Problem with the blockly script turning on the light
Maciek90
Re: Problem with the blockly script turning on the light
Post by Maciek90 »
Individually
Dave21w
Domoticz version: Stable
Post by Dave21w »
If turned on individually do you want to disable the auto on via pir of both or only the one you have manually turned on
Maciek90
Post by Maciek90 »
Only the one I turned on manually.
The script from madpatrick works exactly as I want. However, there's a problem, and I don't know what's causing it. Every few days, one of the lights won't turn off after a set time (30 seconds) after the motion sensor signal is turned off. I had the same problem with my script in Blockly.
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Sounds it is not an script issue.
You can give extra/second switch off command but that makes no sense
Maciek90
Post by Maciek90 »
I thought about that too
I tried something like this in blockly but it didn't help
However, I noticed that this problem was more common with blockly. With dzVents, it happens once every few days. Any ideas what might be causing this?
madpatrick
Is the switched off command triggered when it happens
If the command is send to the switch then it is not a acriot issue but hardware
madpatrick
Can you try this
it should switch off the lamp 30 after after the last movement. When there will be new movement within the 30 sec it will reset to 30 sec again
local SCRIPT_NAME = 'PIR'
local LOG_LEVEL = domoticz.LOG_FORCE
local OFF_DELAY = 30
        devices = {68, 69, 1574, 1575},
    logging = {
        level = LOG_LEVEL,
        marker = SCRIPT_NAME
    execute = function(dz, device)
        local pir1 = dz.devices(69)
        local pir2 = dz.devices(1575)
        local lamp1 = dz.devices(68)
        local lamp2 = dz.devices(1574)
        local lamp1PirVar = dz.variables('Lamp1_PIR')
        local lamp2PirVar = dz.variables('Lamp2_PIR')
        -- PIR 1 / Lamp 1
        -- PIR detects motion → lamp ON or timer reset
        if device.id == pir1.id and pir1.state == 'On' then
            if lamp1.state == 'Off' then
                lamp1.switchOn()
                dz.log('PIR1 → Lamp1 ON', LOG_LEVEL)
            -- mark lamp as PIR-controlled
            lamp1PirVar.set(1)
            -- cancel any pending OFF by reasserting ON
            lamp1.switchOn().checkFirst()
            dz.log('PIR1 → OFF timer reset', LOG_LEVEL)
        -- PIR no motion → plan OFF
            and pir1.state == 'Off'
            and lamp1.state == 'On'
            and lamp1PirVar.value == 1
        then
            lamp1.switchOff().afterSec(OFF_DELAY)
            dz.log('PIR1 → Lamp1 OFF in ' .. OFF_DELAY .. ' sec', LOG_LEVEL)
        -- Lamp actually turned off → reset PIR flag
        if device.id == lamp1.id
            and lamp1.state == 'Off'
        then
            lamp1PirVar.set(0)
            dz.log('Lamp1 OFF → PIR mode reset', LOG_LEVEL)
        -- Manual ON → disable PIR control
        then
            lamp1PirVar.set(0)
            dz.log('Lamp1 manually ON → PIR disabled', LOG_LEVEL)
        -- PIR 2 / Lamp 2
        if device.id == pir2.id and pir2.state == 'On' then
            if lamp2.state == 'Off' then
                lamp2.switchOn()
                dz.log('PIR2 → Lamp2 ON', LOG_LEVEL)
            lamp2PirVar.set(1)
            -- cancel pending OFF
            lamp2.switchOn().checkFirst()
            dz.log('PIR2 → OFF timer reset', LOG_LEVEL)
            and pir2.state == 'Off'
            and lamp2.state == 'On'
            and lamp2PirVar.value == 1
        then
            lamp2.switchOff().afterSec(OFF_DELAY)
            dz.log('PIR2 → Lamp2 OFF in ' .. OFF_DELAY .. ' sec', LOG_LEVEL)
        if device.id == lamp2.id
            and lamp2.state == 'Off'
        then
            lamp2PirVar.set(0)
            dz.log('Lamp2 OFF → PIR mode reset', LOG_LEVEL)
        then
            lamp2PirVar.set(0)
            dz.log('Lamp2 manually ON → PIR disabled', LOG_LEVEL)
Maciek90
Post by Maciek90 »
In this script, when I manually turn on the lamp and then the motion sensor is triggered and then turned off, after 30 seconds the lamps also turn off. The variables also change their value to 1.
