reset', LOG_LEVEL)
-- Manual ON → disable PIR control
then
lamp1PirVar.set(0)
dz.log('Lamp1 manually ON → PIR disabled', LOG_LEVEL)
-- PIR 2 / Lamp 2
if device.id == pir2.id and pir2.state == 'On' then
if lamp2.state == 'Off' then
lamp2.switchOn()
dz.log('PIR2 → Lamp2 ON', LOG_LEVEL)
lamp2PirVar.set(1)
-- cancel pending OFF
lamp2.switchOn().checkFirst()
dz.log('PIR2 → OFF timer reset', LOG_LEVEL)
and pir2.state == 'Off'
and lamp2.state == 'On'
and lamp2PirVar.value == 1
then
lamp2.switchOff().afterSec(OFF_DELAY)
dz.log('PIR2 → Lamp2 OFF in ' .. OFF_DELAY .. ' sec', LOG_LEVEL)
if device.id == lamp2.id
and lamp2.state == 'Off'
then
lamp2PirVar.set(0)
dz.log('Lamp2 OFF → PIR mode reset', LOG_LEVEL)
then
lamp2PirVar.set(0)
dz.log('Lamp2 manually ON → PIR disabled', LOG_LEVEL)
Maciek90
In this script, when I manually turn on the lamp and then the motion sensor is triggered and then turned off, after 30 seconds the lamps also turn off. The variables also change their value to 1.
