energy dashboard P1 LAN not working
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
steve01
- Domoticz version: V4.7900
I cant get a reading of electricity on the energy dashboard.
At the settings for energy dashboard I can not select the device at P1/Grid can only choose disabled. any ideas?
steve01
Re: energy dashboard P1 LAN not working
- energy dashboard2.JPG (91.72 KiB) Viewed 1404 times
- Domoticz version: 2025.1
Do you have devices activated for the P1 Hardware devices?
Can you show a list of the P1 devices in menu Setup - Devices?
steve01
sure thing;
- jvdz
- Domoticz version: 4.107
Why do you have that P1 device selected for Solar?
Think you should remove that and then check the dropdown for P1, which should contain Power (IDX 14)
- RonkA
I see IDX 14 is set to unused(the little green arrow) click this to 'Add device'
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
steve01
Thanks RonkA,
Got a reading from the grid now, nice. Too bad the solar still reads 0 KW, according to the app of my inverter it should read 313W now.
In energy dashboard I have at Solar: Actual delivery L1+L2+L3.
At devices I cannot find the delivery of the solar inverter
- jvdz
Did you expect that reading from your p1?
You need to connect your solar inverter to domoticz first to be able to get those readings.
steve01
Eh yes, how else does my energy company know how much power I return to the grid with solar? I only knows my P1 data
- RonkA
It seems your house has some serious power-balance issues.
As i can see from your screenshot you have a 1 fase inverter connected to L2, the majority of your power-consumtion is done on that fase also..
I assume your house was 1-fase that was upgraded to 3-fase to use 3-fase electric stove or somehing like that..
This can become an issue if the load on the fase spikes or drops the voltage outside the specification of 10% more or less than 230V..
Anyhoe.. Your inverter has to talk to Domoticz to tell it how much power it's producing.
This value minus the actual usage of your house gives the value the P1 meter wil show.. P1 meter doesn't care about your solar (or battery's) , it just sees how much current, and in what direction, is flowing trough it.
So..Find out how to get the values from your inverter into Domoticz...
steve01
Ok, bedankt RonkARonkA wrote: Monday 09 June 2025 13:01 It seems your house has some serious power-balance issues.
Bovenstaande klopt inderdaad, tot op heden geen problemen met de netspanning dus laat het ff zo. Ik ga eens uitzoeken hoe ik mn Solax X1 aan Domoticz kan koppelen
mvg
