Today the water pressure in my central heating did this.... a drop from 1.8 to 0.7....and I got a nice email warning from Domoticz as configured.
So I could spend the afternoon to find the leak and fix it, instead of ending up in a cold house. Thank you !!
Thank you. Domoticz (with OTGW) saved the day.
ssk17051980
- Domoticz version: 2023.2
Re: Thank you. Domoticz (with OTGW) saved the day.
how you monitor the pressure ?
thx
thx
willemd
- Domoticz version: 2024.1
With second hand OpenTherm Gateway (OTGW) in between my thermostat and boiler.
http://otgw.tclcode.com/
jake
Nice. In the ages before domoticz I always noted the meter values for gas and electricity, combined with degrees days. One time I noted a deviation and checked out the boiler. The culprit turned out to be a locked flow switch. This kept turning the boiler on and off because max temperature is reached. I cleaned the switch and everything was fine afterwards.willemd wrote:Today the water pressure in my central heating did this.... a drop from 1.8 to 0.7....and I got a nice email warning from Domoticz as configured.
BartSr
- Domoticz version: V2024.7
Which software is on the OTGW?
Bart
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
willemd
One of the most useful features I have installed in Domoticz: an e-mail alert when the water pressure in my central heating becomes too low.
After filling up the system last week, I got an alert this morning. Turns out the pressure dropped from 1.8 to 1.0 in 2 days.....leak has now been fixed.
The spikes at the end of the graph is me filling up the system, locating the leak and fixing it.
- Screenshot 2024-04-02 174753.png (281.26 KiB) Viewed 2748 times
