ZWA-2 in Domoticz
Frisk
ZWA-2 in Domoticz
I've been running Domoticz quite a time now and for a couple of years thought about upgrading my Aeotec Z-stick 5 to something new. Recently saw the home assistant/nabu casa ZWA-2 which seems very promising and working with zwave-js. Will this just work together with Domoticz as well or are there something "special"about this make it just work with HA and not "general" zwave-js. I don't get any hits at all searching compatibility with Domoticz or zwave-js general.
I'll soon move from my old raspberry pi 3 with open z-wave to an pi5, seems like the right time to swap the stick as well if it is gonna be changed.
- Domoticz version: 2026.3
Re: ZWA-2 in Domoticz
If it works with Zwave-JS-UI it will also work with Domoticz as Domoticz uses Zwave-JS-UI now for zwave devices. For Domoticz it is irrelevant what zwave hardware is connected to Zwave-JS-UI.
The old OpenZwave integration is indeed going to be deprecated.
Frisk
Thanks for a really fast reply!
I thought it should work but wasn't sure if we might be some link of any kind that would make problems.
My setup has got all to little attention lately, just kept it alive at a minimum. When I put the effort to leave OpenZwave I'm also hoping to clean up a bit, change to newer pi (which handles later versions on of MongoDB, of other reasons) upgrade ZWave interface and maybe other hardware etc.
hjzwiers
I just installed one ZWA-2, and it works just as any other in Zwave JS UI, just restore your NVM and its up and running
Frisk
Perfect! Thanks for the feedback. I think its finally time to upgrade!hjzwiers wrote: Tuesday 19 August 2025 18:48 I just installed one ZWA-2, and it works just as any other in Zwave JS UI, just restore your NVM and its up and running
- user4563
- Domoticz version: 2026.4
I'm thinking of upgrading to the ZWA-2 as well to upgrade from Z-Wave 500 to Z-Wave 800. We're you able to toggle the LED off on the ZWA-2?hjzwiers wrote: Tuesday 19 August 2025 18:48 I just installed one ZWA-2, and it works just as any other in Zwave JS UI, just restore your NVM and its up and running
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
hjzwiers
I didn't toggle the LED
- user4563
Do you mind checking in zwave-js-ui if this toggle option is available?
I don't mind the size of the zwa-2 but the huge light at the top I definitely would like to toggle off.
hjzwiers
You can toggle the light off in the menu.
- user4563
Thank you for checking!
