Dashticz v3.7.4 beta
Lokonli
Post by Lokonli »
Dashticz v3.7.4 has just been released.
This release mainly contains some dial related improvements:
* Text devices are supported.
* The formatting of values changed. If needed add 'decimals: 0' to your block definition to remove the digits behind the decimal point.
For a description of all changes check the release notes:
https://dashticz.readthedocs.io/en/beta ... -20-2-2021
madpatrick
Domoticz version: 2025.2
Re: Dashticz v3.7.4 beta
Post by madpatrick »
Hi Lokonli,
I tried the 'decimals: 0' parameter with a dimmer, but this still give a decimal in the dial
blocks['dimmer_hal']	 	= {idx: 154, type: 'dial', color: '#ffff00', width: 2, last_update: false, title:' ', shownumbers: true, showring: true, showunit: true,decimals: 0}
Foxhill67
Post by Foxhill67 »
Hi Lokonli,
since update to V3.7.4 beta (from V3.7.2 beta), my combined calendars block only shows text 'Button'.
calendars.combined = {width: 10, maxitems:15, calFormat:1, dateFormat: "dd DD MMM", timeFormat: "HH.mm", calendars: [{ color:'white',calendar:calendars.x},{ color:'aqua',calendar:calendars.y},{ color:'lightcoral',calendar:calendars.z},{ color:'yellow',calendar:calendars.w},{ color:'lightgreen',calendar:calendars.holiday}]}
Any suggestions how to fix this?
HansieNL
Post by HansieNL »
Foxhill67 wrote: Saturday 20 February 2021 20:37 Hi Lokonli,
The parameter calFormat is absolute since V3.7.3. You have to use one of the layout formats.
See https://dashticz.readthedocs.io/en/bet ... endar.html
Blah blah blah
Krenstik
Post by Krenstik »
I miss a usage el. dial. but all other dial ( mostly with temp, CO2) working
blocks['spotreba'] =    {      type: 'dial', title: 'Odběr', width: 6, min: 100, max: 3500, showunit: false, shownumbers: true, last_update:false, showring: true,
        values : [      { value: 'Data', idx: 66  },
			{ value:'Data', idx: 63,  },
			{ value:'CounterToday', idx: 65,           },	]}
Also any idea how to set setpoint, for example here on the value 1500. ...
Or for ppm dial:
ocks['oco'] = {        type: 'dial', width: 2, title: 'Obyvak', showunit: true, switch: true, shownumbers: true, showring: true, last_update: true, setpoint: 1300, min: 450, max: 2700,
        values : [      { value: 'Data', idx: 47       },
			{ value: 'Data', idx: 48 , icon: 'fas fa-volume-up', unit:' dB',  },
			{ value: 'Data', idx: 22 , unit:' LUX',  }, ]}
Thank you.
Foxhill67
Post by Foxhill67 »
HansieNL wrote: Saturday 20 February 2021 22:21
Thanks, must have missed this while reading the release notes. Have updated my config.js and everything works like a charm again!
Lokonli
Post by Lokonli »
madpatrick wrote: Saturday 20 February 2021 19:31 Hi Lokonli,
Should be fixed in latest beta. Can you test?
madpatrick
It is working now.
Lokonli
Post by Lokonli »
Krenstik wrote: Saturday 20 February 2021 23:02 Hi,
I don't understand your remark. Can you clarify?
Can you add the Domoticz json output of the device you want to show:
http://domoticzip:port/json.htm?type=devices&rid=123
replace 123 with your Domoticz device id.
Can you also indicate which field you would like to use for the dial?
Krenstik
Post by Krenstik »
is a power concuption. In last beta was fully working:
Snímek obrazovky 2021-02-21 163912.jpg (53.83 KiB) Viewed 1134 times
but now I have just name:
Snímek obrazovky 2021-02-21 163940.jpg (43.62 KiB) Viewed 1134 times
And here a json:
ActTime: 1613922038,
AstrTwilightEnd: "19:10",
AstrTwilightStart: "05:05",
CivTwilightEnd: "17:56",
CivTwilightStart: "06:19",
DayLength: "10:33",
NautTwilightEnd: "18:33",
NautTwilightStart: "05:42",
ServerTime: "2021-02-21 16:40:38",
SunAtSouth: "12:07",
Sunrise: "06:51",
Sunset: "17:24",
app_version: "2020.2 (build 12738)",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "521.6 Watt",
Description: "",
Favorite: 1,
HardwareDisabled: false,
HardwareID: 6,
HardwareName: "Z-wave",
HardwareType: "OpenZWave USB",
HardwareTypeVal: 21,
HaveTimeout: false,
LastUpdate: "2021-02-21 16:40:35",
Name: "Spotřeba komplet",
Notifications: "false",
PlanID: "9",
PlanIDs: [
9
Protected: false,
ShowNotifications: true,
SignalLevel: "-",
SubType: "Electric",
Timers: "false",
Type: "Usage",
TypeImg: "current",
Unit: 2,
Used: 1,
XOffset: "767",
YOffset: "148",
idx: "66"
status: "OK",
title: "Devices"
and dial:
			{ value:'CounterToday', idx: 65,           },]}
Lokonli
Post by Lokonli »
Krenstik wrote: Sunday 21 February 2021 16:42 Hi,
is a power concuption. In last beta was fully working:Snímek obrazovky 2021-02-21 163912.jpg
And here a json:
DayLength: "10:33",
Sunrise: "06:51",
Sunset: "17:24",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "521.6 Watt",
Description: "",
Favorite: 1,
HardwareID: 6,
HaveTimeout: false,
PlanID: "9",
PlanIDs: [
9
Protected: false,
SignalLevel: "-",
Timers: "false",
Type: "Usage",
TypeImg: "current",
Unit: 2,
Used: 1,
XOffset: "767",
YOffset: "148",
idx: "66"
status: "OK",
title: "Devices"
and dial:
Could you post the Domoticz json output for device 63 and 65 as well?
