Water Meter, sensor type
flhoest
Domoticz version: 2023.1
Post by flhoest »
Dear All,
I'm using Domoticz since 2008, but I don't know why, I only register to this forum today ... don't ask me why ;)
I'm starting to do some more advanced stuff, that's probably the reason.
I'm busy collecting the water meter data, but this is not where I need support. Part of my workflow, I'm updating the data using Domoticz API.
Something similar to this :
?type=command&param=udevice&idx=5997&nvalue=0&svalue=45
The questions are :
- What type of virtual sensor is best for collecting water usage ? I've tried many : counter incremental, custom sensor, water flow ... I still cannot decide what's the best option.
- In the above API call, I need to understand what nvalue and svalue stands for. I understood svalue is the usage since the last measure. So, when I read my meter, I substrating the current value with the previous value, so I have my usage, and this is that value that I need to send to domoticz to see the usage per time interval. Am I right ?
Thanks for the support.
Take care,
Fred.
Fred
Using Domoticz on Raspberry 3B+ since 2018
Fan of automation, API and PhP.
flhoest
Re: Water Meter, sensor type
Post by flhoest »
Nobody ?
Fred
RedEarth
Post by RedEarth »
Domoticz version: 2025.1
What are you trying to measure?
A counter device can visualize the hourly, daily, monthly, yearly usage.
A waterflow device can visualize the current flow (if you send the data)
See also wiki for overview of all possible devices https://www.domoticz.com/wiki/Dummy_for ... #Waterflow
flhoest
Post by flhoest »
waltervl wrote: Wednesday 19 April 2023 20:32 What are you trying to measure?
Thanks for replying, I already checked indeed. Waterflow is not what I need, because I only measure a delta usage between 2 readings. At the end, it will give me a usage (in liter) for each hours, days, weeks, month ... I think the counter is the best option.
The question is more about the nvalue and svalue .... is there any official documentation explaining what it is ?
Thanks.
Fred
See the wiki that redhearth already gave.
RedEarth wrote: Wednesday 19 April 2023 19:41 have you tried the wiki?
https://www.domoticz.com/wiki/Domoticz_ ... ncremental
flhoest
Post by flhoest »
Hi there,
Thanks for your reply, I was looking at it ... I saw this :
json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=COUNTER;USAGE
I have the feeling that I need to replace the value COUNTER by the total reading on the counter and USAGE seems to be the difference between actual value and previous measure, which is giving a "usage" or "consumption" ...
However it is still not clear what nvalue=0 means ...
Thanks again.
Fred
For a water meter you can use counter with nvalue counter or incremental counter with nvalue is Incremental (delta).
It depends how you measure the watermeter. If you use pulse switch you better use incremental, if you can read the watermeter counter as if you take a snapshot of the watermeter counter every minute you can use the normal counter (in the wiki above the incremental). Nvalue=0 has no extra meaning then you have to supply it for this type of counter.
How do you read your watermeter?
flhoest
Post by flhoest »
@waltervi,
I'm using AI on the Edge project with ESP32-CAM then I use a php script that maintain the virtual sensor.
I'm in the process of writing this script - this is why I'm asking those questions. I have a new value every 5 minutes and I'm recording current value and previous value which gives me a delta indeed.
So I guess I will go the above way when I was talking about CONTER;USAGE
Fred
CONTER;USAGE is only for electricity, not for water.
If you see the whole total counter value every 5 minutes you only have to send that to Domoticz with
/json.htm?type=command&param=udevice&idx=IDX&svalue=COUNTER
No need to store the old value. Simplifies your AI application.
Domoticz will calculate hourly , Daily etc usage from the counter values it receives.
flhoest
Post by flhoest »
Oh really ? this is awesome ;)
I will continue testing ...
Thanks a lot for sharing your knowledge !
Fred
FireWizard
Post by FireWizard »
Hi @ flhoest,
I would recommend to use a "Counter". After you have created a "Counter" virtual device, you can edit the widget and select as "Type" water.
You send the value to the device as your Delta in liters.
See also the discussion at: viewtopic.php?p=293538&hilit=water#p293538
And just for your information:
nvalue stands for Numerical value (Integer or Float) while svalue stands for String value.
