Tado Local and python plugin
Dave21w
Domoticz version: Stable
Re: Tado Local and python plugin
Post by Dave21w »
Before I go down the route of having a play with this and potentially breaking our heating and having to suffer the wrath of the wife I wonder if someone could answer a question.
I'm quite happy using the Tado app so I was thinking of using this more as a backup, along the lines of duplicating the app programming schedule but setting a slighlty later time for the changes so if a room was supposed to change from 16c to 21c at 7am I would set the device in Domoticz to do the same but at 7:05 so if the internet has died my heating still comes on, is this feasible ?
jannl
Domoticz version: 2025.5.x
Post by jannl »
I don't think this is a big issue, since my google home mini also connects to the bridge. And I think also via the homekit protocol, but not sure about that.
manjh
Post by manjh »
jannl wrote: Thursday 13 November 2025 11:55 I don't think this is a big issue, since my google home mini also connects to the bridge. And I think also via the homekit protocol, but not sure about that.
Doesn't that Google Home use internet as well?
Hans
jannl
Post by jannl »
With the update I get a lot further. The localhost is running, in the commandline logging I see the zones being fetched from the Tado api.
However, when I issue http://<ip>:4407/zones, I get no error, but also no zones.
sloeber70
Domoticz version: latest
Post by sloeber70 »
Got this far like last time... still same error:
Tado App update works and gets updates in Tado-Local
Other way : change temperature fails... no leader device
I did update : git pull.... several file replaced... rebooted
See attached
Kind regards,
Sloeber70
Linux Debian 13 standard edition
Domoticz latest beta on ProxmoxVE Virtual Machine
sloeber70
Post by sloeber70 »
<iP>:4407/zones gives:
"homes": [
"id": xxxxxxx,
"name": "HxMx8x0x"
"zones": [
"zone_id": 1,
"name": "Keuken",
"uuid": "filled in repladed by me",
"leader_device_id": null,
"leader_serial": null,
"leader_type": null,
"is_circuit_driver": false,
"order_id": 0,
"device_count": 1,
"state": {
"cur_temp_c": 23.5,
"cur_temp_f": 74.3,
"hum_perc": 51,
"target_temp_c": 22,
"target_temp_f": 71.6,
"mode": 1,
"cur_heating": 0
"home_id": xxxxxxx
"count": 8
Kind regards,
Sloeber70
jannl
Post by jannl »
I also got the no leader device when updating a setpoint.
jannl
Post by jannl »
Pairing once worked, I updated the software, pairing does not succeed anymore.
I am not going to issue a factory reset, so it could be my TadoLocal stops here.....
So I hope there is another solution
Domoticz version: 2025.1
jannl wrote: Friday 05 December 2025 12:09 Pairing once worked, I updated the software, pairing does not succeed anymore.
What software did you update, the Tado Local application or the plugin or both?
jannl
Post by jannl »
propably both, but I removed the tado local first
jannl wrote: Saturday 06 December 2025 13:03 propably both, but I removed the tado local first
Is removing first the way to update? Normally you do some kind of update (eg git pull) to update an application and/or a python plugin.(in Domoticz)
jannl
Post by jannl »
Allthough I mostly agree, that is not always the right way. Especcially when the first install was done by extracting a zip or tarfile.
Anyway, now I removed and reinstalled. I think that should work as well.
dirkdedeur
Post by dirkdedeur »
sloeber70 wrote: Friday 14 November 2025 19:22 Got this far like last time... still same error:
See attached
@Sloeber 70 how did you solve the TADO LOCAL: Failed to connect to Zones Fetch: Connection refused (Status: 111) error?
