I can not connect in MQTT Explorer with mij Rasberry ip adres where MQTT is installed.
Also i can not connect with localhost port 1883
It gives also problems in zwave-js-ui
2023-03-22 10:13:15.177 INFO MQTT: MQTT client reconnecting
2023-03-22 10:13:15.181 ERROR MQTT: Mqtt client error connect ECONNREFUSED 127.0.0.1:1883
Error: connect ECONNREFUSED 127.0.0.1:1883
at TCPConnectWrap.afterConnect [as oncomplete] (node:net16)
2023-03-22 10:13:15.183 INFO MQTT: MQTT client closed
In domoticz i have also Node-red with MQTT and thats ok. It works fine.
For node-red i setup in Domoticz MQTT with lan interface localhost en port 1883.
Dont understand why i can not connect in MQTT Explorer
MQTT cant connect in MQTT Explorer
Kedi
Re: MQTT cant connect in MQTT Explorer
Perhaps use the IP-address of the Raspberry instead of 127.0.0.1
Dave47
- Target OS: -
- Domoticz version: 2023.1
Is not working.
Kedi
What is in the logging of mosquitto?
If you put "log_type debug" in the mosquitto configuration, you will be able to find the cause.
Dave47
- Target OS: -
The problem has been solved.
Kedi
So what was the solution?
Dave47
- Target OS: -
From Mosquitto 2 and higher its only possible to login with localhost on that device.
For another device you have to change some settings in mosquitto.conf. you can login than with raspberry ip
- Domoticz version: 2025.1
As warned for on our domoticz MQTT Wiki:Dave47 wrote: Saturday 25 March 2023 7:40 From Mosquitto 2 and higher its only possible to login with localhost on that device.
https://www.domoticz.com/wiki/MQTT#Installing_Mosquitto
Dave47
- Target OS: -
Ai. Yes i See it now.
