Calendar: issue with repeating appointments
Bospieper
Domoticz version: 2026.3
Post by Bospieper »
When I have a repeating appointment, for example every 5 weeks, the appointment appears every week in the calendar.
Has anyone experience this behaviour?
Grtz Piet
FireWizard
Re: Calendar: issue with repeating appointments
Post by FireWizard »
Hi, @Bospieper,
This question is off topic.
Can you explain the relationship between your calender (what calender?) and Domoticz?
[Edit] Oh, see, it is Dashticz.
Sorry
Bospieper
Post by Bospieper »
My mistake I had to mention that it is about Dashticz.
Lokonli
Post by Lokonli »
Bospieper wrote: Friday 22 October 2021 9:29 Hello,
Grtz Piet
What is your Dashticz version? and PHP version?
(this influences which calendar module is used by Dashticz ...)
I'll do some tests.
Bospieper
Post by Bospieper »
@Lokonli see the attachment ;)
Lokonli
Post by Lokonli »
ok, thanks. I'll have a look.
Bospieper
Post by Bospieper »
Hi Lokonli,
Did you manage to find the solution for my problem?
Grz. Piet
Lokonli
Post by Lokonli »
Bospieper wrote: Saturday 30 October 2021 15:56 Hi Lokonli,
Grz. Piet
It's a (known) issue with the external calendar module Dashticz uses on PHP7 systems.
As fall back you can use the PHP5 module by adding the following block parameter to the calendar block definition in CONFIG.js:
  method: 0,
See also:
https://dashticz.readthedocs.io/en/mast ... ndar#notes
Bospieper
Post by Bospieper »
I've added your suggestion to the calandar block but the calandar still repeats scheduled repeating appointments.
blocks['gmail_calendars'] = {
        type: 'calendar',
	method: 0,
        layout: 1,
	startonly: 'true',
        emptytext: 'Geen afspraken',
