Blockly examples
Ron
- Domoticz version: 2.2284
Re: Blockly examples
This works for me
(but my wife doesn't like it so it is now switched off)
Only dim values depending on the "dark on" and "dark off" value. Dim value depending on the "dark on" and "dark off" value and use of a motion sensor:
teo1966
- Domoticz version: 2025.1
I have an Aeotec ZWA005 TriSensor+ here and would like the motion sensor to switch on my LED lamp when I enter my office and, for example, if I am away for 10 minutes, to switch it off again.
it is not possible to get this working
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
- Treve
- Domoticz version: v4.11474
Is every function separate visual in Domoticz? Or just only PIR function?teo1966 wrote:I have an Aeotec ZWA005 TriSensor+ here and would like the motion sensor to switch on my LED lamp when I enter my office and, for example, if I am away for 10 minutes, to switch it off again.
Where you from?
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
teo1966
I come from the south-east of the Netherlands
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
- Treve
Ok, will you Try the command ‘on’ in stead of ‘motion’ if you can switch the lamp on.
I will think about it and send you a PB after your replay for the next answer.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
teo1966
does not work
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
- Treve
I send you a PB.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Domoticz version: 2026.3
In the event editor there you can see all the devices with the current state they have. Check the state change and see what you have to use in your Blockly statement.
https://www.domoticz.com/wiki/Events#De ... states_Tab
Loekie63
- Domoticz version: 2024.7
I made the folowing script but get an error in my logging and the script does not work:
I tried with: if day= Saturday or day=Sunday instead of the Variable but that gives the same error.
The error in my log :
Error: EventSystem: Lua script error (Blockly), Name: Rolluik voor Open weekend_3 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare string with number
- blockly.jpg (53.78 KiB) Viewed 11975 times
fjuppe
- Domoticz version: 16341
This Blockly block updates a parameter (0219) with fixed value = 100 and works OK. But I want to use an existing user variable instead of the fixed value in the URL. Is this possible in Blockly and what would I write as "val=" ???
