ZWA-2 in Domoticz
Frisk
ZWA-2 in Domoticz
Post by Frisk »
I've been running Domoticz quite a time now and for a couple of years thought about upgrading my Aeotec Z-stick 5 to something new. Recently saw the home assistant/nabu casa ZWA-2 which seems very promising and working with zwave-js. Will this just work together with Domoticz as well or are there something "special"about this make it just work with HA and not "general" zwave-js. I don't get any hits at all searching compatibility with Domoticz or zwave-js general.
I'll soon move from my old raspberry pi 3 with open z-wave to an pi5, seems like the right time to swap the stick as well if it is gonna be changed.
Domoticz version: 2026.3
Re: ZWA-2 in Domoticz
If it works with Zwave-JS-UI it will also work with Domoticz as Domoticz uses Zwave-JS-UI now for zwave devices. For Domoticz it is irrelevant what zwave hardware is connected to Zwave-JS-UI.
The old OpenZwave integration is indeed going to be deprecated.
Frisk
Post by Frisk »
Thanks for a really fast reply!
I thought it should work but wasn't sure if we might be some link of any kind that would make problems.
My setup has got all to little attention lately, just kept it alive at a minimum. When I put the effort to leave OpenZwave I'm also hoping to clean up a bit, change to newer pi (which handles later versions on of MongoDB, of other reasons) upgrade ZWave interface and maybe other hardware etc.
hjzwiers
Post by hjzwiers »
I just installed one ZWA-2, and it works just as any other in Zwave JS UI, just restore your NVM and its up and running
Frisk
Post by Frisk »
hjzwiers wrote: Tuesday 19 August 2025 18:48 I just installed one ZWA-2, and it works just as any other in Zwave JS UI, just restore your NVM and its up and running
Perfect! Thanks for the feedback. I think its finally time to upgrade!
user4563
Domoticz version: 2026.4
Post by user4563 »
I'm thinking of upgrading to the ZWA-2 as well to upgrade from Z-Wave 500 to Z-Wave 800. We're you able to toggle the LED off on the ZWA-2?
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
hjzwiers
Post by hjzwiers »
I didn't toggle the LED
user4563
Post by user4563 »
hjzwiers wrote: Thursday 04 September 2025 13:55 I didn't toggle the LED
Do you mind checking in zwave-js-ui if this toggle option is available?
I don't mind the size of the zwa-2 but the huge light at the top I definitely would like to toggle off.
hjzwiers
Post by hjzwiers »
You can toggle the light off in the menu.
user4563
Post by user4563 »
Thank you for checking!
