Water Meter, sensor type
- flhoest
- Domoticz version: 2023.1
Re: Water Meter, sensor type
Thanks for the graph and the typo
Sorted !
Fred
Using Domoticz on Raspberry 3B+ since 2018
Fan of automation, API and PhP.
- flhoest
Hello Kedi,Kedi wrote: Thursday 20 April 2023 18:27 I use the same "AI-on-the-edge-device" project for my Water meter.
I use NodeRed with this function to get data to Domoticzand have this Device in Domoticz.Code: Select all
var IDX = global.get('idxTable','memoryOnly')['Water'].idx; var msg1 = {}; var msg2 = {}; if (msg.payload.error == 'no error') { msg1.payload = { "command": "udevice", "idx": IDX, "svalue": msg.payload.value.toString()}; msg2.payload = { "command": "addlogmessage", "message": "Water value: "+msg.payload.value.toString()}; } else { msg1.payload = { "command": "addlogmessage", "message": "Water ERROR: "+msg.payload.error}; // msg2.payload = { "command": "sendnotification", "subject": "WATER ERROR!", "subsystem": "pushover", "body": msg.payload.error, "priority": 0}; } //return msg; return [[msg1, msg2]];
This works fine with a nice history.
Quick question, can you confirm the Meter Offset is used to tell the sensor not to start from 0 but from the current meter value ?
Fred
- FireWizard
Hello @flhoest,
In your first post you stated:
In the first paragraph, last line, you will see:
That is special and maybe you want to share the future with us
Well, after the joke, please find also my graphs.
Just FYI,
Like @kedi, I use Node-RED as well, for the Watermeter.
I use the following Function node, before I send it to Domoticz with MQTT.
Important is that you send the value in liter (so you have multiply the m3 x1000). And to correct that again setup your global divider for water with 1000)
The Question to @Kedi: can you confirm the Meter Offset is used to tell the sensor not to start from 0 but from the current meter value ?
Yes I can, but I saw recently something new.
If I send a http request to the watermeter, I receive the following:
Previously "total_liter_offset_m3" was not available. So obviously you can set also the offset in the Home Wizard app. In that case, I assume, you should not use the offset in Domoticz. However, I have not been able to find that setting, yet.
Best regards
I suggest you to read the Wiki and then also this page: https://www.domoticz.com/wiki/About_DomoticzI'm using Domoticz since 2008, but I don't know why, I only register to this forum today ... don't ask me why
So beside that you obviously use hardware, before this has been produced, you have also access to software, before its release.The first release of Domoticz was in december 2012.
Just FYI,
let msg1 = {};
let msg2 = {};
if (msg.payload.hasOwnProperty("error")) {
msg = null;
return msg;
} else {
msg1.payload = { "command": "udevice", "idx": 532, "nvalue": 0, "svalue": ((msg.payload.total_liter_m3) * 1000).toString() };
msg2.payload = { "command": "udevice", "idx": 533, "nvalue": 0, "svalue": (msg.payload.active_liter_lpm).toString() };
return [[msg1,msg2]];
}The Question to @Kedi: can you confirm the Meter Offset is used to tell the sensor not to start from 0 but from the current meter value ?
msg.payload : Object
object
wifi_ssid: "Name "
wifi_strength: 100
total_liter_m3: 41.778
active_liter_lpm: 0
total_liter_offset_m3: 0Best regards
- flhoest
Hi There,
There are a lot of great contents here. I'm starting to go somewhere ... I'm doing further test, I will come back with my results !
Thanks everyone
Thanks everyone
Fred
Kedi
Sorry, I really don't know anymore if I used the Meter Offset, I suppose so.
- flhoest
If I'm passing the value in litre, it looks like the divider in the Domoticz setup should state 1000000 ... still playing around.
Fred
- FireWizard
Hi @flhoest,
You said
If you have a swimming pool of 25 m long and 10 m. wide and 4 meter deep, it is 1,000 m3. This is quite a large and deep swimming pool.
See: https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
(So for Home Wizard you have to multiply it first with 1000, as you get the value in m3)
You said
That is a lot of water 1,000,000 is equal to 1,000 m3 of water.If I'm passing the value in litre, it looks like the divider in the Domoticz setup should state 1000000
The global divider should be set to 1000 and you have to send the value to Domoticz in liters.Counter
/json.htm?type=command¶m=udevice&idx=IDX&svalue=COUNTER
IDX = id of your device (this number can be found in the devices tab in the column "IDX")
COUNTER = Integer of the overall total counter (Energy, Volume, Custom).
When there is a counter created, there is a possibility to change the units by clicking on "Change" at the utility tab.