The counter device needs a String value, so take care that you send a string (and not a number). So something like "1234".
You can safely omit nvalue, in this case.
flhoest
Post by flhoest »
FireWizard wrote: Wednesday 19 April 2023 23:44 Hi @ flhoest,
Fantastic, I like your information, at last something straight forward. It's a bit a shame this is not clearly explained in the wiki ... or I missed it.
Fred
But for every device the content nValue and sValue could mean something else....
Looking back it is a very strange protocol for sending values and states to devices. But it is there and we have to deal with it ;)
Kedi
Post by Kedi »
I use the same "AI-on-the-edge-device" project for my Water meter.
I use NodeRed with this function to get data to Domoticz
var IDX = global.get('idxTable','memoryOnly')['Water'].idx;
var msg1 = {};
var msg2 = {};
if (msg.payload.error == 'no error') {
    msg1.payload = { "command": "udevice", "idx": IDX, "svalue": msg.payload.value.toString()};
    msg2.payload = { "command": "addlogmessage", "message": "Water value: "+msg.payload.value.toString()};
} else {
    msg1.payload = { "command": "addlogmessage", "message": "Water ERROR: "+msg.payload.error};
//    msg2.payload = { "command": "sendnotification", "subject": "WATER ERROR!", "subsystem": "pushover", "body": msg.payload.error, "priority": 0};
//return msg;
return [[msg1, msg2]];
and have this Device in Domoticz.
This works fine with a nice history.
flhoest
Post by flhoest »
Would you mind showing me the history graph?
Fred
flhoest
Post by flhoest »
I managed to create a php script that reads from the "AI-on-the-edge" and pushes to Domoticz. I have the feeling the logic is good, but I still need more hours to have complete confirmation it is working fine ...
<?php
	$espIP="192.168.x.x";
	$domoticzIP="192.168.x.x";
	$sensorIDX="xxxx";
	// Function to retrieve the ESP32-CAM reading of the meter
	function espGetValue($espIP)
		$curl = curl_init();
		curl_setopt($curl, CURLOPT_FOLLOWLOCATION, 1);
		curl_setopt($curl, CURLOPT_HTTPHEADER, array(
							'Accept: application/json, text/plain, */*',
							'Content-Type: application/json;charset=utf-8'
		curl_setopt($curl, CURLOPT_URL, "http://".$espIP."/json");
		curl_setopt($curl, CURLOPT_RETURNTRANSFER, 1);
		$result = curl_exec($curl);
		curl_close($curl);
		$result=json_decode($result);
		if($result -> main -> error == "no error")
			return $result -> main -> value;
		else return FALSE;
	// Function to push data to a Domoticz sensor
	function sendToSensor($domoticzIP,$sensorIDX,$val)
		/* API Reference : https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s#Electricity_.28instant_and_counter.29	*/
		$API=$domoticzIP;
		curl_setopt($curl, CURLOPT_CUSTOMREQUEST, "POST");
		curl_setopt($curl, CURLOPT_POST, 1);
		curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
		curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, false);
		curl_setopt($curl, CURLOPT_URL, "https://".$API."/json.htm?type=command&param=udevice&idx=".$sensorIDX."&nvalue=0&svalue=".$val);
		curl_close($curl);
		if(json_decode($result)->status=="OK") return TRUE;
		else return FALSE;
	// Entry point
	$res=espGetValue($espIP);
	if($res)
	 	print("-> Value is ".$res." m3\n");
	 	print("=> Pushing data to Domoticz sensor...");
		sendToSensor($domoticzIP,$sensorIDX,$res);
		print("\nDone.\n\n")	 	;
	 	print(">> Nothing to do.\n\n");
Sorry, I'm a big fan of Php ;)
Fred
Nice solution!
This would be an easy one in dzvents with openURL and item.json conversion.dzvents script is stored into the database so easy to maintain within the Domoticz application.
flhoest
Post by flhoest »
Thanks ;)
Fred
Kedi
Post by Kedi »
flhoest wrote: Thursday 20 April 2023 19:44 Would you mind showing me the history graph?
No problem.
B.t.w. your Sig. states "Using Domoticz on Raspberry 3B+ since 2008" Are you sure? Release date of the 3B+ is 2018
