I can not connect in MQTT Explorer with mij Rasberry ip adres where MQTT is installed.
Also i can not connect with localhost port 1883
It gives also problems in zwave-js-ui
2023-03-22 10:13:15.177 INFO MQTT: MQTT client reconnecting
2023-03-22 10:13:15.181 ERROR MQTT: Mqtt client error connect ECONNREFUSED 127.0.0.1:1883
Error: connect ECONNREFUSED 127.0.0.1:1883
at TCPConnectWrap.afterConnect [as oncomplete] (node:net16)
2023-03-22 10:13:15.183 INFO MQTT: MQTT client closed
In domoticz i have also Node-red with MQTT and thats ok. It works fine.
For node-red i setup in Domoticz MQTT with lan interface localhost en port 1883.
Dont understand why i can not connect in MQTT Explorer
MQTT cant connect in MQTT Explorer
Re: MQTT cant connect in MQTT Explorer
Perhaps use the IP-address of the Raspberry instead of 127.0.0.1
- Target OS: -
- Domoticz version: 2023.1
Is not working.
What is in the logging of mosquitto?
If you put "log_type debug" in the mosquitto configuration, you will be able to find the cause.
- Target OS: -
The problem has been solved.
So what was the solution?
- Target OS: -
From Mosquitto 2 and higher its only possible to login with localhost on that device.
For another device you have to change some settings in mosquitto.conf. you can login than with raspberry ip
- Domoticz version: 2024.7
- Target OS: -
Ai. Yes i See it now.