Energy (reports kWh), give COUNTER value in Wh, integer
Energy Generated (reports kWh). give COUNTER value in Wh, integer
Gas (reports m3) , give COUNTER value in liter (1000 liter = 1 m³), integer
Water (reports m3), give COUNTER value in liter (1000 liter = 1 m³), integer
Counter (no unit)
Time (min?), seems to be obsolete, use Counter instead and use the time units as desired (eg Sec, min, hrs)
The counter will be treated with the divider which is defined in the parameters in the application settings (menu setup-settings, tab counters). For example if the counter is set to "Water" and the value is passed as liters, the divider must set to 1000 (as the unit is m3). The device displays 2 values:
The status is the overall total volume (or counter).
The volume (or counter) of the day (in the top right corner).
The today's volume (or counter) is calculated from the total volume (or counter).
- flhoest
Yes I initially did that, but if I'm sending the value in litre I'm getting millions of litre reported in the graph ... this is weird.
I know that 1000 liters = 1 m3
My actual value on the meter is 01617.485 (m3)
the "." which is here the decimal divider on my meter.
I have set the meter offset of the sensor to that value. Then each consecutive reading of the value are sent to the sensor. I'm reading a new value every 3 mins and I'm pushing it every 5 mins.
The graph in Domoticz does not seems to be consistent.
It might be decimal separator issue actually since the value should be sent in liter, I have removed the decimal point on my meter reading facility :
Decimal Shift = 0
Decimal Shift = 0
Fred
Kedi
This is my image from the AI project. The value of "666933.70" is send to the Domoticz device.
Decimal shift is 0, so I am sending liters, up to an accuracy of 10 ml.
Rounded by Domoticz to liters.
All with the above Nodered function.
In Domoticz with a water counter divider of 1000 because costs are in €/m3
- flhoest
Brilliant !
Fred
- flhoest
Thanks a lot to everyone assisting on this topic. I'm starting to have relevant figures.
I have noticed the accuracy of the usage graph is "per hour". Is there a way to have better accuracy ? like every 10 mins ?
Thanks again.
I'm preparing a blog post on that topic.
Thanks again.
Fred
I was also searching why it is always 0.FireWizard wrote: Friday 21 April 2023 16:28 Previously "total_liter_offset_m3" was not available. So obviously you can set also the offset in the Home Wizard app. In that case, I assume, you should not use the offset in Domoticz. However, I have not been able to find that setting, yet.
Best regards
After a look at the page, it said
Data points for HWE-WTR
total_liter_offset_m3 - Number - 'The usage of this value is in development and should not be used'
Source: https://homewizard-energy-api.readthedo ... oints.html
So it looks like it is under construction
- flhoest
Fred
- gizmocuz
Another way (at least for Dutch meters) is to use a proximity sensor
https://github.com/gizmocuz/esp_proximity_sensor_mqtt
ilkaskim
FireWizard wrote: Friday 21 April 2023 16:28 Hello @flhoest,
Just FYI,
Important is that you send the value in liter (so you have multiply the m3 x1000). And to correct that again setup your global divider for water with 1000)Code: Select all
let msg1 = {}; let msg2 = {}; if (msg.payload.hasOwnProperty("error")) { msg = null; return msg; } else { msg1.payload = { "command": "udevice", "idx": 532, "nvalue": 0, "svalue": ((msg.payload.total_liter_m3) * 1000).toString() }; msg2.payload = { "command": "udevice", "idx": 533, "nvalue": 0, "svalue": (msg.payload.active_liter_lpm).toString() }; return [[msg1,msg2]]; }
Previously "total_liter_offset_m3" was not available. So obviously you can set also the offset in the Home Wizard app. In that case, I assume, you should not use the offset in Domoticz. However, I have not been able to find that setting, yet.Code: Select all
msg.payload : Object object wifi_ssid: "Name " wifi_strength: 100 total_liter_m3: 41.778 active_liter_lpm: 0 total_liter_offset_m3: 0
Best regards
hello @Firewizard
Could you please provide the flow of how you implemented it to send the data to domoticz.
greeting
- FireWizard
Sure,
I will do that, as soon as I'm behind my computer.
- FireWizard
Hereby the promised flow:
Do not forget to change the IP address in the HTTP request node to your own needs and that the IDX numbers in line 8 and 9 in the Function node match with your virtual IDX's in Domoticz.
