Heisenberg
Thnx for sharing bizziebiz! I am now using 'your' frontpage.html but can't get the camera stream. In Domoticz I can see all my cameras. I then copied the url into the frontpage.html but only get a screenshot of the ip cam for 1 second and then it stopped. What am I doing wrong?
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
- bizziebis
- Domoticz version: 3.8805
It's a little embedde javascript inside the image tag which needs to be right. You need to put in "your camera url"&t= or ?t=
That last part is important because it will write a random time tag like t=752554822 behind the url forcing the image to be reloaded.
pvm
- Domoticz version: 4.10538
Do you have a code snippet? Do you switch css?mvveelen wrote: ...
Today I managed to get the background color to change when the sun sets and when the sun rises. It uses the virtual switch 'IsDark' that I use. And when the outdoor temperature gets below 0, the cell color of the outside temperature gets blue
vanputten80
Had the same. My camera needs a password to show a screenshot of my cam. What I did was loging on to my camera via IE and safe password. Now domoticz is loading everytime the camera. Works fine. Maybe its possible to add your credentials in the URL in the code?Heisenberg wrote:Thnx for sharing bizziebiz! I am now using 'your' frontpage.html but can't get the camera stream. In Domoticz I can see all my cameras. I then copied the url into the frontpage.html but only get a screenshot of the ip cam for 1 second and then it stopped. What am I doing wrong?
Another question, is it possible to get train information in the latest dashboard? From NS?
- bizziebis
Remember your frontpage.html is not secured when using the login page option in Domoticz. So using a url with credentials is not recommended when Domoticz is connected to the outside world. The best way would be to add the camera to Domoticz with the credentials in the url. That way you can use the safe internal Domoticz url for viewing your camera, like you see in my html.
- mvveelen
Yes, sure :pvm wrote:Do you have a code snippet? Do you switch css?mvveelen wrote: ...
frontpage.html -> http://pastebin.com/rxYpDqtt
frontpage.css -> http://pastebin.com/gCjTt8af
And this is what I have at the moment. It would be great if someone could get a slider (or a + / -) in one of the div's where we can set the level of a dimmer.
- Schermafbeelding 2015-01-13 om 18.07.16.png (106.03 KiB) Viewed 7084 times
Heisenberg
bizziebis wrote:It's a little embedde javascript inside the image tag which needs to be right. You need to put in "your camera url"&t= or ?t=
I got the camera working now! Thanx for the tip!
But now some switches don't show. What does NaN means? See attached picture.
- Domoticz Monitor.png (165.44 KiB) Viewed 7074 times
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
- mvveelen
NaN - Not a Number.
Maybe some numbers are expected in the div's / script you use?
ThinkPad
Or you have picked the wrong type for the cell (Status instead of Temp for example).
Heisenberg
ThinkPad wrote:Or you have picked the wrong type for the cell (Status instead of Temp for example).
That's strange because only the 'Radio Badkamer' doesn't work and the rest do show up in frontpage.htmlNaN - Not a Number.
These are my settings:
['35', 'Status', 'cell1', 'Lampen Tuin',],
['43', 'Temp', 'cell2', 'Woonkamer (°C)'],
['15', 'Status', 'cell3', 'Mechanische Ventilatie',],
['29', 'Status', 'cell4', 'Led Verwarming',],
['34', 'Status', 'cell5', 'Led Keuken',],
['19', 'Status', 'cell6', 'Radio Keuken',],
['50', 'Status', 'cell7', 'Radio Zolder'],
['49', 'Status', 'cell9', 'Radio Badkamer'],
['47', 'Status', 'cell10', 'Woonkamer Verlichting',],
['55', 'Status', 'cell11', 'Lamp Slaapkamer Master',],
['32', 'Status', 'cell12', 'Lamp Slaapkamer 2',],
['36', 'Status', 'cell13', 'Lamp Werkkamer'],
['25', 'Status', 'cell14', 'Lamp Bureau'],
['44', 'Status', 'cell15', 'Ledstrip Woonkamer',],
['16', 'Status', 'cell16', 'Lamp Hal',],
['37', 'Status', 'cell17', 'Lamp Cabinet',],
['40', 'Data', 'cell18', 'CPU Usage'],
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
Slayer007
Did you add it to your floorplan?That's strange because only the 'Radio Badkamer' doesn't work and the rest do show up in frontpage.html
ThinkPad
I think that is the issue indeed. Every device you want to show on the frontpage.html has to be included in the floorplan that you use for this page.Slayer007 wrote:Did you add it to your floorplan?That's strange because only the 'Radio Badkamer' doesn't work and the rest do show up in frontpage.html
Heisenberg
I guess you mean adding devices to the Roomplan instead of Floorplan? Yes, I follow the instructions as described in the first post.
Strange thing is that all the other devices are visible but only 'Radio Badkamer' seems not to work. I also try to put in in another cell but it didn't help
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
ThinkPad
What kind of device is it in Domoticz? Some kind of switch i guess? Maybe remove and add to Domoticz again? (if not too difficult)
Heisenberg
It's a dummy switch. I have two internetradio's. The 'Radio Kitchen' works correctly but 'Radio Badkamer' not..ThinkPad wrote:What kind of device is it in Domoticz? Some kind of switch i guess? Maybe remove and add to Domoticz again? (if not too difficult)
Edit: I removed the device and add it again in Domoticz. It works! Thanx for the suggestion ThinkPad!
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
- mbliek
If you use roomplan=0 all devices can be used
Op zoek naar een Domoticz Start Set?
- mvveelen
Good to know! Thanks. Now I can even delete my 'dummy'-roomplan I set up for this frontpage.htmlmbliek wrote:If you use roomplan=0 all devices can be used
ThinkPad
Nice!mbliek wrote:If you use roomplan=0 all devices can be used
sheriff
- Domoticz version: 2023.1
No i had the same problem but somewhere in the code of frontpage.html is some "dirty" code which does some extra formatting for the output of certain idx numbers which are only needed for the creator of the frontpage.html.mvveelen wrote:NaN - Not a Number.
Search the frontpage.html for the idx number which gives the NaN error and int the code change the number to a very high number (5 to 555555) then idx 5 will work fine and extra formatting is disabled.
Last edited by sheriff on Wednesday 14 January 2015 20:49, edited 1 time in total.
Pietertje
- Domoticz version: latest
Great work using new frontpage now, but I'm struggling to get sunset and sunrise listed. Can you give me a hint.
