SolarEdge production throttling from Domoticz
jvdz
Domoticz version: 4.107
Re: SolarEdge production throttling from Domoticz
Post by jvdz »
Did some GITHUB Branches cleanup and updated this in the first post at the bottom:
There are currently 3 Branches:
Original Master (v1.2.3) updated with the active_power_limit Dimmer&Sync option:
https://github.com/jvanderzande/domotic ... tcp-plugin
Original METERS (v2.0.4) updated with the active_power_limit Dimmer&Sync option:
https://github.com/jvanderzande/domotic ... ree/meters
Development based on my meters branch using the latest solaredge_modbus and Selector Switches for Battery modes:
https://github.com/jvanderzande/domotic ... /MetersDev
Documentation still needs work, but that will happen too someday when development is done. :D
jannl
Domoticz version: 2025.5.x
Post by jannl »
Anyone did any checks on the net solarpower? The modbua valua is the AC value, as soon as the battery is being charges the value does not add up. Compare it to the value in the app (but remember it is a lot slower).
For now I use a lua script based on the battery being charged or not, the meter values ans the ev charger power for which I now have a very small plugin that only reads 1 modbua value from the charger.
imautohuttraeger
Domoticz version: 2025.1
Post by imautohuttraeger »
jannl wrote: Wednesday 18 June 2025 19:14 Anyone did any checks on the net solarpower? The modbua valua is the AC value, as soon as the battery is being charges the value does not add up. Compare it to the value in the app (but remember it is a lot slower).
That's why getting these two devices would be excellent to have:
Pure solar production (not the net value)
Pure battery charge / discharge
Unfortunately I can't test it currently (traveling).
jannl
Post by jannl »
I can and the pure solar productuon is not a modbus value. So as ling as youbdon't charge a battery it is not problem.
imautohuttraeger
Will soon be back from traveling on the job. So I hope to find some time next week to install and test. Is MetersDev the correct branch to take? Can I install it in parallel or will it overwrite the existing Hardware in Domoticz? Do I have to observe anything on top of the original instructions on Github?
Sorry, I am not really savy with it ...
jvdz
Post by jvdz »
Just have a look at my first post in this thread which is updated with the latest Status.
I don't know if you can run multiple instances of the plugin on your setup, but i couldn't and had to add any extra docker container that performs the role of modbus proxy after which i can run multiple.
For each change you will have to Perform the pip command to update the docker with the requirement.txt content.
I have added the required command to customstart.sh :
  pip3 install -r /opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/requirements.txt
so it is done with each creation of the domoticz container.
I am hoping that somebody with an battery installation can give me some feedback on the MetersDev branch whether or not those Selector switched work and are usefull.
imautohuttraeger
Sorry, that i took so long. Finally now I have de-installed the current master and installed the MetersDev Branch. There are more devices now including the dimmer switch - see Screenshot. But there is no batterie.
Do I use the correct versions?
Version: 0.8.0
Version: 3.6.9
jvdz
Post by jvdz »
You will have to change the logging to debug and then save the hardware which will restart the plugin. A lot of messages will capture in the domoticz log. Please send that log to my email address and then change the logging back to normal.
imautohuttraeger
jvdz wrote: Wednesday 02 July 2025 9:15 You will have to change the logging to debug and then save the hardware which will restart the plugin. A lot of messages will capture in the domoticz log. Please send that log to my email address and then change the logging back to normal.
Just have sent you a PM with the log data (don't know your email).
1kke
Post by 1kke »
In docker Domoticz :latest and :beta (Version: 2025.1 (build 16758) Build Hash: 79e16c172) the plugin doesn't run anymore:
2025-08-13 10:27:06.803 Error: Inverter: (SolarEdge_ModbusTCP) failed to load 'plugin.py', Python Path used was '/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/opt/venv/lib/python3.11/site-packages:/opt/venv/local/lib/python3.11/dist-packages:/opt/venv/lib/python3/dist-packages:/opt/venv/lib/python3.11/dist-packages'.
2025-08-13 10:27:07.012 Error: Inverter: Traceback (most recent call last):
2025-08-13 10:27:07.012 Error: Inverter: File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 60, in <module>
2025-08-13 10:27:07.012 Error: Inverter: import solaredge_modbus
2025-08-13 10:27:07.012 Error: Inverter: File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/solaredge_modbus/__init__.py", line 6, in <module>
2025-08-13 10:27:07.012 Error: Inverter: from pymodbus.constants import Endian
2025-08-13 10:27:07.012 Error: Inverter: ModuleNotFoundError: No module named 'pymodbus'
With :2025-beta.16756 the plugin runs again normally.