"id": "4d135b728ec17b22",
"type": "http request",
"z": "1ac5277b4a20d52c",
"name": "HTTP Watermeter",
"method": "GET",
"ret": "obj",
"paytoqs": "ignore",
"url": "http://192.168.10.115/api/v1/data",
"tls": "",
"persist": false,
"proxy": "",
"insecureHTTPParser": false,
"authType": "",
"senderr": false,
"headers": [],
"x": 390,
"y": 80,
"wires": [
"71a2b6594fb9fbcb"
"id": "1a06699e862880bf",
"type": "inject",
"name": "Inject 1 min",
"props": [
"p": "payload"
"repeat": "60",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 170,
"y": 80,
"wires": [
"4d135b728ec17b22"
"id": "7b9afc0f16d83c2e",
"type": "mqtt out",
"name": "To Domoticz",
"topic": "domoticz/in",
"qos": "2",
"retain": "false",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "f8a872af.a6898",
"x": 910,
"y": 80,
"wires": []
"id": "71a2b6594fb9fbcb",
"type": "function",
"name": "Calculate Waterflow/usage",
"func": "let msg1 = {};\nlet msg2 = {};\n\nif (msg.payload.hasOwnProperty(\"error\")) {\n msg = null;\n return msg;\n} else {\n msg1.payload = { \"command\": \"udevice\", \"idx\": 532, \"nvalue\": 0, \"svalue\": ((msg.payload.total_liter_m3) * 1000).toString() };\n msg2.payload = { \"command\": \"udevice\", \"idx\": 533, \"nvalue\": 0, \"svalue\": (msg.payload.active_liter_lpm).toString() };\nreturn [[msg1,msg2]];\n}",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 660,
"y": 80,
"wires": [
"7b9afc0f16d83c2e"
"id": "f8a872af.a6898",
"type": "mqtt-broker",
"name": "Jonas_MQTT_Server",
"broker": "mqtt.jonasnet.nl",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"autoUnsubscribe": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
]Regards
ilkaskim
Thanks, I'll take a look at what I can improve on.FireWizard wrote: Friday 08 November 2024 10:53 Hereby the promised flow:
Do not forget to change the IP address in the HTTP request node to your own needs and that the IDX numbers in line 8 and 9 in the Function node match with your virtual IDX's in Domoticz.Code: Select all
[ { "id": "4d135b728ec17b22", "type": "http request", "z": "1ac5277b4a20d52c", "name": "HTTP Watermeter", "method": "GET", "ret": "obj", "paytoqs": "ignore", "url": "http://192.168.10.115/api/v1/data", "tls": "", "persist": false, "proxy": "", "insecureHTTPParser": false, "authType": "", "senderr": false, "headers": [], "x": 390, "y": 80, "wires": [ [ "71a2b6594fb9fbcb" ] ] }, { "id": "1a06699e862880bf", "type": "inject", "z": "1ac5277b4a20d52c", "name": "Inject 1 min", "props": [ { "p": "payload" } ], "repeat": "60", "crontab": "", "once": true, "onceDelay": 0.1, "topic": "", "payload": "", "payloadType": "date", "x": 170, "y": 80, "wires": [ [ "4d135b728ec17b22" ] ] }, { "id": "7b9afc0f16d83c2e", "type": "mqtt out", "z": "1ac5277b4a20d52c", "name": "To Domoticz", "topic": "domoticz/in", "qos": "2", "retain": "false", "respTopic": "", "contentType": "", "userProps": "", "correl": "", "expiry": "", "broker": "f8a872af.a6898", "x": 910, "y": 80, "wires": [] }, { "id": "71a2b6594fb9fbcb", "type": "function", "z": "1ac5277b4a20d52c", "name": "Calculate Waterflow/usage", "func": "let msg1 = {};\nlet msg2 = {};\n\nif (msg.payload.hasOwnProperty(\"error\")) {\n msg = null;\n return msg;\n} else {\n msg1.payload = { \"command\": \"udevice\", \"idx\": 532, \"nvalue\": 0, \"svalue\": ((msg.payload.total_liter_m3) * 1000).toString() };\n msg2.payload = { \"command\": \"udevice\", \"idx\": 533, \"nvalue\": 0, \"svalue\": (msg.payload.active_liter_lpm).toString() };\nreturn [[msg1,msg2]];\n}", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 660, "y": 80, "wires": [ [ "7b9afc0f16d83c2e" ] ] }, { "id": "f8a872af.a6898", "type": "mqtt-broker", "name": "Jonas_MQTT_Server", "broker": "mqtt.jonasnet.nl", "port": "1883", "clientid": "", "autoConnect": true, "usetls": false, "protocolVersion": "4", "keepalive": "60", "cleansession": true, "autoUnsubscribe": true, "birthTopic": "", "birthQos": "0", "birthPayload": "", "birthMsg": {}, "closeTopic": "", "closeQos": "0", "closePayload": "", "closeMsg": {}, "willTopic": "", "willQos": "0", "willPayload": "", "willMsg": {}, "userProps": "", "sessionExpiry": "" } ]
- FireWizard
Okay,
At least you can add the RSSI (wifi_strength).
This can be useful, dependant on your local situation.
When I bought the unit, offset was not available at that time.
But it is not a variable.
Success and let it know.
