Sorry what do you mean?DiaDomo wrote: Friday 09 August 2024 20:33 @rron: please post this screenshot:and 2 from smartevse without detailed information.
SmartEvse support
rron
Re: SmartEvse support
DiaDomo
You said earlier that you also would send a screenshot with the MQTT settings of the SmartEVSE interface, but you didn't send this one yet.
Raspberry PI 2 & 3 & 4 | RFlink | MySensors | ESP32 | Homebridge | Tasmota Sonoff | Zigbee2Mqtt | ADS-B
rron
This is the only setting
- Schermafdruk van 2024-08-09 21-33-25.png (116.58 KiB) Viewed 2942 times
FlyingDomotic
- Domoticz version: 2020.2
thanks!rron wrote: Friday 09 August 2024 19:48There ' s no further information in the mqtt explorer. I have made 2 screenshots from the explorer, 1 from zigbee2mqtt with information and 2 from smartevse without detailed information.FlyingDomotic wrote: Friday 09 August 2024 19:26 Idea is to use a tool (like MQTT Explorer) to extract data from MQTT topic "SmartEVSE-5572" and copy it here.
Let's try with:
"SmartEVSE charge current": {
"topic": "[MQTTprefix]/ChargeCurrent",
"type": "243", "subtype": "23", "switchtype": "0",
"mapping": {"item": "", "multiplier": 0.1}
"SmartEVSE max current": {
"topic": "[MQTTprefix]/MaxCurrent",
"SmartEVSE state": {
"topic": "[MQTTprefix]/State",
"type": "243", "subtype": "19", "switchtype": "0",
"mapping": {"item": ""}
"SmartEVSE error": {
"topic": "[MQTTprefix]/Error",
"type": "244", "subtype": "73", "switchtype": "18",
"options": {"SelectorStyle":"1", "LevelOffHidden": "false", "LevelNames":"None|No Power Available|Communication Error|Temperature High|EV Meter Comm Error|RCM Tripped|Waiting for Solar|Test IO|Flash Error|**Unknown**"},
"mapping": {"item": "", "default": "90",
"values": {
"None": "0",
"No Power Available": "10",
"Communication Error": "20",
"Temperature High": "30",
"EV Meter Comm Error": "40",
"RCM Tripped": "50",
"Waiting for Solar": "60",
"Test IO": "70",
"Flash Error": "80",
"**Unknown**": "90"
"SmartEVSE charge current override": {
"topic": "[MQTTprefix]/ChargeCurrentOverride",
"type": "242", "subtype": "1", "switchtype": "0",
"options": {"ValueStep": "1", "ValueMin": "0", "ValueMax": "200", "ValueUnit": "A"},
"initial": {"nvalue": "0", "svalue": "0"},
"mapping": {"item": "", "multiplier": 0.1},
"set": {"topic": "[MQTTprefix]/Set/CurrentOverride", "digits": 0}
Don't hesitate to ask for help if needed.
rron
Yes, this fully working. Thank you very much. I now can try to add some indicators myself. Again thank you for all the effort.
rron
2024-08-10 11:53:04.258 Error: mapper: No SET parameters for SmartEVSE charge current/SmartEVSE-5572/ChargeCurrent in ('SmartEVSE charge current', {'topic': 'SmartEVSE-5572/ChargeCurrent', 'type': '243', 'subtype': '23', 'switchtype': '0', 'mapping': {'item': '', 'multiplier': 0.1}})
2024-08-10 11:53:27.780 Error: mapper: No SET parameters for SmartEVSE state/SmartEVSE-5572/State in ('SmartEVSE state', {'topic': 'SmartEVSE-5572/State', 'type': '243', 'subtype': '19', 'switchtype': '0', 'mapping': {'item': ''}})
2024-08-10 11:53:37.623 Error: mapper: No SET parameters for SmartEVSE max current/SmartEVSE-5572/MaxCurrent in ('SmartEVSE max current', {'topic': 'SmartEVSE-5572/MaxCurrent', 'type': '243', 'subtype': '23', 'switchtype': '0', 'mapping': {'item': '', 'multiplier': 0.1}})
2024-08-10 11:53:54.493 Error: mapper: No SET parameters for SmartEVSE error/SmartEVSE-5572/Error in ('SmartEVSE error', {'topic': 'SmartEVSE-5572/Error', 'type': '244', 'subtype': '73', 'switchtype': '18', 'options': {'SelectorStyle': '1', 'LevelOffHidden': 'false', 'LevelNames': 'None|No Power Available|Communication Error|Temperature High|EV Meter Comm Error|RCM Tripped|Waiting for Solar|Test IO|Flash Error|**Unknown**'}, 'mapping': {'item': '', 'default': '90', 'values': {'None': '0', 'No Power Available': '10', 'Communication Error': '20', 'Temperature High': '30', 'EV Meter Comm Error': '40', 'RCM Tripped': '50', 'Waiting for Solar': '60', 'Test IO': '70', 'Flash Error': '80', '**Unknown**': '90'}}}) Rpi4, Docker, z-wave, zigbee, espeasy, smartevse
FlyingDomotic
When do you get these errors?
