Energy Dashboard (Build in)
elgringo
- Domoticz version: Left
Re: Energy Dashboard (Build in)
I have multiple solar inverters (and no battery) is it possible to combine multiple solar inverter to 1?
I tried something with a custom sensor which add both, this works but still is a dirty solution.
Second I have a fixed contract with fixed prices, but in the Netherlands we have netting (salderen). price for delivery and return are the same is the total usage over a period is higher or equal the total return.
A few years ago a made a formula to calculate this, but this formula changed the actual price at the end of the period. I dont know if it is possible to add this into the calculation. Its a pain in the ass since actual prices are only know at the end of the period.
- gizmocuz
This is the right wayelgringo wrote: Wednesday 10 July 2024 6:55 I have multiple solar inverters (and no battery) is it possible to combine multiple solar inverter to 1?
- Domoticz version: 2025.1
Better not use a Custom Sensor but a Electricity (instant and counter) device.elgringo wrote: Wednesday 10 July 2024 6:55 I have multiple solar inverters (and no battery) is it possible to combine multiple solar inverter to 1?
I already posted a script in this discussion how to combine multiple devices in a new dummy Electricity (instant and counter) device.
https://www.domoticz.com/forum/viewtopi ... 34#p317834
- gizmocuz
Yes, this was correct. I assumed this display was only useful when you have a PV system.HansieNL wrote: Tuesday 09 July 2024 12:46 The solar panel setting for the Energy Dashboard is disabled, but the solar panel is still shown. The values are 0.000 kWh and 0 Watt. Is this correct or should it not be shown at all?
In the upcoming beta version it is now possible to display without PV.
Jan Jansen
- Domoticz version: Stable
Thank you in advance for the option
akamming
I have a feature request:
it would be really nice that when you click on a device on the energy dashboard, it would direct you directly to the devicelog of that device, so a link like http(s)://<ip:port>/#/Devices/<deviceidx>/Log
would this be possible?
imautohuttraeger
Yes. that would be great.akamming wrote: Saturday 13 July 2024 11:02 I have a feature request:
imautohuttraeger
(minor) feature request for the excellent (thanks for it!) new display:
Option for arranging the items also in portrait mode rather than landscape would improve usage e.g. with smartphones.
Works for me on my smartphone. How does yours look like? You can also zoom in..imautohuttraeger wrote: Sunday 14 July 2024 8:47 (minor) feature request for the excellent (thanks for it!) new display:
imautohuttraeger
Yes, it is working on the smartphone. But it is very small. Usage of the unused space above and below, with bigger items and larger font would improve visibility. Compare my "solution" - before the nice new energy dashboard existed - with a simple floor plan (please don`t laugh about the amateurish designwaltervl wrote: Sunday 14 July 2024 15:37Works for me on my smartphone. How does yours look like? You can also zoom in..imautohuttraeger wrote: Sunday 14 July 2024 8:47 (minor) feature request for the excellent (thanks for it!) new display:
- ugly_selfmade_energy_dashboard_with_floorplan.png (182.12 KiB) Viewed 1662 times
BartSr
- Domoticz version: V2024.7
Can you share how to do this as it's way more better to view on the phone than the integrated energy dashboard.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
imautohuttraeger
NOTE: THIS WORKAROUND IS CRAP COMPARED TO THE NICE NEW ENERGY DASHBOARD. It is just a group of devices based on function placed on a background image.BartSr wrote: Monday 15 July 2024 12:28 Can you share how to do this as it's way more better to view on the phone than the integrated energy dashboard.
You have to create a "room" and a roomplan. I have called it Energy. Then you assign the needed devices to this room. Then you create a floorplan which only contains this "room".
This was just my workaround (without any animated energy flow of course) before the energy dashboard existed. I have created a background image (usually it is a floor plan) and placed the necessary devices on it.
https://www.domoticz.com/wiki/Floorplans
- IMG_COM_202407151324376080.jpg (124.19 KiB) Viewed 1625 times
When you have also battery installed it is already less landscape or portait mode. See the screenshot in https://www.domoticz.com/forum/viewtopi ... 69#p318569
So it will be difficult to satisfy everybody's wishes. The workaround to have it in the floorplan has been around for ages.
imautohuttraeger
That's right. A bigger font size would even be enough. But I think this wouldn't work inside the bullets.
To avoid any misunderstanding: I absolutely love the new Energy dashboard!
Strangely, it doesn't work for me.
LINUX MINT
BMAX B3Plus Mini PC 8GB DDR4 256GB Jasper Lake N5095 (2.9 GHz)
DOMOTICZ 2024.7
LINUX MINT
DOMOTICZ 2024.7
- iScreen Shoter - 20240714170543327 (1).png (261.23 KiB) Viewed 1537 times
imautohuttraeger
Don't know if this is the cause. But in my case, type "General" with subtype "kWh" is working (rather than your type "Usage" and subtype "Elektric"). Maybe it is worth a trial.
- IMG_COM_202407161245100021.jpg (28.83 KiB) Viewed 1510 times
- IMG_COM_202407161245099260.jpg (29.6 KiB) Viewed 1510 times
imautohuttraeger
I don't get the cost fields filled on the energy dashboard. Simple typing in the costs in setup / meters/counters doesn't seem to be enough. Do I need an "Electricity price device"? I tried to choose "Internal (Meter settings) from the drop-down menu without success.
- IMG_COM_202407161305519611.jpg (112.9 KiB) Viewed 1502 times
- IMG_COM_202407161305518470.jpg (53.88 KiB) Viewed 1502 times
I understand, but that's how it is with me.imautohuttraeger wrote: Tuesday 16 July 2024 12:53 Don't know if this is the cause. But in my case, type "General" with subtype "kWh" is working (rather than your type "Usage" and subtype "Elektric"). Maybe it is worth a trial.
- iScreen Shoter - 20240716134603169.png (66.1 KiB) Viewed 1492 times
imautohuttraeger
OK. But compare with my screenshot: Your device is missing "Type: Return" and "Energy read: From Device". As already mentioned: I have no idea, if this is the cause. Just sharing how it works for me.
You have to enable (Dynamic) price calculation. Select a specific sensor with dynamic price information or use the fixed "internal (meter settings)"imautohuttraeger wrote: Tuesday 16 July 2024 13:14 I don't get the cost fields filled on the energy dashboard. Simple typing in the costs in setup / meters/counters doesn't seem to be enough. Do I need an "Electricity price device"? I tried to choose "Internal (Meter settings) from the drop-down menu without success.
