Python Plugin: TUYA
manjh
- Domoticz version: 2025.2
Re: Python Plugin: TUYA
OK, after a little patience, the lamp came in as WW! Success!
Now all I have to do is re-install the other lamps. Which is more work than you'd expect, since they disappear from all scenes when deleted....
Is there a way to reset without deleting them?
Hans
- EdwinK
- Domoticz version: BETA
I just noticed this appearing again, about every second.
2021-04-02 10:24:56.251 Error: Tuya: (Tuya) handleThread: Expecting value: line 1 column 1 (char 0) line 198
Vomera
Okay tried again with your scriptXenomes wrote: Thursday 01 April 2021 21:02The second tuyaha is not needed with my version of the plug-in. I was mislead with the naming of the directory. You are using the version of guino in that version is has limited control of RGB. Can you try my version of the plug[in. https://github.com/Xenomes/Domoticz-TUYA-Plugin.
Version 1.0.6 is installed.
He sees the rgb strip as a switch and there is no RGB control
- Xenomes
- Domoticz version: 2026.4
I pushed a new update, remove faulty device => update plug-in => update button in Hardware at Tuya plug-in.Vomera wrote: Friday 02 April 2021 12:10Okay tried again with your scriptXenomes wrote: Thursday 01 April 2021 21:02The second tuyaha is not needed with my version of the plug-in. I was mislead with the naming of the directory. You are using the version of guino in that version is has limited control of RGB. Can you try my version of the plug[in. https://github.com/Xenomes/Domoticz-TUYA-Plugin.![]()
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
- Xenomes
I don't ever seen it, try stop the plug-in, wait for minimal 61 seconds and start plug-in.EdwinK wrote: Friday 02 April 2021 10:26 I just noticed this appearing again, about every second.
Tinytuya
Tinytuya
- Xenomes
You can change the type/sub type directly in the databasemanjh wrote: Friday 02 April 2021 10:16 OK, after a little patience, the lamp came in as WW! Success!
Tinytuya
Tinytuya
- Xenomes
Try stop the plug-in, wait for minimal 61 seconds and start plug-in again.manjh wrote: Friday 02 April 2021 10:10OK, now getting version 6.Xenomes wrote: Thursday 01 April 2021 22:06That is not the latest version ... Delete devices and update the plug-in, restart Domoticz and see the new detection.
Edit: Just push a new version
(⚠ RGBW(W) lights must be on a colour for correct detection ⚠)
Deleted one lamp, disabled/enabled Tuya, now get this error in the log:Also:Code: Select all
Error: (Tuya devices) handleThread: Expecting value: line 1 column 1 (char 0) line 198Code: Select all
Error: (Tuya devices) handleThread: login rate limited line 195
Tinytuya
Tinytuya
Vomera
Getting also the same error after updating your script, now in domoticz he sees the ledstrip as RGBXenomes wrote: Friday 02 April 2021 12:28I pushed a new update, remove faulty device => update plug-in => update button in Hardware at Tuya plug-in.Vomera wrote: Friday 02 April 2021 12:10Okay tried again with your scriptXenomes wrote: Thursday 01 April 2021 21:02
021-04-02 13:20:46.573 Error: (Tuya) handleThread: Expecting value: line 1 column 1 (char 0) line 198
- Xenomes
Execute this and return the cli resultsVomera wrote: Friday 02 April 2021 13:22Code: Select all
sudo pip3 install tuyahaHP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
Vomera
With Sudo command he said its already installed. So i tried to use the command pip3 install tuyaha. Tuya installed, maybe in the user account instead with admin account. In hardware tab update and after that it worked!!!!!. Finally!! Thank you so much!Xenomes wrote: Friday 02 April 2021 15:02Execute this and return the cli resultsVomera wrote: Friday 02 April 2021 13:22Code: Select all
021-04-02 13:20:46.573 Error: (Tuya) handleThread: Expecting value: line 1 column 1 (char 0) line 198Code: Select all
Vomera
You can see if the answer above this post will helpEdwinK wrote: Friday 02 April 2021 10:26 I just noticed this appearing again, about every second.
- Xenomes
OK greet news! every system has his quirks.Vomera wrote: Friday 02 April 2021 21:20Met sudo commando gaf hij al aan geinstalleerd te zijn. Daarna commando pip3 install tuyaha uitgevoerd en werd de tuya geinstalleerd waarschijnlijk user account. In hardware tab update uitgevoerd en daarna DEED HIJ HET!!!!. Eindelijk opgelost!! Dank je wel! Samen komen we er wel haha.Xenomes wrote: Friday 02 April 2021 15:02Execute this and return the cli resultsVomera wrote: Friday 02 April 2021 13:22Code: Select all
Tinytuya
Tinytuya
manjh
Ah. Risky, but exciting... is there a recommended tool to do this?Xenomes wrote: Friday 02 April 2021 12:31You can change the type/sub type directly in the databasemanjh wrote: Friday 02 April 2021 10:16 OK, after a little patience, the lamp came in as WW! Success!
Is there a way to reset without deleting them?1000% you own risk.
Hans
- Xenomes
Best is by hand, this is a bit off-topic, you have to install sqllite3.manjh wrote: Saturday 03 April 2021 10:02 Ah. Risky, but exciting... is there a recommended tool to do this?
Tinytuya
Tinytuya
manjh
OK, understand. I guess simply deleting and adding the lamps may be easier....
Hans
- Xenomes
U need to know how sql query works. select and update commandsmanjh wrote: Saturday 03 April 2021 10:58OK, understand. I guess simply deleting and adding the lamps may be easier....
Tinytuya
Tinytuya
manjh
I do, but the mere job of having to install SQL just for this small thing seems a bit over the top.Xenomes wrote: Saturday 03 April 2021 11:02U need to know how sql query works. select and update commands
I've now deleted and re-installed the lamps, this was very simple.
Reviewing all scene settings was a bit more work, but also got it done.
All lamps are now recognized as WW. Thanks for the support!
Hans
manjh
One additional thought, perhaps a suggestion for the user interface.
Setting the right color from the color wheel is nice, but it is difficult to get multiple lamps on the same color level.
For the dimmer it can be done by simply moving the slider until the percentage is close enough.
But for color there is no numerical reference>
Would it be possible to add an input field, so that the user can choose to either select from the color wheel, or enter a value in the input field?
Hans
manjh
Now that the lamps are working, I am thinking about the next step: getting rid of the Tuya cloud dependency.
I ran into Tasmota, that seems promising.
Also found a procedure for flashing:
https://www.heise.de/ct/artikel/Tuya-Co ... 84830.html
Before I start playing around, possibly losing a perfectly good lamp, has anyone done this before? Any experience? Recommendations?
Hans
- Xenomes
The colour wheel is default function of Domotixz, request for a input field you need be at the developer of Domoticz.manjh wrote: Saturday 03 April 2021 11:20 Would it be possible to add an input field, so that the user can choose to either select from the color wheel, or enter a value in the input field?
Tuya-Convert only works with bulbs with a esp chip and older firmware version. Lots of new devices firmware upload hack don't work any more. You can't convert back to the original firmware without open and destroy the bulb. If the bulb accepts the Tasmota firmware then a new world of opportunities opens.manjh wrote: Saturday 03 April 2021 14:12 Before I start playing around, possibly losing a perfectly good lamp, has anyone done this before? Any experience? Recommendations?
Tinytuya
Tinytuya