eddieb
Post by eddieb »
Yeah, same here on my docker based system
2025-08-07 11:25:05.067  Error: Solaredge: Call to function 'onHeartbeat' failed, exception details:
2025-08-07 11:25:05.076  Error: Solaredge: Traceback (most recent call last):
2025-08-07 11:25:05.076  Error: Solaredge:   File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 928, in onHeartbeat
2025-08-07 11:25:05.076  Error: Solaredge:     _plugin.onHeartbeat()
2025-08-07 11:25:05.076  Error: Solaredge:   File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 279, in onHeartbeat
2025-08-07 11:25:05.076  Error: Solaredge:     self.processValues(device_details, values)
2025-08-07 11:25:05.076  Error: Solaredge:   File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 316, in processValues
2025-08-07 11:25:05.076  Error: Solaredge:     value = self.getUnitValue(unit, inverter_data)
2025-08-07 11:25:05.076  Error: Solaredge:             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-08-07 11:25:05.076  Error: Solaredge:   File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 406, in getUnitValue
2025-08-07 11:25:05.076  Error: Solaredge:     value = inverter_data[row[Column.MODBUSNAME]]
2025-08-07 11:25:05.076  Error: Solaredge:             ~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^
2025-08-07 11:25:05.076  Error: Solaredge: KeyError: 'status'
2025-08-12 22:16:57.210  Error: Solaredge: (SolarEdge_ModbusTCP) failed to load 'plugin.py', Python Path used was '/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/opt/venv/lib/python3.11/site-packages:/opt/venv/local/lib/python3.11/dist-packages:/opt/venv/lib/python3/dist-packages:/opt/venv/lib/python3.11/dist-packages'.
2025-08-12 22:16:57.408  Error: Solaredge: Traceback (most recent call last):
2025-08-12 22:16:57.408  Error: Solaredge:   File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 60, in <module>
2025-08-12 22:16:57.408  Error: Solaredge:     import solaredge_modbus
2025-08-12 22:16:57.408  Error: Solaredge:   File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/solaredge_modbus/__init__.py", line 6, in <module>
2025-08-12 22:16:57.408  Error: Solaredge:     from pymodbus.constants import Endian
2025-08-12 22:16:57.408  Error: Solaredge: ModuleNotFoundError: No module named 'pymodbus'
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
jvdz
Post by jvdz »
What is returned when you run this command via customstart.sh?:
This should install the required modules.
1kke
Post by 1kke »
I think it has to do with:
gizmocuz wrote: Tuesday 12 August 2025 16:20 Could you update to the latest docker to see if that solved the issue?
The build system is now using a schroot bookwork build environment (it was updated to Trixy)
1kke
Post by 1kke »
jvdz wrote: Wednesday 13 August 2025 10:43 What is returned when you run this command via customstart.sh?:
Launch: Running customstart.sh
domoticz  | /opt/venv/bin/python: error while loading shared libraries: libpython3.13.so.1.0: cannot open shared object file: No such file or directory
1kke
Post by 1kke »
I think those images have a corrupt venv so only @gizmocuz could solve this I think.
eddieb
Post by eddieb »
These are the errors I get on stop/start domoticz docker
2025-08-13 11:19:37.975  Error: Solaredge: (SolarEdge_ModbusTCP) failed to load 'plugin.py', Python Path used was '/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/opt/venv/lib/python3.11/site-packages:/opt/venv/local/lib/python3.11/dist-packages:/opt/venv/lib/python3/dist-packages:/opt/venv/lib/python3.11/dist-packages'.
2025-08-13 11:19:38.020  Error: Solaredge: Traceback (most recent call last):
2025-08-13 11:19:38.020  Error: Solaredge:   File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/plugin.py", line 60, in <module>
2025-08-13 11:19:38.020  Error: Solaredge:     import solaredge_modbus
2025-08-13 11:19:38.020  Error: Solaredge:   File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/solaredge_modbus/__init__.py", line 6, in <module>
2025-08-13 11:19:38.020  Error: Solaredge:     from pymodbus.constants import Endian
2025-08-13 11:19:38.020  Error: Solaredge: ModuleNotFoundError: No module named 'pymodbus'
eddieb
Post by eddieb »
and this is the error while inside the container trying to upgrade requirements
python3 -m pip install -r requirements.txt --upgrade
python3: error while loading shared libraries: libpython3.13.so.1.0: cannot open shared object file: No such file or directory
1kke
Post by 1kke »
I think libpython3.13 indicates a python3.13 venv while python3.11 is installed in the image.
gizmocuz
Post by gizmocuz »
This is quite odd as there is no reference to 3.11 in the Dockerfile... 3.13 should be installed
eddieb
Post by eddieb »
I just did an apt upgrade on the rpi5 and my system still says
root@domoticz2:/opt/stacks/domoticz/config# python3 -V
Python 3.11.2
# apt info python3
Package: python3
Version: 3.11.2-1+b1
Priority: optional
Section: python
Source: python3-defaults (3.11.2-1)
Maintainer: Matthias Klose <[email protected]>
Installed-Size: 82.9 kB
Provides: python3-profiler, python3-supported-max (= 3.11), python3-supported-min (= 3.11)
Pre-Depends: python3-minimal (= 3.11.2-1+b1)
Depends: python3.11 (>= 3.11.2-1~), libpython3-stdlib (= 3.11.2-1+b1)
Suggests: python3-doc (>= 3.11.2-1+b1), python3-tk (>= 3.11.2-1~), python3-venv (>= 3.11.2-1+b1)
Replaces: python3-minimal (<< 3.1.2-2)
Homepage: https://www.python.org/
Tag: devel::interpreter, devel::lang:python, devel::library,
 implemented-in::c, implemented-in::python, role::devel-lib,
 role::program, role::shared-lib
Download-Size: 26.3 kB
APT-Manual-Installed: no
APT-Sources: http://deb.debian.org/debian bookworm/main arm64 Packages
Description: interactive high-level object-oriented language (default python3 version)
 Python, the high-level, interactive object oriented language,
 includes an extensive class library with lots of goodies for
 network programming, system administration, sounds and graphics.
 This package is a dependency package, which depends on Debian's default
 Python 3 version (currently v3.11).
