MQTT cant connect in MQTT Explorer
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
Dave47
Domoticz version: 2023.1
Post by Dave47 »
I can not connect in MQTT Explorer with mij Rasberry ip adres where MQTT is installed.
Also i can not connect with localhost port 1883
It gives also problems in zwave-js-ui
2023-03-22 10:13:15.177 INFO MQTT: MQTT client reconnecting
2023-03-22 10:13:15.181 ERROR MQTT: Mqtt client error connect ECONNREFUSED 127.0.0.1:1883
Error: connect ECONNREFUSED 127.0.0.1:1883
at TCPConnectWrap.afterConnect [as oncomplete] (node:net16)
2023-03-22 10:13:15.183 INFO MQTT: MQTT client closed
In domoticz i have also Node-red with MQTT and thats ok. It works fine.
For node-red i setup in Domoticz MQTT with lan interface localhost en port 1883.
Dont understand why i can not connect in MQTT Explorer
Kedi
Domoticz version: latest
Re: MQTT cant connect in MQTT Explorer
Post by Kedi »
Perhaps use the IP-address of the Raspberry instead of 127.0.0.1
Dave47
Post by Dave47 »
Is not working.
Kedi
Post by Kedi »
What is in the logging of mosquitto?
If you put "log_type debug" in the mosquitto configuration, you will be able to find the cause.
Dave47
Post by Dave47 »
The problem has been solved.
Kedi
Post by Kedi »
So what was the solution?
Dave47
Post by Dave47 »
From Mosquitto 2 and higher its only possible to login with localhost on that device.
For another device you have to change some settings in mosquitto.conf. you can login than with raspberry ip
Domoticz version: 2026.3
Dave47 wrote: Saturday 25 March 2023 7:40 From Mosquitto 2 and higher its only possible to login with localhost on that device.
As warned for on our domoticz MQTT Wiki:
https://www.domoticz.com/wiki/MQTT#Installing_Mosquitto
Dave47
Post by Dave47 »
Ai. Yes i See it now.