Krenstik
Post by Krenstik »
Here 63:
ActTime: 1613931558,
DayLength: "10:33",
ServerTime: "2021-02-21 19:19:18",
Sunrise: "06:51",
Sunset: "17:24",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "236.47 V",
Description: "",
Favorite: 0,
HardwareID: 6,
HaveTimeout: false,
LastUpdate: "2021-02-21 19:15:59",
PlanID: "0",
PlanIDs: [
0
Protected: false,
SignalLevel: "-",
SubType: "Voltage",
Timers: "false",
Type: "General",
TypeImg: "current",
Unit: 1,
Used: 1,
Voltage: 236.47,
XOffset: "0",
YOffset: "0",
idx: "63"
status: "OK",
title: "Devices"
and here 65:
ActTime: 1613931674,
DayLength: "10:33",
ServerTime: "2021-02-21 19:21:14",
Sunrise: "06:51",
Sunset: "17:24",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CounterToday: "8.000 kWh",
CustomImage: 0,
Data: "1311.800 kWh",
Description: "",
EnergyMeterMode: "",
Favorite: 0,
HardwareID: 6,
HaveTimeout: false,
LastUpdate: "2021-02-21 19:21:05",
Name: "Denní spotřeba",
PlanID: "9",
PlanIDs: [
9
Protected: false,
SignalLevel: "-",
SubType: "kWh",
SwitchTypeVal: 0,
Timers: "false",
Type: "General",
TypeImg: "current",
Unit: 1,
Usage: "506.5 Watt",
Used: 1,
XOffset: "766",
YOffset: "87",
idx: "65"
status: "OK",
title: "Devices"
Lokonli
Post by Lokonli »
And here a json:
DayLength: "10:33",
Sunrise: "06:51",
Sunset: "17:24",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "521.6 Watt",
Description: "",
Favorite: 1,
HardwareID: 6,
HaveTimeout: false,
PlanID: "9",
PlanIDs: [
9
Protected: false,
SignalLevel: "-",
Timers: "false",
Type: "Usage",
TypeImg: "current",
Unit: 2,
Used: 1,
XOffset: "767",
YOffset: "148",
idx: "66"
status: "OK",
title: "Devices"
and dial:
I can reproduce your issue if you have defined the following in CONFIG.js:
config['use_favorites'] = 1
In this case, Dashticz doesn't receive the information for device 63 and device 65, since they are not marked as favorite in Domoticz.
So, change this setting to:
config['use_favorites'] = 0
In the mean time, I've improved the dial error handling in latest beta, so at least you see some info when this error occurs.
Can you test with latest beta?
Krenstik
Post by Krenstik »
I do not have it in the config at all, but anyway if I add to confing this not help..
But select those two Domoticz as a favourite help. ;-)
Thank you.
For sure, the latest beta, I´ve updated now. ;-)
And regarding setpoint for ppm, or this power consumption?
Lokonli
Post by Lokonli »
Krenstik wrote: Sunday 21 February 2021 22:56 And regarding setpoint for ppm, or this power consumption?
Should work in latest beta. Can you test?
Krenstik
Post by Krenstik »
Snímek obrazovky 2021-02-23 184359.jpg (270.49 KiB) Viewed 1050 times
Working well.
NIce ;-) Thank you.
pvklink
Domoticz version: latest b
Post by pvklink »
I have the latest beta running without any problems.
I have several dials, and want to get my p1 dial ok.
Its a dial for a energie p1 device with two meters, day and night
I like to show the two values/data 9835192 and 9763855 instead of -3.99 it is showing now..
Can somebody give me a hint how to acomplish this?
Jablotron connection, Ikea
Lokonli
Post by Lokonli »
pvklink wrote: Tuesday 23 February 2021 20:30 I have the latest beta running without any problems.
Add the following to your block:
  values:['Counter', 'CounterDeliv']
Also see:
https://dashticz.readthedocs.io/en/beta ... neric-dial
pvklink
Post by pvklink »
thanks, and i am gonne read the beta doc
pvklink
Post by pvklink »
OK,
This is the total of the two vaues together.
How do i show both seperate?
When i want to check my bill :-) day and night counters
