Tado Local and python plugin
Dave21w
- Domoticz version: Stable
Re: Tado Local and python plugin
Before I go down the route of having a play with this and potentially breaking our heating and having to suffer the wrath of the wife I wonder if someone could answer a question.
I'm quite happy using the Tado app so I was thinking of using this more as a backup, along the lines of duplicating the app programming schedule but setting a slighlty later time for the changes so if a room was supposed to change from 16c to 21c at 7am I would set the device in Domoticz to do the same but at 7:05 so if the internet has died my heating still comes on, is this feasible ?
jannl
- Domoticz version: 2025.5.x
I don't think this is a big issue, since my google home mini also connects to the bridge. And I think also via the homekit protocol, but not sure about that.
manjh
- Domoticz version: 2020.2
Doesn't that Google Home use internet as well?jannl wrote: Thursday 13 November 2025 11:55 I don't think this is a big issue, since my google home mini also connects to the bridge. And I think also via the homekit protocol, but not sure about that.
Hans
jannl
With the update I get a lot further. The localhost is running, in the commandline logging I see the zones being fetched from the Tado api.
However, when I issue http://<ip>:4407/zones, I get no error, but also no zones.
sloeber70
- Domoticz version: latest
Got this far like last time... still same error:
Tado App update works and gets updates in Tado-Local
Other way : change temperature fails... no leader device
I did update : git pull.... several file replaced... rebooted
See attached
See attached
- 2025-11-14_19-19-54.jpg (191.89 KiB) Viewed 175 times
Kind regards,
Sloeber70
Linux Debian 13 standard edition
Domoticz latest beta on ProxmoxVE Virtual Machine
Sloeber70
sloeber70
<iP>:4407/zones gives:
"homes": [
"id": xxxxxxx,
"name": "HxMx8x0x"
"zones": [
"zone_id": 1,
"name": "Keuken",
"uuid": "filled in repladed by me",
"leader_device_id": null,
"leader_serial": null,
"leader_type": null,
"is_circuit_driver": false,
"order_id": 0,
"device_count": 1,
"state": {
"cur_temp_c": 23.5,
"cur_temp_f": 74.3,
"hum_perc": 51,
"target_temp_c": 22,
"target_temp_f": 71.6,
"mode": 1,
"cur_heating": 0
"home_id": xxxxxxx
"count": 8
"homes": [
"id": xxxxxxx,
"name": "HxMx8x0x"
"zones": [
"zone_id": 1,
"name": "Keuken",
"order_id": 0,
"device_count": 1,
"state": {
"cur_temp_c": 23.5,
"cur_temp_f": 74.3,
"hum_perc": 51,
"mode": 1,
"cur_heating": 0
"home_id": xxxxxxx
"count": 8
Kind regards,
Sloeber70
Sloeber70
jannl
I also got the no leader device when updating a setpoint.
jannl
Pairing once worked, I updated the software, pairing does not succeed anymore.
I am not going to issue a factory reset, so it could be my TadoLocal stops here.....
So I hope there is another solution
- Domoticz version: 2025.1
What software did you update, the Tado Local application or the plugin or both?jannl wrote: Friday 05 December 2025 12:09 Pairing once worked, I updated the software, pairing does not succeed anymore.
jannl
propably both, but I removed the tado local first
Is removing first the way to update? Normally you do some kind of update (eg git pull) to update an application and/or a python plugin.(in Domoticz)
jannl
Allthough I mostly agree, that is not always the right way. Especcially when the first install was done by extracting a zip or tarfile.
Anyway, now I removed and reinstalled. I think that should work as well.
dirkdedeur
@Sloeber 70 how did you solve the TADO LOCAL: Failed to connect to Zones Fetch: Connection refused (Status: 111) error?sloeber70 wrote: Friday 14 November 2025 19:22 Got this far like last time... still same error:
See attached
