Calendar: issue with repeating appointments
- Bospieper
- Domoticz version: 2026.3
When I have a repeating appointment, for example every 5 weeks, the appointment appears every week in the calendar.
Has anyone experience this behaviour?
Grtz Piet
Grtz Piet
- FireWizard
Re: Calendar: issue with repeating appointments
Hi, @Bospieper,
This question is off topic.
Can you explain the relationship between your calender (what calender?) and Domoticz?
[Edit] Oh, see, it is Dashticz.
Sorry
Sorry
- Bospieper
My mistake I had to mention that it is about Dashticz.
Lokonli
What is your Dashticz version? and PHP version?Bospieper wrote: Friday 22 October 2021 9:29 Hello,
Grtz Piet
(this influences which calendar module is used by Dashticz ...)
I'll do some tests.
- Bospieper
@Lokonli see the attachment
- Dashticz.JPG (52.47 KiB) Viewed 736 times
Lokonli
ok, thanks. I'll have a look.
- Bospieper
Hi Lokonli,
Did you manage to find the solution for my problem?
Grz. Piet
Grz. Piet
Lokonli
It's a (known) issue with the external calendar module Dashticz uses on PHP7 systems.Bospieper wrote: Saturday 30 October 2021 15:56 Hi Lokonli,
Grz. Piet
As fall back you can use the PHP5 module by adding the following block parameter to the calendar block definition in CONFIG.js:
method: 0,
https://dashticz.readthedocs.io/en/mast ... ndar#notes
- Bospieper
I've added your suggestion to the calandar block but the calandar still repeats scheduled repeating appointments.
blocks['gmail_calendars'] = {
type: 'calendar',
method: 0,
layout: 1,
startonly: 'true',
emptytext: 'Geen afspraken',
