on python plugin I have the possibility to enable/disable Info, Error, Status logging.
Domoticz.Log() logs anything to the log
Domoticz.Debug() logs only if Domoticz.Debugging==1 or Domoticz.Debugging&2 , right?
Domoticz.Error() logs only if Error logging is enabled in the plugin configuration
Domoticz.Status() logs only if Status logging is enabled in the plugin configuration
WHAT ABOUT Info ?
Log functions in Domoticz
- psubiaco
Paolo
Re: Log functions in Domoticz
Did you try it? And what are the differences?
- Domoticz version: 2024.7
I do not understand you question...
The log level settings in your screenshot decide if the info/status/error messages are being sent to the Domoticz log file.
A Python plugin can have additional debug levels (if implemented by the plugin author) and if set the debug messages will be shown as INFO messages in domoticz log if I am not wrong.
Edit:
I suppose Domoticz.Log() writes INFO messages.
Edit:
- psubiaco
Hi Walter,
Domoticz.Log() always write to the log file, without care of Info ON/OFF status.
Domoticz.Error() and Domoticz.Status() work perfectly, but I don't know how to manage the Info ON/OFF flag.
Paolo
Then it seems it is not implemented correctly in the Python Framework. Do you use old or new framework (DomoticzEx)?
- psubiaco
I'm using the old Domoticz framework.
Paolo
It is better to use the new framework, not guaranteed it will work but then it could be repaired,
