Value from user variable as block title (SOLVED)
Maikel76
Domoticz version: 2022.1
Post by Maikel76 »
I cannot get this code to work, could anyone please help me?
I would like the value of an user variable v3 (value is 'Jan' as String) as the title of a block 161, which is a virtual switch
(code based on solution in viewtopic.php?t=34903)
v3 and block 161 are defined in CONFIG.js
custom.js:
function getStatus_v3(block) {                                       //guest1
  var idx = block.idx;
  var device = block.device;
  if (parseString(device['Value']) != '') {
      Dashticz.setBlock(161, {
         title: 'test', //guest1
         icon: 'fas fa-walking'
  } // end if
} // end function
What am I missing?
Last edited by Maikel76 on Wednesday 14 December 2022 7:51, edited 1 time in total.
Scripting is my passion, dzVents, LUA, Bash
Dashticz v3.10.7 Beta --Raspbian Buster
Lokonli
Re: Value from user variable as block title
Post by Lokonli »
Did you add v3 to a column? If not, the getStatus function will not be called.
Verstuurd vanaf mijn SM-A526B met Tapatalk
Maikel76
Post by Maikel76 »
Lokonli wrote: Thursday 08 December 2022 18:07 Did you add v3 to a column? If not, the getStatus function will not be called.
Yep I did;
CONFIG.js:
blocks['g1'] = {title: 'Guest1', idx: 'v3', width: 4}
//Other
columns[6] = {}
columns[6]['blocks'] = [17,23,136,31,133,142,161,24,162,94,18,104,159,92,71,21,frames.player,96,32,'s1',60,12,141,'g1','g2','graphLifePO']
columns[6]['width'] = 12;
i cannot use
blocks['v3'] = {title: 'Guest1', width: 4}
without specifying idx, because then the page wont load properly
also tried on column[3] on the main page because [6] is a seperate page, also the title doesnt change
just updated Dasticz to the latest version, still no title
Any other suggestions? I generate a different title for the AC block, only difference that I can see is that in this case this is a user-variable, so theoretically not a 'device'
I tried this without result too;
function getStatus_v3(variable) {                                       //guest1
  var idx = variable.idx;
  var variable = variable.device;					//here device looks like a property of the domoticz unit
  if (parseString(variable['Value']) != '') {
  } // end if
} // end function
I'm still running domoticz 2022.1
These are my user-variables in domoticz;
Screenshot 2022-12-09 at 09-14-40 Domoticz.png (15.49 KiB) Viewed 1443 times
Lokonli
Post by Lokonli »
If you have:
blocks['g1'] = ...
then in custom.js you should use:
function getStatus_g1
So the last part of the function name should be the same as the key you used for the block.
Did you try that already?
Maikel76
Post by Maikel76 »
Lokonli wrote: Friday 09 December 2022 6:52 If you have:
blocks['g1'] = ...
tried that, strange thing is that id i change it to g1, the dashboard is not (fully) loading; background not correct, i see a switch that is hiding according to its status and tabs are not working, i have to scroll to the specific page and there the title is still not changed
Do i change that back to v3 then its working again
I do use buttons functionality for menu buttons like this;
buttons.pg1bedroom = {
  width:2,
  title:'Bedroom',
  slide:5,
  key:'pg1bedr'
buttons.pg1roon = {
  width:12,
  title:'Click to browse music on Roon',
  slide:6,
  key:'pg1roon'
buttons.pg2home = {
  width:11,
  title:'This is the Climate page, click to go back to the Homescreen',
  slide:1,
  key:'pg2home'
buttons.pg3home = {
  width:8,
  title:'This is the Lights page, click to go back to the Homescreen',
  slide:1,
  key:'pg3home'
i dont use the g1 variable anywhere else (doublechecked)
Lokonli
Post by Lokonli »
parseString is not a javascript function, so you have to remove that.
Try the following:
function getStatus_g1(block) {
  if (device['Value'] != '') {
  } // end if
} // end function
This assumes you have defined blocks['g1'] in your CONFIG.js, and have added 'g1' to a column. 161 must also have been added to column.
Maikel76
Post by Maikel76 »
Excellent, thanks a lot Sander, this is the final code;
function getStatus_g1(block) {                                       //guest1
         title: device['Value'],
         icon: 'fas fa-walking',
         textOn: device['Value'] + ' is Home',
         textOff: device['Value'] + ' is out'
  } // end if
} // end function
