Tado Local and python plugin
rhuijben
I'm working on a more generic solution via a local mini REST api instead of relying on home assistant and gateways between them. Very early stage but already used in my Domoticz. See https://github.com/ampscm/TadoLocal
The repository contains the service and a Domoticz plugin using the service.
jannl
- Domoticz version: 2026.1.x
Re: Tado Thermostat plugin
Sounds promising, might give it a try soon
Tukker
- Domoticz version: 2023.2
I tried the install, but failed
tado-local --bridge-ip 192.168.2.2 --pin 123-45-678 --verbose
2025-11-05 15:33:22 INFO Verbose logging enabled
2025-11-05 15:33:22 DEBUG Using selector: EpollSelector
2025-11-05 15:33:22 ERROR ERROR: Failed to start Tado Local: no such column: d.is_zone_leader
2025-11-05 15:33:22 ERROR ERROR: no such column: d.is_zone_leader
Bugs bug me.
jannl
Here I get an error in Trixy on: pip install -e
Python version is 3.13.x
error: externally-managed-environment- waltervl
- Domoticz version: 2026.3
To use plugins in newer OS that uses Python virtual environments look at the instructions in https://zigbeefordomoticz.github.io/wik ... alEnv.html that a plugin author created. It is also mentioned in the wiki https://wiki.domoticz.com/Using_Python_plugins
So important to read both when it is the first time you use Python Plugins in Domoticz.
jannl
So I should use it inside the docker.
If you run Domoticz in a docker you should install a plugin always through the docker container. As described in the wiki https://wiki.domoticz.com/Docker#Python_Plugins In the container already a venv is enabled.
jannl
The error message is not the plugin but the rest api. I will update my customstart.sh. Which by the way runs in 2 minutes on a pi5 instead of the almost 10 on a pi 3b.
And installing...a new plugin is not more rhan copying the plugin files to the correct directory and restarting domoticz.
Yes, I meant installing the extra python modules that need to be installed fo a python plugin. The error you mentioned came from installing a module (for a python plugin...) But all is described on the wiki....
jannl
Got a bit further, but ran into an error already logged as an issue on github. We'll see.
sloeber70
- Domoticz version: latest
Installed the TadoLocal environment on my domoticz test system.
Local UI works fine on localhost:4402... and is getting changes when I alter a temperature set in Tado App... but setting a temperature setpoint from TadoLOcal does not work. Also I get errormsg : no leader device for zone...
Getting plugin in domoticz too... working... all devices are installed... But when trying to set a higher temperature for a zone: error
2025-11-10 14:07:03.101 Error: TadoLocal: Failed to connect to Zones Fetch: Connection refused (Status: 111)
2025-11-10 14:07:33.254 Error: TadoLocal: CConnection_disconnect, disconnection request from 'TadoLocal' ignored. Transport does not exist.
2025-11-10 14:07:33.364 Error: TadoLocal: CConnection_disconnect, disconnection request from 'TadoLocal' ignored. Transport does not exist.
What did I miss?
Python requirements for Domoticz plugins are OK....
tado-local output:
2025-11-10 14:11:29 INFO [E] Bureel | TargetTemperature: 20.5 -> 24
2025-11-10 14:11:35 INFO 10.10.3.114:49641 - "GET / HTTP/1.1" 200
2025-11-10 14:11:35 INFO 10.10.3.114:49641 - "GET /zones HTTP/1.1" 200
2025-11-10 14:11:35 INFO 10.10.3.114:50481 - "GET /events?types=zone HTTP/1.1" 200
2025-11-10 14:11:35 INFO 10.10.3.114:61449 - "GET /status HTTP/1.1" 200
2025-11-10 14:11:44 INFO POST /zones/4/set temperature=18.0 heating_enabled=True
2025-11-10 14:11:44 INFO 10.10.3.114:62824 - "POST /zones/4/set?temperature=18&heating_enabled=true HTTP/1.1" 400
2025-11-10 14:11:52 INFO [E] Slaapkamer | CurrentTemperature: 20.9 -> 20.8
2025-11-10 14:12:35 INFO 10.10.3.114:52954 - "GET /zones HTTP/1.1" 200
2025-11-10 14:13:08 INFO [E] Bureel | CurrentTemperature: 22.7 -> 22.8
2025-11-10 14:13:35 INFO 10.10.3.114:64970 - "GET /zones HTTP/1.1" 200
2025-11-10 14:14:11 INFO [E] Hall | CurrentTemperature: 21 -> 20.9
2025-11-10 14:14:35 INFO 10.10.3.114:55800 - "GET /zones HTTP/1.1" 200
2025-11-10 14:15:31 INFO [E] LivingHall | CurrentTemperature: 21.1 -> 21
2025-11-10 14:15:35 INFO 10.10.3.114:60354 - "GET /zones HTTP/1.1" 200
2025-11-10 14:16:35 INFO 10.10.3.114:56908 - "GET /zones HTTP/1.1" 200
2025-11-10 14:16:58 INFO [E] Slaapkamer | CurrentTemperature: 20.8 -> 20.7
2025-11-10 14:17:14 INFO [E] Keuken | CurrentTemperature: 20.8 -> 20.6
2025-11-10 14:17:35 INFO 10.10.3.114:58645 - "GET /zones HTTP/1.1" 200
2025-11-10 14:18:04 INFO [E] Badkamer | CurrentTemperature: 21.2 -> 21.1
2025-11-10 14:18:35 INFO 10.10.3.114:63567 - "GET /zones HTTP/1.1" 200
2025-11-10 14:20:04 INFO 10.10.3.114:65394 - "GET /zones HTTP/1.1" 200
2025-11-10 14:20:35 INFO 10.10.3.114:62049 - "GET /zones HTTP/1.1" 200
What did I miss?
