Crash with 2025.2 beta 17074
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Filnet
Domoticz version: 2026.1 ß
Post by Filnet »
Hello, This morning I update from 2025.2 beta 17060 to 2025.2 beta 17074.
And domoticz crashes at opening:
● domoticz.service - LSB: Home Automation System
     Loaded: loaded (/etc/init.d/domoticz.sh; generated)
     Active: active (exited) since Thu 2026-02-05 08:37:58 CET; 3min 17s ago
       Docs: man:systemd-sysv-generator(8)
    Process: 9606 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
        CPU: 44ms
févr. 05 08:37:58 pidomo systemd[1]: Starting domoticz.service - LSB: Home Automation System...
févr. 05 08:37:58 pidomo domoticz.sh[9606]: Time synchronized, starting Domoticz...
févr. 05 08:37:58 pidomo domoticz.sh[9616]: /home/pi/domoticz/domoticz: /lib/aarch64-linux-gnu/libm.so.6: version `GLIBC_2.38' not found (required by /home/pi/domoticz/domoticz)
Could you hep me? Thanks
NB: under bookworm (is it the problem?)
ChrisWallwork
Re: Crash with 2025.2 beta 17074
Post by ChrisWallwork »
I had the same `GLIBC_2.38' not found' error when I upgraded my beta today. Also on bookworm; running on a Pi 4. Sorry, I can't now be certain of the "old" and "new" domoticz releases.
I "fixed" the problem by reverting to an older version of the bata, as described at
https://wiki.domoticz.com/Raspberry_Pi# ... ect_update
It's now running OK on version 2025.2 (build 17057)
My impression from a few searches is that Glibc 2.38 is used in trixie but not in bookworm. But I'm not an expert!
I hope this helps.
Raspberry Pi, RFXTRX433, Philips Hue, Honeywell Evohome, Owl CM133, Oregon weather & temp sensors, Hikvision NVR
Filnet
Post by Filnet »
Thanks Chris for your reply. I'll wait a few hours and see if a new beta version is released before reverting to the old one.
I also think it's a problem with Bookworm.
rene2716
Post by rene2716 »
same here reverted to 17060 and everything works again, lets wait it out :)
pfloryann
Post by pfloryann »
I put an older backup, upgraded to Debian 13 and then updated to Domoticz beta. That's how it worked.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
Filnet
Post by Filnet »
I can't revert because I do an update several times and backups are dated after the first update.
Two solutions:
- Waiting for another release?
- Try updating to Debian 13?
What do you think about that?
FireWizard
Post by FireWizard »
GLIBC_2.38 has never been used in Debian.
Bookworm uses 2.36 and Trixie uses 2.41.
So if an upgrade to Debian 13 will help you, I do not know.
Filnet
Post by Filnet »
Happy end!
I have upgraded to trixie. https://forums.raspberrypi.com/viewtopi ... 6&start=50
domoticz is running!
I shall have some stuff to repair monit's parameters...
Thank you for your help.
rene2716
Post by rene2716 »
hopefully there will be a fix from domoticz itself i dont like patching the system everytime
gizmocuz
Post by gizmocuz »
Should be solved now by upgrading to the latest beta.
The build servers had to be adjusted because of a big (&$!@) change by mosquitto's CMake project.
Domoticz is now also using a new external library (libmosquitto1) that is installed by the updatebeta/updaterelease scripts (assuming you are on one the latest beta's)
For users running a stable release via the bash install command line , you should run this script again so all dependencies are installed.
Of course docker users will have no issues when upgrading
gizmocuz wrote: Friday 06 February 2026 9:13 For users running a stable release via the bash install command line , you should run this script again so all dependencies are installed.
Something to mention in the release notes (history.txt) of upcoming stable 2026.1 ....
rene2716
Post by rene2716 »
indeed its working now with updatebeta :D
