Enever NULL values cause time shift in Enever_Electricity_tomorrow variable
msnep
Domoticz version: 2024.7
Post by msnep »
Hi, I've been using the Enever price feed for several months and I automate stuff based on the price. Perfect.
However, recently I noticed sometimes that there's something wrong with the timing of my automations.
After investigating I found that the Enever price feed for tomorrow (9-Feb-2025) has NULL values for 05:00 and 06:00 for all suppliers. (via https://enever.nl/api/stroomprijs_morgen.php?token=abc), like this for 05:00:
"datum": "2025-02-09 05:00:00",
"prijs": null,
"prijsANWB": null,
"prijsBE": null,
"prijsEE": null,
"prijsEN": null,
"prijsEVO": null,
"prijsEZ": null,
"prijsFR": null,
"prijsGSL": null,
"prijsMDE": null,
"prijsNE": null,
"prijsTI": null,
"prijsVDB": null,
"prijsVON": null,
"prijsWE": null,
"prijsZG": null,
"prijsZP": null
However, Domoticz doesn't seem to check the time-stamp in the JSON: there are 22 price points from 0:00 till 21:00 in the variable Enever_Electricity_tomorrow. And I use this variable as the basis for my automations.
So in the variable 22:00 and 23:00 are missing, instead of 05:00 and 06:00.
The price at 07:00 became 05:00 in the variable, 08:00 --> 06:00, etc. and therefore my automation timings are off by 2 hours.
Does anybody else experience this? Or should I skip the variable/Domoticz functionality and read from Enever directly?
(Domoticz 2024.7 on RPi)
Domoticz version: 2025.1
Re: Enever NULL values cause time shift in Enever_Electricity_tomorrow variable
Better report this to Enever so that this situation is not happening. Probably a glitch on their side.
msnep
Post by msnep »
I reported it to Enever.
Note - I checked a few different places for the electricity prices (anwb, tibber, and epexspot.com) and noticed that 4 - 5 - 6:00 has the exact same price today. It could mean that 5 and 6 were duplicated from 4 due to missing data, but who knows.
msnep
Post by msnep »
Tomorrow it's the same thing again (10-Feb-2025).
I think that the handling by Domoticz is not "ideal", because due to the null values all following prices are incorrect in Domoticz' variable. It would be Ok if the data from Enever was taken 1 on 1, in my opinion.
I am probably going to read directly from Enever because then I can handle the null values. Hopefully it will eventually be fixed at the source.
HvdW
Domoticz version: 2023.2
Post by HvdW »
Pity that it stopped.
I have a dzVents script that relies on the Enever plugin.
I have this script that runs in the background and it returns the data correctly.
        timer = { 'at 00:05' }, -- a new day yesterday, is an old day now
        httpResponses = { 'EnergyPricesTodayReceived' }
    logging = {
        level = domoticz.LOG_INFO,
        marker = 'EnergyPricesToday'
        local energyProviders = {
            --prijs = "Beurs",
            AA = "Atoom Alliantie",
            AIP = "All in power",
            ANWB = "ANWB Energie",
            BE = "Budget Energie",
            EE = "EasyEnergy",
            EN = "Eneco",
            EVO = "Energie van Ons",
            EZ = "Energy Zero",
            FR = "Frank Energie",
            GSL = "Groenestroom Lokaal",
            MDE = "Mijndomein Energie",
            NE = "NextEnergy",
            TI = "Tibber",
            VDB = "Vandebron",
            VON = "Vrij op naam",
            WE = "Wout Energie",
            ZG = "ZonderGas",
            ZP = "Zonneplan"
        if (item.isTimer) then
            domoticz.log('Starting energy prices update', domoticz.LOG_INFO)
            -- Doe het API verzoek
            domoticz.openURL({
                url = 'https://enever.nl/api/stroomprijs_vandaag.php?token=<your_token',
                method = 'GET',
                callback = 'EnergyPricesTodayReceived'
        elseif (item.isHTTPResponse) then
            domoticz.log('Processing HTTP response', domoticz.LOG_INFO)
            if (item.ok) then
                local data = item.json
                if data.status == "true" then
                    -- Open het CSV-bestand om te schrijven
                    local file = io.open("/home/pi/Energy_Prices_Today.csv", "w")
                    if file then
                        -- Schrijf de header naar het bestand
                        file:write("Afkorting,Provider,00:00,01:00,02:00,03:00,04:00,05:00,06:00,07:00,08:00,09:00,10:00,11:00,12:00,13:00,14:00,15:00,16:00,17:00,18:00,19:00,20:00,21:00,22:00,23:00\n")
                        -- Schrijf de data voor elke provider
                        for provider, name in pairs(energyProviders) do
                            file:write(provider .. "," .. name)
                            for _, hour in ipairs(data.data) do
                                file:write(string.format(",%s", hour["prijs" .. provider]))
                            file:write("\n")
                        -- Add another line with timestamp
                        local timestamp = os.date("%Y%m%d %H:%M")
                        file:write(string.format("Updated,%s\n", timestamp))
                        file:close()
                        domoticz.log('Energy prices saved to Energy_Prices_Today.csv', domoticz.LOG_INFO)
                        domoticz.log('ERROR: Could not open Energy_Prices_Today.csv for writing', domoticz.LOG_ERROR)
                    domoticz.log('ERROR: Invalid response from API', domoticz.LOG_ERROR)
                domoticz.log('ERROR: HTTP request failed', domoticz.LOG_ERROR)
Bugs bug me.
HvdW wrote: Monday 10 February 2025 12:05 Pity that it stopped.
I have a dzVents script that relies on their figures.
Who said that it stopped? It seems Enever only supplies some strange values sometimes ... Or do I miss something?
msnep
Post by msnep »
Thanks for the update!
The fix is the same as how I had fixed it temporarily (taking the price of the hour before) - I'm happy with the solution.
hjzwiers
Post by hjzwiers »
I ran your script, but i get back "Could not open Energy_Prices_Today.csv for writing" ok that is clear.
het is al gelukt!
Greetings
