Blockly examples
Ron
Domoticz version: 2.2284
Re: Blockly examples
Post by Ron »
This works for me
(but my wife doesn't like it so it is now switched off)
Only dim values depending on the "dark on" and "dark off" value.
Badkamer verlichting met standen.jpg (85.47 KiB) Viewed 6277 times
Dim value depending on the "dark on" and "dark off" value and use of a motion sensor:
Badkamer verlichting met sensor en standen.jpg (152.71 KiB) Viewed 6277 times
teo1966
Domoticz version: 2025.1
Post by teo1966 »
I have an Aeotec ZWA005 TriSensor+ here and would like the motion sensor to switch on my LED lamp when I enter my office and, for example, if I am away for 10 minutes, to switch it off again.
it is not possible to get this working
Screenshot 2023-10-06 at 09-57-21 Domoticz.png (34.42 KiB) Viewed 5906 times
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Treve
Domoticz version: v4.11474
Post by Treve »
teo1966 wrote:I have an Aeotec ZWA005 TriSensor+ here and would like the motion sensor to switch on my LED lamp when I enter my office and, for example, if I am away for 10 minutes, to switch it off again.
Is every function separate visual in Domoticz? Or just only PIR function?
Where you from?
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
teo1966
Post by teo1966 »
I come from the south-east of the Netherlands
Screenshot 2023-10-06 at 16-25-09 Domoticz.png (34.58 KiB) Viewed 5870 times
Release: 11
Codename: bullseye
Treve
Post by Treve »
Ok, will you Try the command ‘on’ in stead of ‘motion’ if you can switch the lamp on.
I will think about it and send you a PB after your replay for the next answer.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
teo1966
Post by teo1966 »
does not work
Release: 11
Codename: bullseye
Treve
Post by Treve »
I send you a PB.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
In the event editor there you can see all the devices with the current state they have. Check the state change and see what you have to use in your Blockly statement.
https://www.domoticz.com/wiki/Events#De ... states_Tab
Loekie63
Domoticz version: 2024.7
Post by Loekie63 »
I made the folowing script but get an error in my logging and the script does not work:
I tried with: if day= Saturday or day=Sunday instead of the Variable but that gives the same error.
The error in my log :
Error: EventSystem: Lua script error (Blockly), Name: Rolluik voor Open weekend_3 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare string with number
fjuppe
Domoticz version: 16341
Post by fjuppe »
This Blockly block updates a parameter (0219) with fixed value = 100 and works OK. But I want to use an existing user variable instead of the fixed value in the URL. Is this possible in Blockly and what would I write as "val=" ???
