Please use template to report bugs and problems. Post here your questions when not sure where else to post Only for bugs in the Domoticz application! other problems go in different subforums!
Forum rules
I had the same `GLIBC_2.38' not found' error when I upgraded my beta today. Also on bookworm; running on a Pi 4. Sorry, I can't now be certain of the "old" and "new" domoticz releases.
I "fixed" the problem by reverting to an older version of the bata, as described at https://wiki.domoticz.com/Raspberry_Pi# ... ect_update
It's now running OK on version 2025.2 (build 17057)
My impression from a few searches is that Glibc 2.38 is used in trixie but not in bookworm. But I'm not an expert!
I hope this helps.
Should be solved now by upgrading to the latest beta.
The build servers had to be adjusted because of a big (&$!@) change by mosquitto's CMake project.
Domoticz is now also using a new external library (libmosquitto1) that is installed by the updatebeta/updaterelease scripts (assuming you are on one the latest beta's)
For users running a stable release via the bash install command line , you should run this script again so all dependencies are installed.
Of course docker users will have no issues when upgrading
gizmocuz wrote: Friday 06 February 2026 9:13
Something to mention in the release notes (history.txt) of upcoming stable 2026.1 ....
