SOLVED: Attach scene to triple click fibre dimmer module
stef62376
Post by stef62376 »
I have a FGD211Fibaro dimmer module and would like to attach a scene to the triple click functionality. In domoticz I can enable the functionality in the hardware settings but what I make out from the description it is not possible in Domoticz (see attachment)?
When I check with a lua script I see:
print ('The following prints pairs device changed')
for i, v in pairs(devicechanged) do print(i, v) end
print ('The End')
2014-12-14 21:03:10 (razberry) Lighting 2 (Achterkamer Plafond Lamp)
2014-12-14 21:03:10 LUA: The following prints pairs device changed
2014-12-14 21:03:10 LUA: Unknown
2014-12-14 21:03:10 LUA: On
2014-12-14 21:03:10 LUA: The End
Any idea if it is possible to attach a scene to the triple click functionality? Or is it not implemented yet?
Stef
Screen Shot 2014-12-15 at 08.02.22.png (337.95 KiB) Viewed 4573 times
Last edited by stef62376 on Tuesday 30 December 2014 7:48, edited 1 time in total.
stef62376
Re: Attache scene to triple click fibre dimmer module
Post by stef62376 »
<spammer has been removed already>
Last edited by stef62376 on Tuesday 30 December 2014 14:55, edited 1 time in total.
mbliek
Post by mbliek »
Done. You can report the post at the moderators. Thanks.
stef62376
Re: SOLVED: Attach scene to triple click fibre dimmer module
Post by stef62376 »
Later on I found an unknown device in my device list. After some investigation I found out that it was a new switch created after I enabled the scene activation in the settings of my Fibaro dimmer (FGD211 micromodule).
I added it to the switch page, gave a it a proper name and attached a scene to it.
Now I can triple click my (physical) switch to turn of all lights before I go to bed:-).
I hope it helps someone having the same question I had.
Cheers
vvhillo
Post by vvhillo »
How do you activate a scene by a switch? I have my "triple click" switch but I cant attach a scene to it. What do I need to do for that?
mfranken
Post by mfranken »
Just go the scene and click 'Add device', then triple-click your switch and it will show up.
At least that is what worked for me. I now have a scene that reacts to (in my case double click on the S1 of) my fibaro dimmer:
Scenes with fibaro switch and more
Raspberry, RFX, Zwave, JeeNodes, MySensors, OTGW, Domotix iPhone App