tado-local output:
- 2025-11-10_14-20-33.jpg (279.05 KiB) Viewed 39896 times
Kind regards,
Sloeber70
Linux Debian 13 standard edition
Domoticz latest beta on ProxmoxVE Virtual Machine
Sloeber70
jannl
There is seperate TadoLocal topic and I think you better also create an issue on github.
manjh
- Domoticz version: 2025.2
Is there an overview somewhere showing which functionality TadoLocal offers?
In the screenshot it shows the different zones. I assume you can manually change temperatures.
But can you change the programming schedule? times/temperatures per day?
Hans
Re: Tado Local and python plugin
Splitted off from the original Tado integration topic.
This is the current functionality with the plugin:manjh wrote: Tuesday 11 November 2025 12:33 Is there an overview somewhere showing which functionality TadoLocal offers?
https://github.com/AmpScm/TadoLocal/blo ... /README.md
Tukker
Maybe I am too stupid for this.
What I did.
The python system was protesting, so I continued like this.
then another pip install -e .
and SUCCESS
Running setup.py develop for tado-local
Successfully installed tado-local-1.0.0a1
then
Authentication succeeded and another ~/TadoLocal $ tado-local --bridge-ip 192.168.2.2 --pin 123-45-678 -> same result
Any idea what I did wrong here?
What I did.
# Clone the repository
git clone https://github.com/ampscm/TadoLocal.git
cd TadoLocal
# Install (requires Python 3.11+)
pip install -e .Code: Select all
python3 -m venv venv
source venv/bin/activateand SUCCESS
then
(venv) (venv) pi@RPI4:~/TadoLocal $ tado-local --bridge-ip 192.168.2.2 --pin 123-45-678
2025-11-12 18:55:06 INFO Loaded 0 devices from cache
2025-11-12 18:55:06 INFO Loaded 0 zones from cache
2025-11-12 18:55:06 INFO Loaded latest state for 0 devices from database
2025-11-12 18:55:06 INFO Tado Cloud API: Starting authentication flow...
2025-11-12 18:55:06 INFO Started background cloud sync (4h battery, 24h config)
2025-11-12 18:55:06 INFO API authentication disabled (no TADO_API_KEYS configured)
2025-11-12 18:55:06 INFO No existing pairing found for specified IP: 192.168.2.2
2025-11-12 18:55:06 INFO Starting fresh pairing with 192.168.2.2 using PIN 488-89-183...
2025-11-12 18:55:06 INFO Starting controller-based pairing with 192.168.2.2:80 using PIN: 123-45-678
2025-11-12 18:55:06 INFO Using Controller ID: f780edf2-0605-4030-a02d-ec451f45f4cc
2025-11-12 18:55:06 INFO Starting fresh pairing with persistent controller f780edf2...
2025-11-12 18:55:06 INFO --- Trying approach: single_connection ---
2025-11-12 18:55:06 INFO Description: Keep connection open throughout
2025-11-12 18:55:06 INFO Requesting device authorization code from Tado...
2025-11-12 18:55:06 WARNING Overall attempt failed with approach single_connection, feature flags 0: step bytearray(b'\x02')
2025-11-12 18:55:06 INFO ======================================================================
2025-11-12 18:55:06 INFO TADO CLOUD API AUTHENTICATION REQUIRED
2025-11-12 18:55:06 INFO To connect to Tado Cloud API, please visit this URL:
2025-11-12 18:55:06 INFO https://login.tado.com/oauth2/device?user_code=GBQVVC
2025-11-12 18:55:06 INFO Your code: GBQVVC
2025-11-12 18:55:06 INFO (This code expires in 300 seconds)
2025-11-12 18:55:06 INFO Once authenticated, you see a success result here in the log. Polling for authorization...
