Enever null values for next day results in an incomplete chart
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
jvdk
Sometimes the values from Enever have null values as shown below:
"datum": "2025-02-19 01:00:00",
"prijs": "0.099700",
"prijsANWB": "0.277377",
"prijsBE": "0.264487",
"prijsEE": "0.265277",
"prijsEN": "0.269137",
"prijsEVO": "0.277377",
"prijsEZ": "0.277377",
"prijsFR": "0.261697",
"prijsGSL": "0.277377",
"prijsMDE": "0.277377",
"prijsNE": "0.265397",
"prijsTI": "0.268302",
"prijsVDB": "0.265377",
"prijsVON": "0.263462",
"prijsWE": "0.268397",
"prijsZG": "0.277377",
"prijsZP": "0.263497"
"datum": "2025-02-19 02:00:00",
"prijs": null,
"prijsANWB": null,
"prijsBE": null,
"prijsEE": null,
"prijsEN": null,
"prijsEVO": null,
"prijsEZ": null,
"prijsFR": null,
"prijsGSL": null,
"prijsMDE": null,
"prijsNE": null,
"prijsTI": null,
"prijsVDB": null,
"prijsVON": null,
"prijsWE": null,
"prijsZG": null,
"prijsZP": null
"datum": "2025-02-19 03:00:00",
"prijs": "0.097670",
"prijsANWB": "0.274921",
"prijsBE": "0.262031",
As a result the chart stops at 01:00 hours:
Is there something I can do to solve this?
Regards,
Jan
"prijs": null,
"prijsANWB": null,
"prijsBE": null,
"prijsEE": null,
"prijsEN": null,
"prijsEVO": null,
"prijsEZ": null,
"prijsFR": null,
"prijsGSL": null,
"prijsMDE": null,
"prijsNE": null,
"prijsTI": null,
"prijsVDB": null,
"prijsVON": null,
"prijsWE": null,
"prijsZG": null,
"prijsZP": null
Regards,
Jan
- Domoticz version: 2025.1
Re: Enever null values for next day results in an incomplete chart
See the advise I also gave in another topic on this subject: contact Enever why they do this.... Perhaps they are not aware.
viewtopic.php?t=43181
jvdk
I just sent a message to Enever about this problem. I hope that helps.
It might be great, however, if Domoticz could handle these missing values.
Regards,
Jan
Regards,
Jan
Enever also has a Forum so perhaps post the bug report for Null values there too https://enever.nl/forums/
jvdk
I tried to post the problem to the Enever forum, but all forums are closed, so no posting is possible.
HvdW
- Domoticz version: 2023.2
At what time are you reading the data.
Enever writes in its website that the data for tomorrow are published at 15:00 and if not at 16:00 utmost.
Bugs bug me.
ricvee
- Domoticz version: Stable
I am having the same problem.
I just did send a message to Enever, hoping that they can and will fix it.
ricvee
I deleted the Enever hardware, and added it again.
Now there are only 3 new devices added, not the one for Actual Electricity Price:
ricvee
Answer from Enever:
No, that's something that the developers from the plugin for Domoticz should fix.
So the Enever-plugin is useless for me now ( I am using the latest Stable Version: 2024.7).
Is there someone that can and will fix this?
Make a GitHub issue related to this forum topic and hope someone can fix this (Domoticz is opensource software...)
jvdk
I use the "Domoticz built-in Enever "hardware". I do not know when it is updated exactly, but normally the values for the next day are available in Domoticz after 15.00 hours.HvdW wrote: Wednesday 19 February 2025 15:08 At what time are you reading the data.
jvdk
I just did.waltervl wrote: Thursday 20 February 2025 22:43 Make a GitHub issue related to this forum topic and hope someone can fix this (Domoticz is opensource software...)
Regards,
Jan
Edit Waltervl: the issue: https://github.com/domoticz/domoticz/issues/6265
HvdW
What might be your problem is that most of the time 1 or 2 suppliers didn't deliver their values, so your choice has NIL values.
These are the values for today.
I solved it by calculating the average value per hour of the data provided.
Bugs bug me.
Looking at the first topic it seems enever sometimes shows null for all suppliers on a specific timeslot.
and null should perhaps be interpreted as 0 (zero). Or as the same value from the hour before (if that also is not null...)
"prijs": null,
"prijsANWB": null,
"prijsBE": null,
"prijsEE": null,
"prijsEN": null,
"prijsEVO": null,
"prijsEZ": null,
"prijsFR": null,
"prijsGSL": null,
"prijsMDE": null,
"prijsNE": null,
"prijsTI": null,
"prijsVDB": null,
"prijsVON": null,
"prijsWE": null,
"prijsZG": null,
"prijsZP": null
jvdk
It will be solved in the next beta release. See https://github.com/domoticz/domoticz/issues/6265