Do you try to manually change the values?
rron
No I didn’t manual change these values. I will try again tomorrow with my car and see what happens. I let you know.
FlyingDomotic
Reason of my question is that "No SET parameters" message is displayed only when you try to change value in Domoticz (either by GUI or script), and don't give set params for that.
We must understand who is trying to change value (and perhaps why).
PieterS
- Domoticz version: 2024.7
What about 2 different smart evse topics in the screenshots?
Strange to me.
Strange to me.
Synology with Domoticz build (V2024.7) in Docker
FlyingDomotic
Probably a default value somewhere, used 'til properly configured.
rron
I'm testing it in life situation. Everything looks good but the current values are displaying 1.6 instead of 16. If I change multiplier to 1 it give 160.the rest is made. Everything is made right now.This is the logging:
If have also not seen the error from yesterday.
2024-08-11 12:26:17.202 mapper: Setting SmartEVSE error to 0/0.0
2024-08-11 12:26:28.183 mapper: Setting SmartEVSE max current to 1/1.6
2024-08-11 12:26:28.191 mapper: Setting SmartEVSE charge current to 1/1.6
2024-08-11 12:26:28.199 mapper: Setting SmartEVSE charge current override to 0/0.0
2024-08-11 12:26:28.207 mapper: Setting SmartEVSE state to >Charging<
2024-08-11 12:26:28.215 mapper: testValue="None" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.215 mapper: testValue="No Power Available" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.216 mapper: testValue="Communication Error" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.216 mapper: testValue="Temperature High" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.217 mapper: testValue="EV Meter Comm Error" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.218 mapper: testValue="RCM Tripped" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.219 mapper: testValue="Waiting for Solar" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.219 mapper: testValue="Test IO" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.220 mapper: testValue="Flash Error" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.220 mapper: testValue="**Unknown**" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:28.221 mapper: Setting SmartEVSE error to 0/0.0
2024-08-11 12:26:39.151 mapper: Setting SmartEVSE max current to 1/1.6
2024-08-11 12:26:39.167 mapper: Setting SmartEVSE charge current to 1/1.6
2024-08-11 12:26:39.180 mapper: Setting SmartEVSE charge current override to 0/0.0
2024-08-11 12:26:39.194 mapper: Setting SmartEVSE state to >Charging<
2024-08-11 12:26:39.208 mapper: testValue="None" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.209 mapper: testValue="No Power Available" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.210 mapper: testValue="Communication Error" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.211 mapper: testValue="Temperature High" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.211 mapper: testValue="EV Meter Comm Error" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.211 mapper: testValue="RCM Tripped" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.212 mapper: testValue="Waiting for Solar" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.212 mapper: testValue="Test IO" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.214 mapper: testValue="Flash Error" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.215 mapper: testValue="**Unknown**" (<class 'str'>), readValue="None" (<class 'str'>)
2024-08-11 12:26:39.216 mapper: Setting SmartEVSE error to 0/0.0
2024-08-11 12:26:50.209 mapper: Setting SmartEVSE max current to 1/1.6
2024-08-11 12:26:50.225 mapper: Setting SmartEVSE charge current to 1/1.6
2024-08-11 12:26:50.240 mapper: Setting SmartEVSE charge current override to 0/0.0
2024-08-11 12:26:50.256 mapper: Setting SmartEVSE state to >Charging<If have also not seen the error from yesterday.
FlyingDomotic
Could you try with last version of MqttMqpper plugin, I found a bug?
rron
Thanks, that was it! The current is now 16A. Thanks again for the effort.
FlyingDomotic
You're welcome!
rron
I have still a question nl the charge current is still at 16A without loading. I think that charge current is the same value as max current.
In the settings from smartevse is max current a fixed value (in my case 16A) and charge current should be a variable value, in the beginning the max (16A) and at the end lower and when full 0A.
FlyingDomotic
Have a check with data in MQTT. As MqttMapper get changes through MQTT, if MQTT is false, MqttMapper has the same default.
Else, it's a MqttMapper bug
rron
I think it's a bug, If you look at the mqtt explorer you can see the old topic smartevse (previous MqttMapper)and there was the ChargeCurrent 0 and in the latest release you can see the new topix SmartEVSE-5572 and now is the ChargeCurrent 16. The same is for MainsCurrent L1=-7, that should be -0,7FlyingDomotic wrote: Monday 12 August 2024 23:37 Have a check with data in MQTT. As MqttMapper get changes through MQTT, if MQTT is false, MqttMapper has the same default.
Else, it's a MqttMapper bug![]()
- Schermafdruk van 2024-08-13 19-25-03.png (141.7 KiB) Viewed 2747 times
FlyingDomotic
Could I have MqttMapper json configuration file?