2025-11-12 18:55:06 INFO You can also access this information via the web-ui or the /status endpoint:
2025-11-12 18:55:06 INFO curl http://localhost:4407/status
2025-11-12 18:55:06 WARNING Overall attempt failed with approach single_connection, feature flags 1: step bytearray(b'\x02')
2025-11-12 18:55:06 INFO --- Approach single_connection completed, trying next approach ---
2025-11-12 18:55:06 INFO --- Trying approach: reconnect_between_parts ---
2025-11-12 18:55:06 INFO Description: Reconnect between Part 1 and Part 2
2025-11-12 18:55:06 WARNING Overall attempt failed with approach reconnect_between_parts, feature flags 0: step bytearray(b'\x02')
2025-11-12 18:55:06 WARNING Overall attempt failed with approach reconnect_between_parts, feature flags 1: step bytearray(b'\x02')
2025-11-12 18:55:06 INFO --- Approach reconnect_between_parts completed, trying next approach ---
2025-11-12 18:55:06 ERROR ============================================================
2025-11-12 18:55:06 ERROR ALL PAIRING ATTEMPTS FAILED
2025-11-12 18:55:06 ERROR Tried approaches:
2025-11-12 18:55:06 ERROR - single_connection: Keep connection open throughout
2025-11-12 18:55:06 ERROR - reconnect_between_parts: Reconnect between Part 1 and Part 2
2025-11-12 18:55:06 ERROR Controller identity persisted: f780edf2-0605-4030-a02d-ec451f45f4cc
2025-11-12 18:55:06 ERROR Part 1 state may be saved - retry might resume from Part 2
2025-11-12 18:55:06 ERROR Possible issues:
2025-11-12 18:55:06 ERROR 1. Device is already paired to another HomeKit controller
2025-11-12 18:55:06 ERROR 2. Device is not in pairing mode
2025-11-12 18:55:06 ERROR 3. Wrong PIN code
2025-11-12 18:55:06 ERROR 4. Device needs to be reset/factory reset
2025-11-12 18:55:06 ERROR 5. Network connectivity issues
2025-11-12 18:55:06 ERROR 6. Device-specific pairing behavior not yet understood
2025-11-12 18:55:06 ERROR Troubleshooting steps:
2025-11-12 18:55:06 ERROR - Check if device is showing on other HomeKit controllers
2025-11-12 18:55:06 ERROR - Try factory resetting the device
2025-11-12 18:55:06 ERROR - Verify the PIN is correct from device label
2025-11-12 18:55:06 ERROR - Ensure device is in pairing mode
2025-11-12 18:55:06 ERROR - Retry - we'll attempt to resume from saved Part 1 state
2025-11-12 18:55:06 ERROR Controller-based pairing failed: All pairing attempts failed - see troubleshooting info above
File "/home/pi/TadoLocal/tado_local/bridge.py", line 541, in perform_pairing_with_controller
pairing_data = await TadoBridge.perform_fresh_pairing(host, port, hap_pin, controller_id, db_path)
File "/home/pi/TadoLocal/tado_local/bridge.py", line 355, in perform_fresh_pairing
raise Exception("All pairing attempts failed - see troubleshooting info above")
Exception: All pairing attempts failed - see troubleshooting info above
2025-11-12 18:55:06 ERROR Pairing failed with error: All pairing attempts failed - see troubleshooting info above
2025-11-12 18:55:06 ERROR Pairing failed: All pairing attempts failed - see troubleshooting info above
2025-11-12 18:55:06 ERROR ERROR: Failed to start Tado Local: All pairing attempts failed - see troubleshooting info above
2025-11-12 18:55:06 INFO Performing cleanup...
2025-11-12 18:55:06 INFO Stopping Tado Cloud API background tasks...
2025-11-12 18:55:06 INFO Background cloud sync task cancelled
2025-11-12 18:55:06 INFO Stopped background cloud sync task
2025-11-12 18:55:06 INFO Starting cleanup...
2025-11-12 18:55:06 INFO Cleanup complete
2025-11-12 18:55:06 INFO Shutdown complete. Process will exit in 3 seconds.
2025-11-12 18:55:06 ERROR ERROR: All pairing attempts failed - see troubleshooting info above
2025-11-12 18:55:09 WARNING Forcing process exit after 3 seconds to avoid lingering SSE connections.
Bugs bug me.
jorknu
Wow, I think I will set up a new container to give this a try.
I have been trying to come up with some python stuff (also using aiohomekit) and then trying to get that connected to C++ so it can be build into the existing integration. But with little time this seems like a futile attempt.
What I was wondering about:
I have 4-5 years of data in my database of the C++ implementation.
Is there anyway to "import" the old data into the new sensors generated by a python implementation?
I know I can always just make some SQL to get the data out of one sensor and then inject it back in another.
But I do not feel like hacking out the DB and then reloading it with modified content if I do not have to.
There are some API calls to add history data to a counter device https://wiki.domoticz.com/Domoticz_API/ ... n_counters
But adding data directly in the database is not big problem if you already know some sql. Also you will add the data in a meter or multimeter _calendar table that only stores summarized daily history data. So not much harm you can do there.
And with an application like SQLite DB browser you can add data from a prepared excel file. So you do not have to know SQL. You only have to stop Domoticz when adding data to prevent locking.
jannl
There is an issue regarding the pairing on github
And there seem to be some related changes in the plugin on the repository last few days so perhaps do a
git pull
in the plugin folder and test again...
git pull
