Last time I added temperature sensors, I did this through a mysensors gateway and sensebender Arduino-like little gizmos (https://www.mysensors.org/hardware/micro). This stuff has been running on Domoticz on a Linux machine for years. Fast forward several years and I'd like to add more, but I think the Mysensors approach is dated and would like to add something that is more modern.
What would you suggest? I don't want to invest too much time in this. What gateway & temperature sensor option would do the job as simple as possible?
Easiest path to add temperature sensors/monitors
jannl
- Domoticz version: 2025.5.x
Re: Easiest path to add temperature sensors/monitors
I would say start with zigbee (zigbee2mqtt) and buy compatible zigbee sensors.
