on python plugin I have the possibility to enable/disable Info, Error, Status logging.
Domoticz.Log() logs anything to the log
Domoticz.Debug() logs only if Domoticz.Debugging==1 or Domoticz.Debugging&2 , right?
Domoticz.Error() logs only if Error logging is enabled in the plugin configuration
Domoticz.Status() logs only if Status logging is enabled in the plugin configuration
WHAT ABOUT Info ?
Log functions in Domoticz
- psubiaco
Paolo
Re: Log functions in Domoticz
Did you try it? And what are the differences?
- Domoticz version: 2024.7
I do not understand you question...
The log level settings in your screenshot decide if the info/status/error messages are being sent to the Domoticz log file.
A Python plugin can have additional debug levels (if implemented by the plugin author) and if set the debug messages will be shown as INFO messages in domoticz log if I am not wrong.
Edit:
I suppose Domoticz.Log() writes INFO messages.
Edit:
- psubiaco
Hi Walter,
Domoticz.Log() always write to the log file, without care of Info ON/OFF status.
Domoticz.Error() and Domoticz.Status() work perfectly, but I don't know how to manage the Info ON/OFF flag.
Paolo
Then it seems it is not implemented correctly in the Python Framework. Do you use old or new framework (DomoticzEx)?
- psubiaco
I'm using the old Domoticz framework.
Paolo
It is better to use the new framework, not guaranteed it will work but then it could be repaired,
Users browsing this forum: Bing [Bot], HvdW and 1 guest
