Python Plugin: TUYA
- Domoticz version: 2020.2
Re: Python Plugin: TUYA
OK, after a little patience, the lamp came in as WW! Success!
Now all I have to do is re-install the other lamps. Which is more work than you'd expect, since they disappear from all scenes when deleted....
Is there a way to reset without deleting them?
Hans
- EdwinK
- Domoticz version: BETA
I just noticed this appearing again, about every second.
2021-04-02 10:24:56.251 Error: Tuya: (Tuya) handleThread: Expecting value: line 1 column 1 (char 0) line 198
Okay tried again with your scriptXenomes wrote: ↑Thursday 01 April 2021 21:02The second tuyaha is not needed with my version of the plug-in. I was mislead with the naming of the directory. You are using the version of guino in that version is has limited control of RGB. Can you try my version of the plug[in. https://github.com/Xenomes/Domoticz-TUYA-Plugin.
Version 1.0.6 is installed.
He sees the rgb strip as a switch and there is no RGB control
- Xenomes
- Domoticz version: 2024.7
I pushed a new update, remove faulty device => update plug-in => update button in Hardware at Tuya plug-in.Vomera wrote: ↑Friday 02 April 2021 12:10Okay tried again with your scriptXenomes wrote: ↑Thursday 01 April 2021 21:02The second tuyaha is not needed with my version of the plug-in. I was mislead with the naming of the directory. You are using the version of guino in that version is has limited control of RGB. Can you try my version of the plug[in. https://github.com/Xenomes/Domoticz-TUYA-Plugin.
HP T630 (32GB SSD/8GB Mem) - Ubuntu 22.04.4 LTS (64Bit) - Domoticz 2024.7 with Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
- Xenomes
I don't ever seen it, try stop the plug-in, wait for minimal 61 seconds and start plug-in.
- Xenomes
You can change the type/sub type directly in the database 1000% you own risk.
- Xenomes
Try stop the plug-in, wait for minimal 61 seconds and start plug-in again.manjh wrote: ↑Friday 02 April 2021 10:10OK, now getting version 6.
Deleted one lamp, disabled/enabled Tuya, now get this error in the log:Also:Code: Select all
Error: (Tuya devices) handleThread: Expecting value: line 1 column 1 (char 0) line 198
Error: (Tuya devices) handleThread: login rate limited line 195
Getting also the same error after updating your script, now in domoticz he sees the ledstrip as RGBXenomes wrote: ↑Friday 02 April 2021 12:28I pushed a new update, remove faulty device => update plug-in => update button in Hardware at Tuya plug-in.Vomera wrote: ↑Friday 02 April 2021 12:10Okay tried again with your scriptXenomes wrote: ↑Thursday 01 April 2021 21:02
021-04-02 13:20:46.573 Error: (Tuya) handleThread: Expecting value: line 1 column 1 (char 0) line 198
- Xenomes
Execute this and return the cli resultsVomera wrote: ↑Friday 02 April 2021 13:22Code: Select all
sudo pip3 install tuyaha
With Sudo command he said its already installed. So i tried to use the command pip3 install tuyaha. Tuya installed, maybe in the user account instead with admin account. In hardware tab update and after that it worked!!!!!. Finally!! Thank you so much!Xenomes wrote: ↑Friday 02 April 2021 15:02Execute this and return the cli resultsVomera wrote: ↑Friday 02 April 2021 13:22Code: Select all
- Xenomes
OK greet news! every system has his quirks.Vomera wrote: ↑Friday 02 April 2021 21:20Met sudo commando gaf hij al aan geinstalleerd te zijn. Daarna commando pip3 install tuyaha uitgevoerd en werd de tuya geinstalleerd waarschijnlijk user account. In hardware tab update uitgevoerd en daarna DEED HIJ HET!!!!. Eindelijk opgelost!! Dank je wel! Samen komen we er wel haha.Xenomes wrote: ↑Friday 02 April 2021 15:02Execute this and return the cli resultsVomera wrote: ↑Friday 02 April 2021 13:22Code: Select all
Ah. Risky, but exciting... is there a recommended tool to do this?
Hans
- Xenomes
Best is by hand, this is a bit off-topic, you have to install sqllite3.
OK, understand. I guess simply deleting and adding the lamps may be easier....
Hans
- Xenomes
U need to know how sql query works. select and update commands
I do, but the mere job of having to install SQL just for this small thing seems a bit over the top.
I've now deleted and re-installed the lamps, this was very simple.
Reviewing all scene settings was a bit more work, but also got it done.
All lamps are now recognized as WW. Thanks for the support!
Hans
One additional thought, perhaps a suggestion for the user interface.
Setting the right color from the color wheel is nice, but it is difficult to get multiple lamps on the same color level.
For the dimmer it can be done by simply moving the slider until the percentage is close enough.
But for color there is no numerical reference>
Would it be possible to add an input field, so that the user can choose to either select from the color wheel, or enter a value in the input field?
Hans
Now that the lamps are working, I am thinking about the next step: getting rid of the Tuya cloud dependency.
I ran into Tasmota, that seems promising.
Also found a procedure for flashing:
https://www.heise.de/ct/artikel/Tuya-Co ... 84830.html
Before I start playing around, possibly losing a perfectly good lamp, has anyone done this before? Any experience? Recommendations?
Hans
- Xenomes
The colour wheel is default function of Domotixz, request for a input field you need be at the developer of Domoticz.
Tuya-Convert only works with bulbs with a esp chip and older firmware version. Lots of new devices firmware upload hack don't work any more. You can't convert back to the original firmware without open and destroy the bulb. If the bulb accepts the Tasmota firmware then a new world of opportunities opens.
Users browsing this forum: averter, Bing [Bot], Google [Bot] and 1 guest
