Easiest path to add temperature sensors/monitors
zuru
Post by zuru »
Last time I added temperature sensors, I did this through a mysensors gateway and sensebender Arduino-like little gizmos (https://www.mysensors.org/hardware/micro). This stuff has been running on Domoticz on a Linux machine for years. Fast forward several years and I'd like to add more, but I think the Mysensors approach is dated and would like to add something that is more modern.
What would you suggest? I don't want to invest too much time in this. What gateway & temperature sensor option would do the job as simple as possible?
jannl
Domoticz version: 2026.1.x
Re: Easiest path to add temperature sensors/monitors
Post by jannl »
I would say start with zigbee (zigbee2mqtt) and buy compatible zigbee sensors.
scommed12
Post by scommed12 »
I’d agree Zigbee is probably the simplest path now, especially with Zigbee2MQTT being pretty mature. Setup is fairly straightforward, and there are lots of inexpensive sensors that just work without much tinkering.
gizmocuz
Post by gizmocuz »
Zigbee with Zigbee2MQTT is pretty great! Sensors are not expensive on AliExpress or Temu or other home automation stores.
The only downside is if you have sensors with a little CR 2032 battery, you need to change them every year.
If you can find sensors that fit 2 AA/AAA batteries that is even better.
If you want to be experimental you can connect/solder a larger battery (parallel) to the sensor hardware
Another way I also use on some very far places is a ESP32 with a THB sensor that publishes to MQTT (Auto Discovery protocol) and is connected to a USB charger (230V), it is inside a ugly box but it serves it's purpose.
Do get a Temp+Hum+Baro (and with Zigbee you sometimes get a Lux sensor as well)
Domoticz version: 2026.3
I have some battery sensors on CR2032 running for 4 years or longer. But the newer AA/AAA powered sensors are more indeed more reliable (or the hardware inside is getting better over the years)
Menno
Post by Menno »
Maybe also already dated: I use a couple of ESP8266 microcontrollers with sensors, they run ESPEasy, which is specifically tailored for use with Domoticz. Downside is: they are not practical to run on batteries, as they are to power hungry.
More recently I have used the cheap Xiaomi temperature sensors that work over Bluetooth.
I use a script to read them. They use CR2032 batteries that last approximately a year, depending on how often your script connects to them.
woodyvjh
Domoticz version: last
Post by woodyvjh »
used domoticz on rpi2 with espeasy, I lost the settings during the update, and now I am not able to set up espeasy because the links in the manual are not working. Could someone help me set up espeasy.
Thank you
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
Running on AAA batteries, including a display: https://nl.aliexpress.com/item/1005011964861654.html
Running on CR2450 ( >5 year batterylife): https://nl.aliexpress.com/item/1005009085628701.html
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
azonneveld
woodyvjh wrote: Friday 29 May 2026 16:01 used domoticz on rpi2 with espeasy, I lost the settings during the update, and now I am not able to set up espeasy because the links in the manual are not working. Could someone help me set up espeasy.
Thank you
You had your setup running before, therefor I assume you know your way around in espeasy. The setup on an ESP has changed tough.
It's webbased now, works well.
install espeasy
RNEE
Post by RNEE »
I started long time ago and have now KAKU, Milight, Wifi and Zigbee. Each has pro and con's.
I like the Zigbee most, because it builds a strong growing network with cheap parts.
The cheap Chinese sensors, and lights, from Aliexpress as mentioned before work great and last a long time.
Currently migrating and extending (nearly) everything to Zigbee.
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek Homebattery 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|
