Crash with 2025.2 beta 17074
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Filnet
Domoticz version: 2025.2 ß
Post by Filnet »
Hello, This morning I update from 2025.2 beta 17060 to 2025.2 beta 17074.
And domoticz crashes at opening:
● domoticz.service - LSB: Home Automation System
     Loaded: loaded (/etc/init.d/domoticz.sh; generated)
     Active: active (exited) since Thu 2026-02-05 08:37:58 CET; 3min 17s ago
       Docs: man:systemd-sysv-generator(8)
    Process: 9606 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
        CPU: 44ms
févr. 05 08:37:58 pidomo systemd[1]: Starting domoticz.service - LSB: Home Automation System...
févr. 05 08:37:58 pidomo domoticz.sh[9606]: Time synchronized, starting Domoticz...
févr. 05 08:37:58 pidomo domoticz.sh[9616]: /home/pi/domoticz/domoticz: /lib/aarch64-linux-gnu/libm.so.6: version `GLIBC_2.38' not found (required by /home/pi/domoticz/domoticz)
Could you hep me? Thanks
NB: under bookworm (is it the problem?)
ChrisWallwork
Re: Crash with 2025.2 beta 17074
Post by ChrisWallwork »
I had the same `GLIBC_2.38' not found' error when I upgraded my beta today. Also on bookworm; running on a Pi 4. Sorry, I can't now be certain of the "old" and "new" domoticz releases.
I "fixed" the problem by reverting to an older version of the bata, as described at
https://wiki.domoticz.com/Raspberry_Pi# ... ect_update
It's now running OK on version 2025.2 (build 17057)
My impression from a few searches is that Glibc 2.38 is used in trixie but not in bookworm. But I'm not an expert!
I hope this helps.
Raspberry Pi, RFXTRX433, Philips Hue, Honeywell Evohome, Owl CM133, Oregon weather & temp sensors, Hikvision NVR
Filnet
Post by Filnet »
Thanks Chris for your reply. I'll wait a few hours and see if a new beta version is released before reverting to the old one.
I also think it's a problem with Bookworm.
rene2716
Post by rene2716 »
same here reverted to 17060 and everything works again, lets wait it out :)
pfloryann
Post by pfloryann »
I put an older backup, upgraded to Debian 13 and then updated to Domoticz beta. That's how it worked.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
Domoticz version: 2025.1
Filnet
Post by Filnet »
I can't revert because I do an update several times and backups are dated after the first update.
Two solutions:
- Waiting for another release?
- Try updating to Debian 13?
What do you think about that?
FireWizard
Post by FireWizard »
GLIBC_2.38 has never been used in Debian.
Bookworm uses 2.36 and Trixie uses 2.41.
So if an upgrade to Debian 13 will help you, I do not know.
Filnet
Post by Filnet »
Happy end!
I have upgraded to trixie. https://forums.raspberrypi.com/viewtopi ... 6&start=50
domoticz is running!
I shall have some stuff to repair monit's parameters...
Thank you for your help.
rene2716
Post by rene2716 »
hopefully there will be a fix from domoticz itself i dont like patching the system everytime
gizmocuz
Post by gizmocuz »
Should be solved now by upgrading to the latest beta.
The build servers had to be adjusted because of a big (&$!@) change by mosquitto's CMake project.
Domoticz is now also using a new external library (libmosquitto1) that is installed by the updatebeta/updaterelease scripts (assuming you are on one the latest beta's)
For users running a stable release via the bash install command line , you should run this script again so all dependencies are installed.
Of course docker users will have no issues when upgrading
gizmocuz wrote: Friday 06 February 2026 9:13 For users running a stable release via the bash install command line , you should run this script again so all dependencies are installed.
Something to mention in the release notes (history.txt) of upcoming stable 2026.1 ....
rene2716
Post by rene2716 »
indeed its working now with updatebeta :D
Users browsing this forum: gizmocuz and 1 guest
